Removing Gauge Cluster on 2014 - Mustang Evolution
Old 06-03-2014, 12:00 AM   #1
Big Q's Avatar
Region: Nebraska
Hi, wanted to see if someone could walk me through removal of the gauge cluster on my GT? Need to do some modifications to it to install a raptor shift light and would be easier to do that with it out of the car...
Big Q is offline   Reply With Quote
Old 06-03-2014, 05:25 AM   #2
Deerslayer's Avatar
The Cluster Bezel pulls off by hand. Using a plastic pry tool, place it in the top left edge and pry the bezel away from the dash. It ill pop out in seconds. Next, there are two 8mm bolts on each side that you remove. Next pull the bezel out and unplug it. 5min job max.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 06-03-2014, 05:45 AM   #3
Big Q's Avatar
Region: Nebraska
Great, thanks. Was expecting more of a job than that...
Old 06-03-2014, 08:09 AM   #4
Deerslayer's Avatar
Nothing too it
Old 06-03-2014, 07:49 PM   #5
Post photos of which wires you tap into for the shift light. Also a photo of the light on the dash when it's all done.
bullet3z is offline   Reply With Quote
Old 06-03-2014, 08:42 PM   #6
Big Q's Avatar
Region: Nebraska
Will do, gonna do the install this Saturday.
Removing Cluster Needles 2003SonicBlue Pre-2005 V6 Mustang 5 01-20-2012 12:43 PM
2001 gauge cluster whitev6stang03 Pre-2005 V6 Mustang 5 12-10-2005 12:26 PM
mach 1 gauge cluster whitev6stang03 Pre-2005 V6 Mustang 13 01-22-2005 10:51 PM
Cleaning out the garage: 3.73's/Gauge cluster/trans cooler Suprman Mustang Parts for Sale and Wanted 10 10-08-2004 11:05 PM
99-04 GT Gauge Cluster > '02 V6?? mattstang Mustang Audio & Video 8 12-15-2003 08:13 AM
01:55 AM
