Transmission fluid swap this last weekend - Mustang Evolution
Old 06-11-2014, 10:59 PM   #1
Rynarok's Avatar
Thumbs up Transmission fluid swap this last weekend
After finally getting the missus's permission, I did a fluid swap on my MT82 this last weekend.
I did some looking - there seems to be a good split between redline, AMS, and royalpurple fluids. I went with RP Synchromax...I use RP for everything else with zero issues so I figured I'd stick with them. I also installed the whiteline transmission bushing insert.
Gotta say, I've got nothing bad to b!tch about with this trasmission anymore. The shifts are smooth and positive, I do NOT miss shifts under load, and I don't think the NVH is any worse (I'd heard the bushing insert could make things noisy). If it is more than before I wouldn't notice, my outlaws easily drown it out
I did a write up in the DIY section of the forums, if anyone wants to see what's involved with doing it.
MT82 Transmission Fluid Change
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 06-12-2014, 03:11 PM   #2
Nice write up! Going to get this done soon.
OH2014GTCS is offline   Reply With Quote
Old 06-12-2014, 07:02 PM   #3
JM7225's Avatar
Good write up and thanks! I got the tsb fluid from ford but I'm wondering if I need something more...
2015 Mustang GT Premium | MRT Catback
JM7225 is offline   Reply With Quote
Old 06-12-2014, 10:19 PM   #4
Rynarok's Avatar
I'm not sure what ford is handing out, but I'm completely satisfied with the synchromax I've used. Seriously - to fix the MT82 you need an MGW, a trans bushing insert, a fluid swap, and call it a day. Pull the clutch assist spring if you want.
Each shift is firm and positive, there is no magic 'lockout' when shifting under power, and the cold tranny chatter is all but completely eliminated. Before, this transmission was a pain in the @ss. It's a damn sight better now. It reminds me of my buddy's LS1 Formula transmission, the TR6060. Not quite as bullet proof, but that same feel and feedback when bangin' thru gears.
edit: I guess he had a T56 in those years. Still, "improved MT82 is a go hmmkay!"
AXLEBACKS THREADS =
Old 06-12-2014, 11:13 PM   #5
JM7225's Avatar
What's the trans bushing and where does this go? I didn't see it in your install post but maybe I missed it, I read through it fast. I've seen people say it helps, but what does it do?
Old 06-13-2014, 05:48 AM   #6
Big Q's Avatar
Region: Nebraska
Glad to hear you like the trans insert, have one on the way!
Big Q is offline   Reply With Quote
Old 06-13-2014, 05:50 AM   #7
Big Q's Avatar
Region: Nebraska
Google Vorschlag motorsports, search Whiteline with their search feature and scroll down the page. Pretty good info on their site. I'd post a link but I'm on my phone.
Old 06-13-2014, 07:44 AM   #8
JM7225's Avatar
Wow thanks! Going to buy one today probably. Looks cheap, easy to install, and can't hurt. I've noticed shifting while turning at ANY speed is so clunky in this transmission. Some of the sounds that this thing emits when you don't shift perfectly make me feel like the tranny is falling apart.
Old 06-13-2014, 08:06 AM   #9
Rynarok's Avatar
The transmission bushing insert goes into the transmission mount - the main bushing that keeps the transmission centered under the car. During high load, the transmission can slightly shift or torque...making that 1-2nd or 2-3rd shift more difficult, because the shift linkage doesn't exactly align if the transmission is torqued outta alignment. The bushing simply firms up the support from the mount - thus, not allowing the transmission to move so far out of alignment under load that shifting becomes a problem.
The downside is increased NVH. I haven't really noticed much of a difference...others have. It's worth mentioning that I'm running flowmaster outlaws and I'm soon to be catless with an H-pipe. With all of that other sound and vibration present I think it's unlikely that I'd feel a bit more from the transmission.
For like 35 bucks though, its a good improvement for the MT82. Here's a link to the bushing on AM
----edit---
I didn't cover the install of the bushing in my fluid swap DIY post. The bushing install is super simple - literally 4 bolts holding the brace in place, and two bolts holding the bushing assembly together. Support the transmission before loosening the bolts with a bottle jack or something. Torque the big bolts to 47ft/lbs when reinstalling...it's honestly a 15minute job, and easier than most other jobs are. I coated the bushing in some leftover grease that came with my ENERGY suspension bushings for good measure - not going to risk an annoying squeak coming from it.
AXLEBACKS THREADS =
Old 06-14-2014, 08:10 AM   #10
JM7225's Avatar
Does it cure the crackling that happens when shifting from 1 to 2 while turning? I believe that's from the torque shift when pressing in the clutch, but I'm not sure. This sound also can happen sometimes when I'm in 1st gear and slowing down to park and I press in the clutch. It doesn't happen when I'm careful with giving the car a little bit of gas while pressing in the clutch...
Old 06-15-2014, 09:36 AM   #11
Rynarok's Avatar
I think what you mean by cracking is maybe what I'm calling transmission chatter? You should still hear the gears engage/disengage...or you might be hearing the flywheel contacting the clutch plate.
Iunno, how does it feel to shift? notchy? vague? Does it fight you going into gears? I see you are already rocking an mgw - seriously try the fluid swap and the trans bushing. You can feasibly do both for under $120 bucks and an afternoon's worth of garage work.
AXLEBACKS THREADS =
Old 06-15-2014, 09:11 PM   #12
JM7225's Avatar
I think the chatter I'm hearing is the gears disengaging. If you don't shift perfectly, sometimes you can hear the gears chattering because of the torque difference. Usually happens to me in lower gears (1 to 2 shift). I've got the bushing on order so I'll see how it is after I put it in, thanks!
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
Fun Ford Weekend at Maple Grove Raceway near Reading PA this Weekend Aug 16-17-18 Spiney General Mustang Discussion 0 08-13-2013 01:06 AM
Fun Ford Weekend this weekend (June 14-15) 9tee7pony General Mustang Discussion 0 06-13-2013 06:36 AM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Baton Rouge area: Who's going to fun ford weekend this weekend? PureVenom Regional Mustang Discussion 9 05-22-2008 06:55 PM
02:04 AM
