Stock brake fluid - Mustang Evolution
Old 06-19-2014, 04:06 PM   #1
Stock brake fluid
Just a quick question, what is the stock brake fluid in the 2013 mustang gt? I am going to install the stainless clutch line and need to buy some more to refill. So dot 3/4 or what? Thanks.
Kjdjr18 is offline   Reply With Quote
Old 06-19-2014, 04:55 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It should say it right on the cap. If not, it's definitely on your owner's manual
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 06-19-2014, 05:06 PM   #3
Ok I checked the owners manual but didn't see. I will feel dumb by looking at the cap lol. Thanks though.
Old 06-19-2014, 06:36 PM   #4
nhcowboy's Avatar
Search harder...
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 06-19-2014, 06:45 PM   #5
Son of a gun. I'm gonna go check the manual again now. Thank you for the pic. Any dot 3 should work right? I'm gonna eventually go to dot 4 but not now.
Old 06-19-2014, 06:59 PM   #6
nhcowboy's Avatar
No problem. Yes any dot 3.
I download the manual (PDF) to my phone. Makes finding stuff easier since you can keyword search.
You can get it off the owners ford site.
12.538 ET @112.33
Old 06-19-2014, 07:06 PM   #7
That's a darn good idea! I found it after you showed me too. Time to go download I guess. Thanks again. Finally got the bottom clip off!
Old 06-20-2014, 08:04 AM   #8
Compstall's Avatar
Going from 3 to 4 is not an upgrade
Sent from The Prophecy
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-21-2014, 07:00 AM   #9
Dot 3, 4, and 5.1 are pretty much all cross compatible. Dot 5 is something different (silicone based) and is not compatible with glycol based fluids.
As others have said Dot 4 is not an upgrade. The most important thing you can do is just keep the fluid fresh. Fresh dot 3 is better then old dot 4, and it doesn't take long for brake fluid to absorb water, so yearly changes are a good idea and more often if you take the car to a road course. For a daily driven vehicle every 2 years is fine unless specified sooner by the owners manual.
Refreshing the reservoir every oil change is a decent way to prolong fluid life but is not a replacement for occasionally bleeding the system.
BadCon is offline   Reply With Quote
Old 06-21-2014, 07:24 AM   #10
Don't be dumb
Use DOT 3
Why would you even think about going to dot 4?
The page you were looking for is in the manual.
The stainless steel lines are a great improvement and well worth the money and time to install them. Your gonna love them.
Old 06-21-2014, 10:23 AM   #11
AJcruz1's Avatar
Whats wrong with using DOT 4?
AJcruz1 is offline   Reply With Quote
Old 06-21-2014, 11:44 AM   #12
Compstall's Avatar
4 is bitter, 3 makes a better mohito.
Sent from Tom Cruise
- Brent
Old 06-21-2014, 12:02 PM   #13
Abominable Mustang
WhoDat's Avatar
Region: Alaska
There's nothing wrong with it; there's just really no benefit in using DOT 4 unless your car is constantly on the track and braking a lot. DOT 4 has a higher boiling point than DOT 3.
Old 06-21-2014, 03:37 PM   #14
I learned this
Dot 4 will take more heat but is will also collect moisture faster.
Dot 3 works well for street driving and really only needs to be changed about once every two years.
Dot 4 should be change more often when using it where Dot 3 is the fluid of choice mainly for normal street driving.
Dot 3 is less corrosive to the system.
If your not tracking your car every weekend and don't need unwanted maintenance just stick with the Dot 3.
Old 06-22-2014, 06:57 PM   #15
ddtmoto's Avatar
Region: Utah
Fresh brake fluid is not corrosive. DOT3 or 4 is good. I only use dot4. It's the contaminants in old fluid that harms internals. The key is to flush brake/clutch fluid before it is full of junk. If your fluid is darker than honey it is past time to flush it out with fresh. Not good to mix brands.
ddtmoto is offline   Reply With Quote
Old 06-22-2014, 08:48 PM   #16
AJcruz1's Avatar
Stock brake fluid
This is what I always thought. Don't see why DOT 4 is not being recommended as I have never heard what some of you say about it. I use Motul Dot 4 fluid.
Old 06-22-2014, 10:23 PM   #17
Compstall's Avatar
Check out this cool article I just found.
http://www.torquebrakefluid.com/abc.html
Sent from Midas
- Brent
Old 06-23-2014, 06:11 AM   #18
EXCELLENT
I'm thinking with our street cars and not changing brake fluid often it is best to use DOT 3.
Why?
Because DOT 4 is less HYDROSCOPIC which means it absorbs moisture a tad more then DOT 3.
That artical said it all. http://www.torquebrakefluid.com/abc.html
The Manuals say's DOT 3 and why argue with the Mustang MANUAL ???????
Old 06-23-2014, 06:17 AM   #19
bucko's Avatar
Another thing to remember on brake fluid is to not use it from a container that has sat on your shelf (once opened) over 6 months. It can easily obsorb moisture from the air, contaiminating it.
I flush my brake fluid once a year using a power bleeder. I've never had to replace a caliper or rebuild one.
Old 06-23-2014, 06:58 AM   #20
AJcruz1's Avatar
Sent from Midas
Good read!
Old 06-29-2014, 06:56 AM   #21
gdcracing's Avatar
I am incredibly anal about preventative maintenance on my car. It's a lot easier though when I'm a technician at a dealer and have all the tools and a lift. I drain and fill the reservoir every other week with a newly opened bottle and then once every 3-4 months perform a full flush. Only takes 10 minutes and if I have extra bottles on hand, why not?
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Mark Donohue
"You might think that's not cricket, and it's not, it's motor racing"
"Finishing second means you are the first person to lose"
gdcracing is offline   Reply With Quote
Old 06-29-2014, 09:27 AM   #22
DUH !!!!!!!!!
WHY NOT ???
Because it just ain't necessary. Once a year is fine. Once every two years is OK.
Now if your auto X-ing or tracking your car it is different. But for a street car. "NOT NECESSARY"
That is why not.
Old 06-29-2014, 10:45 AM   #23
gdcracing's Avatar
WHY NOT ???
That is why not.
lol no believe me I understand that but like I said it's free. I can't stand the discoloring of the fluid or the reservoir. It takes me a whopping 1 minute to grab the brake bleeder, drain the reservoir and fill it back up. Just helps keep the fluid diluted with new fluid. Then every few months bleed the calipers.
Old 06-29-2014, 04:01 PM   #24
Compstall's Avatar
Time isn't free
Sent from the Clock
- Brent
Old 06-29-2014, 04:25 PM   #25
Just a big total waste of resources.
You are just wasting brake fluid.
How often do you change your oil?
Anti freeze coolant?
Air in your tires?
Windshield washer fluid?
Bulbs?
I'm just wondering. I don't mean to be nosy but I sure am curious. It's just that I have never ever heard of changing the brake fluid that often. Especially just in the reservoir. Not even on a race car do they do that. All the race car owners I have been around drained the system after a few races if they used the brakes enough to get them overly hot. I did this myself.
Old 06-29-2014, 05:26 PM   #26
if you are hard enough on your brakes to warrant steel lines, than you should upgrade your fluid as well, go with a motul or Ate, that way you wont have to worry about boiling your stock fluid
rwheels is offline   Reply With Quote
Old 06-29-2014, 08:02 PM   #27
ddtmoto's Avatar
Region: Utah
What is the boiling points of ATE and Motul?
Old 06-29-2014, 08:16 PM   #28
Compstall's Avatar
Look it up fool
- Brent
Old 06-29-2014, 08:27 PM   #29
Compstall is a very friendly person
I think he said to ddtmoto:
LOOK IT UP FOOL
Wow, A nice friendly answer to a legitimate question.
Old 06-30-2014, 12:57 AM   #30
I apologize for this war I have started. Lol. Stainless line is in dot 3 replaced and even added the whiteline mount. All is good!
Old 06-30-2014, 02:59 AM   #31
J
Just under 600 degrees I believe for both.
Old 06-30-2014, 03:08 AM   #32
gdcracing's Avatar
No, time isn't free but if you can't slow down to relax and you're so worried about 1 minute, you're doing something wrong. lol. anyways, coolant will be changed once a year including when I put my boss mani on i will just go ahead and drain and fill it. Oil gets changed every 3 to 4k miles. Yes I know these things have a computer. It can last 15k blah blah blah I have my reasons for doing this. tires get checked with bulbs at least once a month when I bring it in and check it over for everything. fluid leaks and the like. I fill the washer reservoir as needed if I happen to notice it needs some. Don't really use the sprayer though.
Yes, it may be a bit excessive. I don't really care. To each his own. This is my first new car. I've worked my *** off like a lot of people here to have decent cars since I started driving. I still remember the look on my parents face when I was able to get a loan and a decent warehouse job when I turned 18 to get myself a 99 E36 M3. beautiful car. I'm 24 now and have a freakin 14 gt/cs. I would like to take care of it as much as I can. It may be a waste to you. Not to me.
Old 06-30-2014, 04:47 AM   #33
audioAl's Avatar
Dang! what thread. I want steel lines myself when I can afford them.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 06-30-2014, 10:11 AM   #34
DallasStang77's Avatar
+1 do as you please it is your car after all. People have as much right to tell you what you should or should not do with your car as much as they have a right to tell you how much toilet paper to use when you wipe your ***.
Old 06-30-2014, 10:14 AM   #35
gdcracing's Avatar
Bwahahaha! Awesome
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Still dripping some brake fluid WhiteStang99 Pre-2005 V6 Mustang 19 06-21-2005 07:00 PM
Getting brake fluid on... MonteCitan The Bar 8 03-26-2005 09:50 PM
11:54 AM
