Koni STR.t making noise - Mustang Evolution
Old 06-05-2014, 07:56 AM   #1
All
I purchased and installed a set of Koni’s for my 2013 GT, now I hear a noise coming from the left front strut. This started immediately.
Though it was my first install, it went off w/o a hitch. I had the right tools, took my time and made sure everything was torqued to spec. When I test drove the car after the install everything was fine but then I started to hear a very faint noise like a piston working sound (hard to explain). If I have the radio on at barely audible levels you can’t hear it. After driving the car for 300 miles, I removed the wheels and re torqued all bolts, still the same noise. I found out if I drive the car for a couple of miles, I can physically pull up on the fender and the car makes the piston noise almost as if the Strut is binding on something.
Has anyone ever experienced this? If so, what have did you do to stop the noise?
84GCock is offline   Reply With Quote
Old 06-06-2014, 12:45 AM   #2
Were they the correct struts for the 2011+ models? Did you replace or have any issues with the strut mounts? If everything is tight and the install went well, I'd say you got a bad strut.
SecretAgent is offline   Reply With Quote
Old 06-06-2014, 05:28 AM   #3
Yes, they are the correct struts for the 2011+.
I didn't replace the strut mounts, had no problems with them coming apart like others have experienced.
I think the issue might be with the Strut as well. Going to have a mechanic friend take a look at it before I order a new one.
Old 06-06-2014, 05:38 AM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The factory strut mounts are poorly made and even though it didn't come apart on you, I would still keep it in mind as the possible cause. An upgrade to C/C plates or at least the GT500 strut mounts would probably be a good idea.
2012 Kona Blue 3.7L V6:
Old 06-06-2014, 08:08 AM   #5
GT500 mounts don't work on 11+ struts.
Old 06-06-2014, 08:59 AM   #6
Grabber Blue5.0's Avatar
This is what I'm thinking.
Correct. Which is a good reason to get 05-10 struts and use the GT500 mounts.
Old 06-06-2014, 09:08 AM   #7
Abominable Mustang
WhoDat's Avatar
Region: Alaska
That's what I have. 05-10 Koni STR.Ts with GT500 upper strut mounts. Not a sound so far.
Old 06-07-2014, 06:13 AM   #8
lilediselec's Avatar
I have the Koni 11-14 I blew top mounts costs 42$ at ford hasn't made a noise since
lilediselec is offline   Reply With Quote
Old 06-07-2014, 06:20 AM   #9
How long were your Konis installed before your mounts went?
Old 06-07-2014, 06:30 AM   #10
A week or so it was only the driver side but it would make a terrible metal on metal sound when I turned the wheel.
Old 06-07-2014, 11:18 AM   #11
Yeah the mounts are going to make more noise when turning the wheel than from up and down motion. I still think you have a bad strut. Best way to tell is take that corner back apart separate the spring and strut and work the strut by hand. It should be firm and silent when you push down on the rod and return on its own to the top position within a couple seconds.
Old 06-07-2014, 11:37 AM   #12
Wait, so I was planning on getting bmr lowering springs with the gt500 strut mounts. Does this mean I need to get the 05-10 str.t koni's?
Old 06-07-2014, 11:39 AM   #13
You need a strut for 05-10 years.
Old 06-07-2014, 11:43 AM   #14
With those strut mounts you use 05-10 struts.
Old 06-07-2014, 08:20 PM   #15
Why is this? koni made the 11-14 struts not compatible with gt500 mounts but they are for 05-10? Weird.
Old 06-07-2014, 08:36 PM   #16
It's because the 05-10 mustangs (including the gt500) use a different shaft size than the 11-14 v6/gt mustangs. Koni was one of the first aftermarket companies to recognize this and offer a specific 11-14 strut
Old 06-07-2014, 08:41 PM   #17
Abominable Mustang
WhoDat's Avatar
Region: Alaska
With those strut mounts you use 05-10 springs
Nope. I've got 11+ springs on 05-10 struts with gt500 mounts. Works like a champ.
This goes for all aftermarket struts. It's due to the length of the threaded portion at the top of the 11+ struts being shorter than the 05-10s. It's not long enough to go through the gt500 mounts. I can say this from personal experience and wasted money.
Old 06-07-2014, 08:46 PM   #18
2 Stangz's Avatar
Region: Nevada
There's an extremely high chance its the factory strut mounts as users have reported. Also, I didn't see you mention anything about getting a proper alignment after installation... I'd recommend that as well.
Old 06-07-2014, 08:50 PM   #19
I'd certainly not recommend getting an alignment done until he fixes the clunk. Otherwise he's just throwing away $80.
Old 06-07-2014, 08:57 PM   #20
Very good to know, thanks!
Old 06-07-2014, 09:27 PM   #21
Old 06-08-2014, 05:19 AM   #22
If you use the GT500 mounts an alignment isn't necessary.
Old 06-08-2014, 01:49 PM   #23
2 Stangz's Avatar
Region: Nevada
Oops. Misread.
Old 06-08-2014, 02:44 PM   #24
An alignment is recommended any time the suspension is apart. No adjustments may be needed, but still best to check. Tires aren't cheap, and even a slightly out if spec alignment can destroy them in weeks. Not to mention darty or floaty characteristics from the front suspension if toe or caster is off.
Old 06-08-2014, 03:50 PM   #25
Plan to do that in the next couple of days, I suspect that the unit is bad.
---------- Post added at 05:50 PM ---------- Previous post was at 05:49 PM ----------
Yep, that's my plan. Get all of this worked out before the alignment.
Old 06-08-2014, 04:05 PM   #26
Wrong. If you install the GT500 mounts with the arrows pointed in you'll gain back the camber you lost. The toe isn't affected enough to warrant checking. But by all means spend the money if it makes you feel warm and fuzzy.
Old 06-08-2014, 04:58 PM   #27
FYI...most places do not charge to do an alignment check so it's free if there's no adjustments needed. How's that for warm and fuzzy. 😁
Old 06-08-2014, 05:03 PM   #28
I check my own alignment in my garage with nothing more than a straight edge and a digital level. Pretty smart huh? No fancy equipment needed.
Old 06-08-2014, 05:19 PM   #29
No matter how good you are with that straight edge and digital level, you'll never get it as perfect as an alignment rack will. But if you want to continue to argue over the matter I'll oblige.
Old 06-15-2014, 09:42 PM   #30
Got the new Strut in, all is right with the world! No more noise. Surprised I had a problem with the first one. Handled everything with white gloves.
Old 06-15-2014, 09:48 PM   #31
TooSlow4U's Avatar
I have the 11+ konis with ground control cc plates. The gc plates are the best way to go in my opinion and experience.
TooSlow4U is offline   Reply With Quote
Old 06-16-2014, 12:36 AM   #32
Good to hear! Were you able to get the strut replaced under warranty?
Old 06-16-2014, 05:27 AM   #33
Not yet but I have spoken to LMR and they told me I should be able to. Will contact them this morning to determine what the next steps are.
Old 06-16-2014, 03:34 PM   #34
I am a machine and good at what I do.
Old 07-08-2014, 10:33 AM   #35
2014oxstang's Avatar
Sorry to thread jack, but grabber, if I changed the position of the arrow pointing inwards, I wouldn't have camber issues? Arrow pointing outward was obviously in the directions.....
2014oxstang is offline   Reply With Quote
Question on Koni Str.t install Evil2014GT 2011-2014 Mustang GT 60 05-15-2015 08:07 PM
KONI STR.T VS. FRPP m-18000-a back n a stang 2011-2014 Mustang GT 1 09-16-2012 04:01 PM
front koni str.t shocks for sale tigercrazy718 Mustang Parts for Sale and Wanted 13 03-24-2011 07:51 AM
KONI STR.T + Steeda Sport springs M3hunter 2011-2014 Mustang GT 5 01-21-2011 10:39 PM
04:10 PM
