1st Time at Dyno | 91 Oct Pump Gas Tune - Mustang Evolution
Old 06-18-2014, 09:36 PM   #1
Hulk 5.0's Avatar
Yeah so after installing some bolt ons it was time for Hulk to hit the dyno. (Dynojet)
Mod list is on my signature; overall im happy with the numbers and most importantly the great tune and how it feels. Best was 419whp & 356wtq. I did thought that my wtq was going to be higher.
Also.. I had code p300 before the dyno run. Sparkplugs? Im thinking about changing em.. What do you guys recommend or are running?
ID:	159553Click image for larger version
ID:	159554Click image for larger version
Gotta Have It Green GT 2013 | Recaro | Brembo | Track | 3.73 Rear End | Boss 302 Intake Manifold -Dynatech Long Tube Headers - Magnaflow Full Exhaust & Tru X Pipe 3 - JLT Intake- SCT 91 Tune - BMR Pan Hard Bar - SR Performance Sway Bar Kit - Steeda Strut Bar - MGW Shifter Kit - Hankook RS3 275 Rear - Hawk HPS Brake Pads - Roush Front Lip & Roush Full Side Skirts
Hulk 5.0 is offline   Reply With Quote
Old 06-18-2014, 10:52 PM   #2
Torque is definitely low for that number. Some more aggressive negative timing on the exhaust cam should bring that number up significantly. I made 405/400 with just a tune and intake, but on 93 octane. So you should be able to squeeze out at least 390ft lbs.
As for the spark plug question, I swear by NGK iridiums. Burn clean, strong spark, and last a long time. Work with na, nitrous (some people will disagree), and with forced induction (with the right temp range of course). Also they're usually cheaper than the boutique plugs like brisk, et al.
SecretAgent is offline   Reply With Quote
Sat. Oct. 1st-2nd Annual Cruise-In @ McClary Ford Dealership 4DRACN Regional Mustang Discussion 0 09-23-2011 10:35 AM
Mustang Show on Oct. 1st in Athens, AL 4DRACN Regional Mustang Discussion 0 09-16-2011 01:53 PM
Sat. Oct. 1st All Ford & Mustang Show!! 4DRACN Regional Mustang Discussion 2 08-22-2011 02:36 PM
Sat. Oct. 1st Mustang Show in Athens, AL 4DRACN Regional Mustang Discussion 0 07-09-2011 06:14 PM
Cookout/Meet on Friday Oct. 1st in Augusta, GA fast64 The Bar 9 09-21-2004 04:49 PM
06:59 AM
