Installing parts today - Mustang Evolution
Old 05-25-2014, 01:06 AM   #1
Later today I will be installing a few rear end suspension parts.BMR rear LCA's,BMR adjustable Panhard bar and BMR LCA relocation bracket.Any tips or known speed bumps I might encounter during install or things I should look for?My buddy has lots of experience with the coyotes as he has one himself so he knows exactly what he's doing.I figured I'd just ask if you guys got any personal install tips or issues you remember that you encountered so I can avoid ya know.
Thanks
2012 Kona Blue Metallic GT,6spd,3.73's,MGW Shifter,H&R lowering springs,BMR Panhard Bar,BMR Rear LCA,BMR relocaton brackets,Roush Axlebacks
BigBlue5.0 is offline   Reply With Quote
Old 05-25-2014, 07:49 AM   #2
Deerslayer's Avatar
Rear suspension is pretty straight forward and not too difficult except for a UCA can be challenging if you dont have a lift. After you install, drive around for a bit, make a few pulls and then go back and measure and make adjustments to your panhard bar. Use a yard stick up against each rear wheel and measure to your fender edge top dead center while the car is down and level. Jack up and make your adjustments to what your measurements were.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Installing 2013 axlebacks today! OzzyLiriano 2011-2014 Mustang GT 44 10-26-2012 11:13 AM
Got some new parts today Chris01 1979-1995 Mustang GT 10 06-09-2011 01:25 PM
Installing Mustang GT parts on V6? Derby General Mustang Discussion 1 03-01-2010 08:09 AM
Installing new headlights today CreationNation 1979-1995 Mustang GT 7 04-04-2009 11:07 AM
Out searching for parts today... BruThru2002 The Bar 14 10-26-2003 12:10 PM
09:36 AM
