Purpose of adjustable LCA's? - Mustang Evolution
Old 06-11-2014, 10:08 PM   #1
Big Q's Avatar
Region: Nebraska
I realize I need a adjustable UCA when I drop the car as well as a adjustable pan hard bar to center the rear axle. So what purpose do adjustable LCA's serve? I plan on doing the eibach pro kit so it's not a huge drop and will use the relocation brackets.
Big Q is offline   Reply With Quote
Old 06-11-2014, 11:08 PM   #2
Rynarok's Avatar
I think adjustable lowers are sorta pointless. You'll need an adjustable upper to correct pinion angle, but solid LCAs with brackets should be fine for most applications. My plan is the BMR lowers with brackets, with the JPC adjustable upper.
Added complexity isn't always a useful thing!
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 06-11-2014, 11:15 PM   #3
Tyoung68's Avatar
Adjustable LCA are for keeping your axle centered in the wheel wells i think
Old 06-11-2014, 11:40 PM   #4
Yes true, whenever you raise or lower a vehicle adjustable suspension items are used to keep unwanted stress off bushings/studs. Also keeping the axle proportions correct benefits ride quality
Sent from my C811 4G using Mustang Evolution mobile app
2010 GT Done: FR Intake Manifold-FRPP Hot Rod Cams-Granatelli 62mm TB-BBK Ceramic Longtubes-BBK Catted X-pipe To do:-One piece aluminum driveshaft-Gears-Staggered wheels when my tires are done
theonekyle is offline   Reply With Quote
Old 06-12-2014, 12:22 AM   #5
Big Q's Avatar
Region: Nebraska
Kind of what I was thinking, think I'll stick with non adjustable and do relocation brackets when I do a mild drop.
Old 06-12-2014, 09:49 PM   #6
fastJ's Avatar
I want to switch to adjustable lowers cause on my passenger side my axle is about a 1/4 inch closer to the wheel well but I think I'm just being picky
fastJ is offline   Reply With Quote
Purpose of caster/camber plates? StangerBanger04 1996-2004 Mustang GT 22 11-15-2012 11:30 AM
What is the purpose of some of the stuff they put on cars on Mtv's Pimp My Ride? searbhreathach General Mustang Discussion 4 07-23-2010 11:04 AM
A Robot Built For One Purpose *WW for ads* 04MonteSS The Bar 20 01-22-2007 11:24 AM
V6stangs.com has a new look and purpose Brent The Bar 11 01-04-2006 09:01 PM
purpose of green reputation thingies? tire The Bar 12 04-10-2004 05:12 PM
06:14 AM
