Whiteline Transmission Mount Bushing insert???? - Mustang Evolution
Old 05-24-2014, 07:14 PM   #1
2014GT's Avatar
I've read the reviews on AM but has anyone here tried it out. For $35 I ordered it to give it a go.
2014 Mustang GT w/Trackpack
Competition Auto Dyno 93Race Tune, Flowmaster Outlaw Axle-Back, JLT Oil Separator, Barton Two-Post Shifter, Airaid CAI, BMR LCA w/relocation bracket, SR Performance Adj Panhard Bar, Whiteline Panhard Bar Support Brace, MM camber plates, Koni STR Shocks/Struts, Steeda Ultralight Springs. Future Mods: aluminum Driveshaft, Barton short throw shifter, BMR adj UCA, long tubes/H-Pipe
2014GT is offline   Reply With Quote
Old 05-24-2014, 07:27 PM   #2
Rapinator126's Avatar
It works
Old 05-24-2014, 09:10 PM   #3
2014GT's Avatar
Did you cut a hole in yours to reduce nvm? I've read a few did that
Sent from my HTC One X using Mustang Evolution mobile app
Old 05-24-2014, 10:25 PM   #4
I did...still works and quieter....
Old 05-24-2014, 11:54 PM   #5
I didn't. The extra NVH does not bother me.
Old 05-25-2014, 02:12 AM   #6
Jsmorley81's Avatar
I cut the tab half off and noticed no noise at all. Fells a lot firmer when shifting
Jsmorley81 is offline   Reply With Quote
Old 05-25-2014, 11:39 AM   #7
2014GT's Avatar
Ok so you simply cut it in half? Interesting
Old 05-25-2014, 11:40 AM   #8
2014GT's Avatar
I don't mind a little NVH but as my daily driver I would to keep it to a min.
Old 05-25-2014, 11:57 AM   #9
Oh2freshstang's Avatar
I've seen people cut the middle tab entirely off & some 1/3 or 1/2 & I've also seen people cut a circle out & they all seem to work the same!
Old 05-25-2014, 12:54 PM   #10
Jsmorley81's Avatar
Yes I read all the reviews about cutting it in half, cutting a hole and cutting it all the way off. Some people say no nvh at all and they didn't cut any thing. So I didn't want to have to redo it it so I cut my tab half off and put it in. I notice no nvh at all with it done that way. But I think every ones car may be a little different. IMO
Old 05-25-2014, 01:33 PM   #11
2014GT's Avatar
Cool! I'm going to cut half off
Old 05-25-2014, 03:09 PM   #12
Some dude put it in then tried it out then took it out & cut a small piece then keep doing the same thing till he was happy but that sounds like too much work for me! Haha.
Old 05-25-2014, 03:33 PM   #13
Its really not that bad. Put it on how it comes and roll with it.
Old 05-25-2014, 09:25 PM   #14
NoSlo5oH's Avatar
What Rapinator said. I have poly motor mounts and the Whiteline bushing and no NVH. The tongue is what helps keep the bushing in place. I know many have modified theirs, but I personally wouldn't recommend it.
NoSlo5oH is offline   Reply With Quote
Old 05-29-2014, 06:48 PM   #15
20bmr14's Avatar
I installed mine and it was fine for higher speeds but when the vehicle is running 10-15mph creeping through a parking lot there is alot of pops and creaks and every noise when changing gears. It seems now that most of those noises are either settled or I am used to them. I would not take it out or cut it but it was noisey for me at first.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 05-29-2014, 09:35 PM   #16
HPFury's Avatar
I cut a 2" hole in mine and hardly notice any NVH.
HPFury is offline   Reply With Quote
Old 05-30-2014, 04:37 AM   #17
Camron502's Avatar
I installed mine and had the same significant increase in NVH. It seemed like it got a little better and I got more used to it after about a week, but I still decided to drill a 1 3/4 inch hole in it and reinstall. All of the increased NVH is now gone and no change in the performance from prior to the modification. With the Barton 2 post bracket, the clutch line upgrade, and the Whiteline bushing with Royal Purple fluid, the tranny is like a rock now... Huge improvement!!
2013 Roush Stage 3 M6 Roush CAI, 82mm pulley, ID1000's, KB BAP, Vossen CV3 20x9-20x10.5, Michelin Pilot SS, Lethal O/R X, GT500 axleback, Barton Shifter with 2-post bracket, Clutch Line Upgrade, Boss Trans Cooler, Dynotech Aluminum Driveshaft, BMR Driveshaft Loop, Whiteline Trans Bushing, BMR LCA's with Relo Brackets, Adjustable Panhard Bar, GT500 STB, Steeda X-Brace, Steeda rear sway, JLT Oil Separator, GT500 Diff Cover, Afco Heat Exchanger, 170* T-stat, Tint, RP Fluids, aeroforce interceptors///688rwhp 605lb/ft torque cornfed
Camron502 is offline   Reply With Quote
Whiteline transmission bushing ThinBlueLine 2011-2014 Mustang GT 34 09-04-2014 01:01 PM
Whiteline trans mount gtstyles2 2011-2014 Mustang GT 16 03-27-2014 12:18 PM
whiteline trans mount GypsyChris 2011-2014 Mustang GT 12 12-15-2013 09:06 AM
Anyone have whiteline LCA Relocation brackets on Schram1 2011-2014 V6 Mustang 0 02-01-2013 12:21 PM
Whiteline anti-dive kits mmike87 2011-2014 Mustang GT 0 11-28-2012 06:48 PM
07:39 AM
