2014 Mustang GT Engine Check Light On - Mustang Evolution
Old 06-17-2014, 04:59 PM   #1
Hello All,
Engine check light came on yesterday during my regular commute from work to home. I went to Advance Auto Parts to get a read on the code and the guy told me its due to Incorrect Air/Fuel Ratio.
I do not know why this issue came up suddenly.
I have upgraded Flowmaster oultlaw Axle back. Will my warranty cover the fix for A/F ratio issue with my Flowmaster AB on the car?
Any suggestion is appreciated!!
Note: I went through the forum to find similar issues, but I could not find A/F ratio issue.
2014 GT w/ Flowmaster AB
arcelius is offline   Reply With Quote
Old 06-17-2014, 05:04 PM   #2
Rapinator126's Avatar
Is the axle back the only thing done to the car? No tune or anything?
Old 06-17-2014, 05:14 PM   #3
Yup, thats the only thing done. Besides wheels and tires.
Old 06-17-2014, 05:18 PM   #4
Did it start running different when the light came on?
Old 06-17-2014, 05:28 PM   #5
I did not feel anything noticeable, it drove the same way.
I did not drive much after it came on, probably 10-15 miles.
Old 06-17-2014, 05:29 PM   #6
It could be a few things. All the way as simple as a exhaust leak. Best bet is to bring it to the dealer. The stock tunes are known to run lean also.
Old 06-17-2014, 05:44 PM   #7
Thanks, thats the only thing I can think of too. But the only question that I have would be - Will the axle back cause any issues (warranty) since it is related to A/F ratio? (Would there be a chance of dealer not looking at it under warranty)
I wonder if anyone else had similar issue/experience.
---------- Post added at 07:44 PM ---------- Previous post was at 07:44 PM ----------
Old 06-17-2014, 05:46 PM   #8
No a axle back will not void your warr8
---------- Post added at 06:46 PM ---------- Previous post was at 06:46 PM ----------
* warranty
Old 06-17-2014, 06:38 PM   #9
Hellish Horse's Avatar
If not an Exhaust Leak I would bet it's a faulty 02 sensor. Just cause the car is new doesn't mean the part isn't defective. When they told you it was the air/fuel ratio ...did they tell you in what bank? If you have the code look it up & see what bank it's in & change that sensor. The code will tell you Bank #1,2,3 or 4. But since it's under warranty you may as well take it to the dealership if it's not to far & you have the time to wait for it.
Hellish Horse is offline   Reply With Quote
Old 06-17-2014, 06:43 PM   #10
Oh...It could also be a Dirty MAF Sensor. There's a small wire between 2 prongs (like in a light bulb) & when it gets dirty it will also throw that code. I clean mine by soaking the wires only in paint thinner over night & then clean it off gently with a Q-Tip & Rubbing Alcohol. Re-install & good as new. Don't worry...Paint thinner doesn't melt plastic.
Old 06-17-2014, 07:03 PM   #11
Thanks! I think I should take it to the dealer. And I know my whole day will probably be gone there
And hope won't have to deal with any warranty conditions, etc...
2014 mustang
2014 GT Check Engine Light jlesp2013 2011-2014 Mustang GT 18 08-27-2013 08:01 AM
My check engine light came on my 1996 Mustang GT? orlando67 1996-2004 Mustang GT 2 12-13-2011 05:10 PM
I have a 96 Mustang and my check engine light keeps coming on.? walthari81 General Mustang Discussion 7 03-17-2010 08:59 AM
2002 Ford Mustang 3.8L check engine light help!!? evian General Mustang Discussion 4 03-04-2010 10:50 AM
10:22 PM
