water leak 2014 GT - Mustang Evolution
Old 06-14-2014, 07:05 AM   #1
water leak 2014 GT
wet floor mat drivers side. water was leaking from around the upper left brake pedal assembly mounting bolt, facing front.
wildwolf is offline   Reply With Quote
Old 06-14-2014, 09:06 AM   #2
I thought I had a water leak for the longest time from the same spot. Turned out it was just the water coming off my shoes when I would get into the car. I was positive it was a leak bc it happened every time the car got wet. I also have rubber floor mats so the water is much more noticeable than if there was carpet.
To test get a water house and point it at the base of the windshield. Get a friend to hold the hose and crawl inside to see where the water is coming from. Some people have had water leaks from the lower windshield not being sealed completely. In my research I didn't find much else info. Doesn't seem to be a common issue at all. Good luck!
SecretAgent is offline   Reply With Quote
Old 06-14-2014, 09:12 AM   #3
Region: New Mexico
There are 2 drains from the cowl under the wipers. They drain out behind each head on the firewall. They are soft rubber. You can reach with your hand (engine cold) and clear them with your finger.
califsp is offline   Reply With Quote
Old 06-14-2014, 09:30 AM   #4
SixBanger's Avatar
Condensation drips from the AC condenser in that exact spot. Have you been using your AC a lot?
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 06-14-2014, 09:34 AM   #5
GrabberMeBlue's Avatar
I don't think either the cowl drains or the AC condenser should be dripping inside the car, only outside.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 06-14-2014, 09:35 AM   #6
My 2013GT did the same thing while it was parked at work and it rained. Did it once and never happened again.
Drag737 is offline   Reply With Quote
Old 06-14-2014, 02:20 PM   #7
Getn off's Avatar
Did u remove the sound tube? That is about where the hole in the firewall is. Maybe the grommet fell out, or was never installed when removing the tube?!
Troy
Getn off is offline   Reply With Quote
Old 06-14-2014, 07:07 PM   #8
I wonder what is on the upper side of that bolt as it goes in straight up from inside under the dash and where by the windshield it would emerge.
« Stripes | Brakes »
Water Leak on Drivers side LLinoRR14 2011-2014 Mustang GT 4 01-12-2014 07:02 PM
Water Leak ThatsCoolBro 2005-2010 V6 Mustang 8 11-27-2013 10:30 AM
Water Leak Kick Panel Area ThatsCoolBro 2005-2010 V6 Mustang 1 04-06-2013 11:20 PM
Anyone have a water leak? Mandy4 2011-2014 Mustang GT 48 08-25-2012 03:44 PM
Water leak! Pete08GT 2005-2010 Mustang GT 19 04-16-2011 01:50 PM
10:15 PM
