bit the bullet... bought nitrous setup! - Mustang Evolution
Old 06-07-2014, 01:00 PM   #1
fivepointwut's Avatar
Region: New Mexico
Welp... I just ordered the nitrous express coyote plate system setup from AM...
The real reason for the thread is not to brag , but to ask you more experienced nitrous people if I have forgotten anything really necessary to run a nice, clean, safe nitrous setup!
Along with the nitrous kit I also ordered:
directly related to the NX kit:
MSD window switch
NX purge kit
heat range 7 spark plugs
SCT X4 tuner
indirectly related, but supporting mods:
JLT cai
Lethal Perf off road h-pipe
IS THERE ANYTHING ELSE that you all feel I need to be running along with what I have to be as safe as possible with this kit???
Thanks guys/gals
fivepointwut is offline   Reply With Quote
Old 06-07-2014, 01:19 PM   #2
NoSlo5oH's Avatar
Add a Fuel Pressure Safety Switch and a bottle heater to your list and you'll be set.
NoSlo5oH is offline   Reply With Quote
Old 06-07-2014, 01:24 PM   #3
Region: New Mexico
Fuel pressure safety switch... hadn't heard of that one but it does make a lot of sense... Thanks
As for the heater... 1.) I live in hot *** new mexico. And 2.) I was under the impression that a bottle heater was really only needed it you'd be hitting the nitrous back to back to back to back. Because then it would get cold.
I really don't plan on beating it around town like that...
Any thoughts?
Old 06-07-2014, 01:35 PM   #4
NoSlo5oH's Avatar
Any thoughts?
It's always good to have a heater because when you make a pass or use nitrous there will be a pressure drop and the shot will be weakened. I am sure you want to get the most out of it with every use, so optimum pressure will be important. The only other way around the heater and pressure drop issues is to use a pusher system like the NANO system. I have one on my car and love it. Here's a pic of the FPSS that screws into your fuel rail adapter. You will want one that is set for 50psi.
Old 06-07-2014, 01:43 PM   #5
NoSlo5oH's Avatar
This may give you some ideas for your install.
2013 GT nitrous install pics
Old 06-07-2014, 02:17 PM   #6
Region: New Mexico
Hey good link there! I'm not too good at the search button I just ask a question cuz it's a forum for asking questions he he he
Where did you get that FPSS???
Old 06-07-2014, 02:34 PM   #7
NoSlo5oH's Avatar
I got the FPSS from Jegs.
Old 06-07-2014, 02:52 PM   #8
Region: New Mexico
Thanks a lot man! Big help
Old 06-07-2014, 11:09 PM   #9
Region: New Mexico
Did you have to buy any special fittings besides what the kit comes with from jegs???
I don't want to break the car apart just to find out that I need another fitting or two!!!
Old 06-08-2014, 12:23 AM   #10
Compstall's Avatar
You live in NM, haven't you found the TSC forum yet? ABQ is a Mustang town, if you can't get your answer there yer doin it wrong.
Sent from The Prophecy
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-08-2014, 01:15 AM   #11
Jsmorley81's Avatar
What wire did you tap into for your wot
Jsmorley81 is offline   Reply With Quote
Old 06-08-2014, 04:54 AM   #12
Region: New Mexico
O ya I'm definitely on tsc!
I like talking to people further away though and then surprising these people
ABQ is am awesome city to live in if you're into fast cars! These people have race gas in their bloodstream!
---------- Post added at 04:54 AM ---------- Previous post was at 04:53 AM ----------
I barely ordered the thing yesterday. Won't be here for a few days!
Old 06-08-2014, 06:35 AM   #13
NoSlo5oH's Avatar
You shouldn't need to, as I believe the NX kit comes with a fuel rail adapter which is the black piece that the FPSS is screwed into in the pic that I posted earlier. I used blue loctite on all of my NPT fittings instead of teflon paste.
Old 06-08-2014, 06:53 AM   #14
Region: New Mexico
True. They do state that it comes with a fuel rail adapter piece. Thanks NoSlo5oH!
What size slick did you end up getting? You had mentioned it in your other link when you chatted with Dan at AM!
Old 06-08-2014, 11:56 AM   #15
NoSlo5oH's Avatar
You're welcome fivepointwut. I have 28X12.5X15 M/T ET Streets on my car.
Old 06-08-2014, 12:06 PM   #16
Region: New Mexico
Is that on an 8 inch wheel or a 10 inch???
How are they hooking for you around the 500+ horsepower range?
Old 06-08-2014, 02:37 PM   #17
NoSlo5oH's Avatar
10" wheel and they hook really good on the street. I will be taking the car to the track for some numbers as soon as the weather allows me too. It has been raining a lot here in Kansas City.
Old 06-08-2014, 04:53 PM   #18
Region: New Mexico
Did they fit on the back without any modifications to the rear end?
Old 06-08-2014, 05:29 PM   #19
Compstall's Avatar
8's do, 10's require a modded sway bar.
- Brent
Old 06-08-2014, 07:04 PM   #20
Region: New Mexico
Thanks!!!
Old 06-08-2014, 08:24 PM   #21
NoSlo5oH's Avatar
The wheels/tires will fit with minor modifications. I started out using a BMR sway bar relocate kilt, which requires a portion of the sway bar mounting tabs to be cut off to raise the sway bar to clear a 10" wheel. The problem I encountered is; the factory sway bar slightly touched the left side of the panhard bar bracket. To fix this, I ended up removing the factory sway bar and taking it to a machine shop to have some material removed to gain the necessary clearance. I then had it sandblasted and powder coated. After all that; I still wasn't happy with the amount of clearance that I had, which was about an 1/8", so I ordered a Strano adjustable rear sway bar. I had to have the Strano brackets cut, drilled and slotted to provide proper mounting and clearance. The rear sway bar setup is perfect now. Here's an angled pic of the Strano bar installed.
Old 06-08-2014, 08:28 PM   #22
Region: New Mexico
Wow! Sounds like a lot of work just for that :-/
Makes me wanna lean towards the 8 inch wheels
Old 06-08-2014, 08:33 PM   #23
NoSlo5oH's Avatar
Here's a left side shot of the Strano sway bar. This should give you a better idea of the amount of clearance that I gained by installing this bar. BMR is also working on a similar sway bar, but no release date has been revealed yet.
Old 06-08-2014, 08:39 PM   #24
NoSlo5oH's Avatar
It was definitely was more work than I expected. Hopefully my shared experience in this area will save you from having to endure any unnecessary grief. I was on the fence about whether to get the 8's or 10's too, but I'm glad I went with the 10's.
Old 06-08-2014, 11:11 PM   #25
Region: New Mexico
It does look sexy! That big ole fatt tire out back!!!
Old 06-09-2014, 08:23 PM   #26
Region: New Mexico
hey NoSlo5oH is this the FPSS you were referring to? Or did you buy a different one?
Nitrous Express 15718 Nitrous Express Nitrous Pressure Gauge - Free Shipping on All Orders @ JEGS
this one says nitrous express nitrous pressure gauge... not fuel pressure? hhmmm
buy it will get to 50psi like you said...
"These EFI fuel pressure safety switches from Nitrous Express are designed to cut off the fuel supply if the pressure gets too low. This prevents a lean condition, which could harm your engine."
Thanks
Old 06-10-2014, 05:32 AM   #27
NoSlo5oH's Avatar
Thanks
Here's the one I bought.
http://www.jegs.com/i/Edelbrock/350/72214/10002/-1
Although the product description is off a bit on the link you posted, it appears that would also work. Keep in mind that you would have to set the pressure on that one yourself.
Old 06-10-2014, 07:18 AM   #28
Region: New Mexico
Very true! Plus yours is half the price! Think I'll go with that so I don't have to worry about adjusting the fuel pressure!
Thanks
Old 06-16-2014, 08:05 PM   #29
Region: New Mexico
Nitrous kit came in today along with my window switch and purge valve... just waiting on the FPSS...
Holy moly I'm excited now!!! Time to start ripping **** apart!
Old 06-18-2014, 04:15 PM   #30
NoSlo5oH's Avatar
Right on! Get after it and post progress pics please.
Old 06-18-2014, 07:22 PM   #31
lilediselec's Avatar
Good bite I bought the kit couple months ago with 100 shot works amazingly installed myself in couple of hrs. Works amazingly
lilediselec is offline   Reply With Quote
Old 06-18-2014, 09:16 PM   #32
Region: New Mexico
Gotta question here.....
So I'm in the middle of installing this kit. Boy Ooo boy is it cake! Good directions from NX and just all in all an easy task...
But my question is: can I drive the car normally on my NA tune from Lund now that I have installed the NX plate kit system between the intake manifold and the throttle body??????????
The plate system is about 3/8 inch thick. So I get the feeling that it is going to kind of act like a throttle body spacer?!!? Right?!!!?
Let me know what y'all think of this idea...
Old 06-18-2014, 09:19 PM   #33
Region: New Mexico
O ya and I'm asking because my tuner is out of town until June 30th. So another 10 days or so!!
So i wont be able to take it to him until then.
Old 06-18-2014, 09:21 PM   #34
Rapinator126's Avatar
I'm going to be a dick just a little on this. Is that honestly a serious question?
Yes you are 150 % fine. The plate will not change 1 thing bud.
Old 06-18-2014, 09:48 PM   #35
Region: New Mexico
Yes i was serious. Lol
I come from the forced induction side of things where the simplest change in things changes a lot of things!
Didn't know how much of a role an actual throttle body spacer performs...
Thanks though Rapinator
nitrous
Bit the bullet and got 410s Slow4V 1996-2004 Mustang GT 30 09-10-2013 09:13 PM
Ultimate Nitrous Setup Dan The Bar 13 02-18-2004 11:38 PM
Just ordered a nitrous setup MusclesFromBrussels Pre-2005 V6 Mustang 6 11-22-2003 08:37 AM
i want this nitrous setup Monkey The Bar 16 11-20-2003 08:43 PM
Sold My Nitrous setup Danger Dude The Bar 10 09-22-2003 07:52 PM
10:10 PM
