replacing wiper blades - Mustang Evolution
Old 06-07-2014, 08:28 PM   #1
Went to autozone today to upgrade my wiper blades to bosch icons,1 is 22" the other 20". It was so hot outside I asked the sales rep. to install them,says where it connects to the arm just doesn't fit like ford has a new design,was disappointed. Was wondering if anybody relaced theirs yet? And what brand did you use?2013 boss.
chefron50 is offline   Reply With Quote
Old 06-07-2014, 08:34 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I use Bosch, can't remember if they are icons though. Mine came with a couple adapters, one of which fit Ford's new wiper arm.
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 06-07-2014, 08:40 PM   #3
I think I had a lazy sales rep.So many mustang's out there , has to have some kind of adapter you think? I'm looking for someone who already made the change.
Old 06-07-2014, 08:46 PM   #4
Tyoung68's Avatar
You didnt get the oe ones did you? If not then you should be fine. Most of them just have the little J clip on it post a picture of it
Old 06-07-2014, 09:23 PM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
There are different types of wiper blades of the same size. Like a 22OE and a 22A are both 22" but have different connections, or one comes with adapters and one doesn't. I'll see if I can find the exact one I used.
Old 06-07-2014, 09:28 PM   #6
Tyoung68's Avatar
The OEs dont fit any cars iv tried to put them on almost all cars use just the regular wipers
---------- Post added at 08:28 PM ---------- Previous post was at 08:27 PM ----------
I work at an autozone btw
Old 06-07-2014, 09:34 PM   #7
Yes they were the 22oe and 20oe, didn't fit said the sales rep .
Old 06-07-2014, 10:12 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
22OE fits the top lock style wiper arms (which I believe we have) and 22A fits the hook arms according to the Bosch site's fitment guide.
Old 06-07-2014, 10:47 PM   #9
I guess I'll try it again, lazy sales rep.
Old 06-07-2014, 11:32 PM   #10
Loc: Austin,TX
I've had the same wipers for almost 4 years now. Sorry for the useless post.
Old 06-08-2014, 06:35 AM   #11
It's not useless if you want to upgrade, what is wrong with trying to verify the right blades?
Old 06-08-2014, 09:19 AM   #12
scott_0's Avatar
as said numerous times, the OE's are the ones that fit, got mine at Walmart
sent from HTC M8 using tapatalk
Old 06-08-2014, 11:07 AM   #13
Tyoung68's Avatar
Hmm weird it does say the OEs fit the car. Take one off and bring it in and they should be able to tell what kind you need
Old 06-08-2014, 01:38 PM   #14
thanks for the help,I'll let you know what happens?
Old 03-22-2015, 09:22 PM   #15
Konawin's Avatar
I try to drive my Jeep in the rain but when I get stuck in the occasional precipitation the Mustang OE wipers suck! I've got to replace my OE wipers because one skips in the middle of the arms swing and it's finally torn. I need recommendation on an upgrade, I won't replace with more OE wipers unless I've exhausted all options!
Konawin is offline   Reply With Quote
Old 03-23-2015, 04:50 AM   #16
hitmeagain's Avatar
I work In an auto parts store... Sounds like the guy didn't want to mess with the blades.... Almost all after market beam blades come with little adapters that will change to the new ford style attachment... I could have literally installed them in a matter of seconds after changing the adapters... All trico flex, trico neoform, and rain x will come with the correct adapters.
hitmeagain is offline   Reply With Quote
Old 03-23-2015, 06:10 AM   #17
Waylap1's Avatar
Region: New Hampshire
If you're into treating yourself and your Mustang...and you don't mind skipping those Monster energy drinks for a few weeks to help cover the cost.....
Subarus rally team uses these: yes, that's cost per each blade....
PIAA | 26" (650Mm) Forza Hybrid Silicone Wiper Blade #96065
Mustang would take 20 and 22" though.
Waylap1 is offline   Reply With Quote
Old 03-23-2015, 06:29 AM   #18
fenixignition's Avatar
probably had a lazy sales rep. I used to work at an autoparts store, and if i sold you wipers that didn't fit, I would still do what i can to set you up with the correct wipers, or a recommendation on where to go for the right ones. Definitely wouldn't send you off with more questions.
2002 GT 5sp. 16x,xxx miles
Old 03-23-2015, 06:32 AM   #19
you should have the I&L right? theyre a bit tricky but i have fit plenty of those. Im sure there are bosch's that fit. but theres few brands. Your usually stuck with the expensive blades for that hook. Rain-x lattitudes should have the piece, among other bands.
Old 03-23-2015, 01:46 PM   #20
Konawin's Avatar
Picked up the Rain X Latitudes this morning at Walmart. Popped them on, WAY better than OE. I guess I've got $32 invested in them - win! BTW, the little adapters came in the box, PITA to get on but...
Old 03-23-2015, 01:49 PM   #21
scott_0's Avatar
yes we have the I & L hook type, I got the Bosch Icons and love how they work, very smooth and quiet
Old 03-23-2015, 02:14 PM   #22
Compstall's Avatar
I live in the rain here in WA and have great success with the OEM blades. Almost 4 years on the stock blades and they're just now showing signs of needing replacement. Have never had any aftermarket blades last that long. Going back to the dealer for fresh ones.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Fan blades Silversky545 2005-2010 Mustang GT 13 05-07-2012 01:20 PM
Procharge z06 vs. Blades (kenne belle Cobra) Cajun JungleBoy Pictures and Videos 32 12-18-2006 11:36 AM
Wiper blades KyleUSAF Pre-2005 V6 Mustang 8 07-07-2006 11:46 PM
Mod: Lowered Wiper Blades...? WhiteStang99 Mustang Audio & Video 11 04-06-2004 04:37 PM
11:53 PM
