Suspension questions - Mustang Evolution
Old 06-03-2014, 03:12 AM   #1
I'm trying to tighten up the front end suspension/lowered maintenance.I bought the car with lowering springs already installed so im playing catch up with the proper supporting mods for a lowered car.I I'm looking at Steeda's bump steer kit and ball joint kit and also while I'm at it inner tie rods as well.With the bump steer kit it says it's adjustable,how would I gauge I guess is the best word how to properly adjust it.(if that makes any sense)basically I'm confused on what I'd be looking to adjust when installing.Or is this something that is done during the alignment??And I also want to make sure installing the bump steer or ball joint kit won't change my ride height correct?Appreciate any help as I'm trying to learn but it's a process and I'm afraid to ask for help lol
2012 Kona Blue Metallic GT,6spd,3.73's,MGW Shifter,H&R lowering springs,BMR Panhard Bar,BMR Rear LCA,BMR relocaton brackets,Roush Axlebacks
BigBlue5.0 is offline   Reply With Quote
Old 06-03-2014, 05:19 AM   #2
2014GT's Avatar
If it only has lowering springs the next step would be new shocks and struts. I prefer koni. I don't think the parts you are looking at are really needed.
Sent from my HTC One X using Mustang Evolution mobile app
2014 Mustang GT w/Trackpack
Competition Auto Dyno 93Race Tune, Flowmaster Outlaw Axle-Back, JLT Oil Separator, Barton Two-Post Shifter, Airaid CAI, BMR LCA w/relocation bracket, SR Performance Adj Panhard Bar, Whiteline Panhard Bar Support Brace, MM camber plates, Koni STR Shocks/Struts, Steeda Ultralight Springs. Future Mods: aluminum Driveshaft, Barton short throw shifter, BMR adj UCA, long tubes/H-Pipe
2014GT is offline   Reply With Quote
Old 06-04-2014, 11:55 AM   #3
tj@steeda's Avatar
Here are the directions for adjusting the kit on the alignment rack:
http://www.steeda.com/store/uploads/555-8106-1.pdf
What does the car currently have on it ... if you are lowered from a previous owner .. does it have a panhard bar?
Send me an email at tim@steeda.com & let's discuss what your options are. No, the ball joints will not raise the car.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 06-04-2014, 12:50 PM   #4
I put a panhard bar on myself,it's got rear LCA,relocation bracket and the panhard bar,and lowering springs.Thats all the suspension work done so far
Old 06-04-2014, 01:03 PM   #5
tj@steeda's Avatar
Okay ... what are you goals & what do you do with the car? Are you looking for a better handling DD or are you looking to drag or track it?
TJ
Steeda Autosports
www.steeda.com
Old 06-04-2014, 11:25 PM   #6
Looking for a better handling DD with potential for some light Auto crossing.The power is more than enough,in the end I'll probably have full exhaust,intake,tune.Basic bolt ons,but I want it to handle much better than it does right now
Old 06-05-2014, 07:07 AM   #7
tj@steeda's Avatar
I do not see any upper strut mounts on your list of equipment. (That is highly recommended)
How much lower is the car than stock?
If you would like ... please send me an email at tim@steeda.com & we can talk off-line about your options & how to achieve your goals with the proper set-up.
TJ
Steeda Autosports
www.steeda.com
Old 06-05-2014, 12:30 PM   #8
Just sent you an email
Suspension Questions fadedsoldier 2011-2014 V6 Mustang 2 07-03-2012 06:27 AM
suspension questions taylor98gt 1996-2004 Mustang GT 15 04-16-2012 06:55 PM
front suspension questions white98gt 1996-2004 Mustang GT 3 12-13-2010 08:20 AM
Suspension questions?????? CC plates? Panhard bar? Camaro Eater Pre-2005 V6 Mustang 4 07-02-2010 09:47 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
12:37 PM
