AED Tune...Knock Sensor - Mustang Evolution
Old 06-11-2014, 07:05 PM   #1
Has anyone had issues trying to datalog for the AED tune and getting a high reading on the knock sensor? Around 3.5 at 6800rpms?
What could be the cause for this?
tigerfan2771 is offline   Reply With Quote
Old 06-11-2014, 08:21 PM   #2
I had the same problem. Turned out to be bad 93 octane gas in my area.
DallasBoss is offline   Reply With Quote
Old 06-11-2014, 08:27 PM   #3
I tried the first time with less than a quarter tank of gas. Then I filled up with 93 and tried again and got the same results. Could it have been bad both times? Maybe I should try an octane booster?
Old 06-11-2014, 08:45 PM   #4
I tried 93 from several different companies, and all resulted in a ton of knock activity. In order to rule out the possibility of false knock readings, I mixed pump gas and Sunoco 105 race gas, which yielded great data logs. There have been several others who have had issues with bad gas. I'm on e85 now.
Old 06-12-2014, 08:21 AM   #5
Coyote5o's Avatar
Region: West Virgina
Are the knock readings (+) or (-)? Negative knock sensor readings mean it is advancing timing, whereas positive knock sensor readings mean it is retarding timing. So, negative values are Good. The positive values are the ones to watch out for. If you look back a page or two in the forum, i have a thread very similar to this.
Datalog - Knock Sensor
2013 Mustang GT w/ Track Pack - Steeda Ultralite Springs, Koni Str.t Struts/Shocks, BMR LCA & Relocation Brackets, BMR Adjustable UCA and Bracket, BMR Adjustable Panhard, DSS Aluminum Driveshaft, Bassani x-pipe and catback, MGW shifter, JLT CAI, Steeda Tune
Coyote5o is offline   Reply With Quote
Old 06-12-2014, 09:42 AM   #6
The readings are positive. Are there any good octane boosters? Lucas oil octane booster?
Old 06-12-2014, 09:57 AM   #7
Coyote5o's Avatar
Is it knocking at WOT or under partial load? I had a few positive knock values, but all were under 30% throttle (and low RPM) so I wasn't too concerned. These were a max of 1deg though. I've never used octane boosters myself, my dad swears by Torco in is procharged 04 mustang. There's a few threads on here talking about them.. most people say that they are a waste of time/money and can foul plugs and clog fuel filters. Apparently the tune needs a few degrees of timing pulled. Hopefully AED can resolve that. may be beneficial to ask for an 89 or 91 tune for the time being - then run 93oct in it..
Old 06-12-2014, 01:01 PM   #8
Compstall's Avatar
AND...thanks for saving me $50. Again.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-12-2014, 05:08 PM   #9
Thanks for your worthless posts. How about keep out of my threads dumbass
Old 06-12-2014, 05:11 PM   #10
I ended up putting in 5gal of octane 100 race fuel in it and the knock is now gone, confiming the gas was bad. I'm going to empty the tank and try a different station. The whole reason Im going through this is to get the AED tune... Im trying to avoid having to get another tune and working with BAMA on any issues.
Old 06-12-2014, 05:49 PM   #11
Coyote5o's Avatar
I've heard good things about aed. Hopefully the fuel was the only problem! I tend to stick to shell/exxon whenever possible. I just meant that it may be good to have a backup 89 tune for the instances where you get bad gas.. Program the 89 tune to prevent knocking and Reinstall the 93 once you get the good stuff again. I currently only have a steeda 93 tune and haven't had issues with bad gas, but I plan on doing just that..
Sent from my SCH-I535 using Mustang Evolution mobile app
Old 06-12-2014, 07:57 PM   #12
Compstall's Avatar
It IS worthless now, thanks to you. You the man
- Brent
Old 06-12-2014, 08:59 PM   #13
You won't necessarily notice bad gas, I didn't notice it driving. I picked it up in the process of datalogging. Your car will automatically adjust for it by adding or removing timing.
Old 06-12-2014, 09:01 PM   #14
Troll
Old 06-18-2014, 09:05 AM   #15
DallasStang77's Avatar
Compy!!! You "worthless...troll"!!! Lol try writing something useful for a change instead of spreading disharmonious misinformation ya damn troll Click image for larger version
Name:	ImageUploadedByMustang Evolution1403103866.634296.jpg
Old 06-18-2014, 10:27 AM   #16
Compstall's Avatar
Welcome to last week. I've been willing for quite a while now to give somebody out there $50, free and easy. This is factual information!
- Brent
Torn between a dyno tune or AED s1975OH 2011-2014 Mustang GT 43 12-16-2013 11:03 PM
AED E85 Lope Tune Jetag93 2011-2014 Mustang GT 14 06-10-2013 02:14 PM
Bama tune with aed cam tune? Mustang32Bill 2011-2014 Mustang GT 23 05-25-2013 06:13 AM
Does foxbodys have a knock sensor? Stang.racr 1979-1995 Mustang GT 8 07-20-2011 03:28 PM
Knock Knock *Language* Brent Pictures and Videos 3 04-03-2008 04:18 PM
03:50 PM
