UMI lower control arms...with "Roto-joint" - Mustang Evolution
Old 06-02-2014, 10:10 AM   #1
Anyone have experience with UMI suspension components and more specifically their lower control arms?
I'm looking at a set of their adjustable LCA's with poly bushings on one end and a "roto-joint" on the other. It appears to be similar to del-spheres. I'm not sure what everyones opinions of these are, but it seems it would reduce suspension bind but without adding all the harshness of a rod end.
On another note, how much are we leaving on the table by going with all poly bushings? It seems to me that suspension bind would be a serious issue with Poly bushings on an LCA. Does it even matter?
BadCon is offline   Reply With Quote
Old 03-10-2016, 07:43 AM   #2
CCS86's Avatar
Wow, it sucks that no one replied to this.
Yes, going fully poly/poly is not a good idea. The resistance to rotation needed for the car to roll, causes spikes in the wheel rate as the car rolls, and that makes traction unpredictable.
One exception might be a fancier multi-piece poly bushing, which uses lower durometer material on the outboard edges of the bushing to help accommodate roll. I don't have any hands on experience with these.
I am running an UCA and panhard bar from Spohn, with a poly/del-sphere combo. The Del-sphere joint is essentially identical to the roto joint. The concept is great, but Spohn's execution is terrible. They paid no attention to important things like fitment between parts. For example, the heinously loose fit between the UCA mounting bolt and the center of the sphere, or the two adjoining spacers. Or, the fact the the spanner nut to tighten the del-sphere will actually make contact with the sphere, instead of just pushing on the delrin cup, due to a lack of concentricity on the nut's features, and improper chamfered relief on the nut. How about that they didn't even bother to put a protrusion on the side of the UCA to capture the factory tabbed nut, keeping it a one-tool job like from the factory, and forcing you to put a second tool on the very shallow headed factory nut.
Spohn is a turd of a company, do half-assed work at best, and do not stand behind their products.
I'm interested in finding some hands on opinions about UMI in general, and their roto joint. I've exchanged a few emails with them, and they seem responsive and helpful, but I haven't put my hands on any of their parts.
Even now with the Del-sphere/poly combo on the UCA, I can still get a hint of wheel hop in certain situations on wet pavement. Annoying. I think maybe past wheel hop has damaged the rubber LCA bushings. So, I've got an eye on the UMI LCA's on-car adj. Roto/Poly combo.
Hopefully someone else can chime in with an experience!
CCS86 is offline   Reply With Quote
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
Front Lower Control Arm or Ball Joint Replacment? EthanGT03 1996-2004 Mustang GT 15 01-10-2014 06:37 AM
lower control arms vs. upper control arms 13 stang22 2011-2014 V6 Mustang 24 05-08-2013 06:03 AM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 03:43 PM
02:03 AM
