Camshafts? - Mustang Evolution
Old 06-20-2014, 06:28 PM   #1
Joaquin_ii's Avatar
Camshafts?
So a couple questions here. I just recently bought headers and x pipe and saw that in order to have stage 3 cans for comp cams I neede LT headers and gears.. However I've never seen any other type of cams are those the only cams for a 2011 5.0 or is there another website that I can find those? Second I've heard they don't lope but saw a post saying they have a ghost tune. What is a ghost tune?
Joaquin_ii is offline   Reply With Quote
Old 06-20-2014, 06:32 PM   #2
Compstall's Avatar
Ghost tune is very difficult to see.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-20-2014, 06:46 PM   #3
Joaquin_ii's Avatar
I see what you did there lol
Old 06-20-2014, 06:59 PM   #4
Rapinator126's Avatar
Only way to get them to lope is to disable the VCT and delete the phasers and add lockouts.
Comp make cams
Jpc does re grinds
L&M has cams
Mmr has cams
And with your basic mod list I would not worry about cams. There is alot more you can do first.
And if you still have the stock intake manifold the stage 3's will be useless
Rapinator126 is online now   Reply With Quote
Old 06-20-2014, 07:02 PM   #5
Joaquin_ii's Avatar
There is still more I'm adding to my list. Boss manifold is next after gears followed by cat back. I didn't mention above but I Also have CAI and tune.
---------- Post added at 08:02 PM ---------- Previous post was at 08:01 PM ----------
Thank you by the way
Old 06-20-2014, 07:03 PM   #6
How high do you plan on spinning it with the boss? What tune?
---------- Post added at 08:03 PM ---------- Previous post was at 08:03 PM ----------
Suspension also
Old 06-21-2014, 07:39 AM   #7
DallasStang77's Avatar
Camshafts?
Don't bother with the Boss manifold. Here's a sample of what people debated with me about why I shouldn't have gotten mine:
Them: You don't make power
Me: Yes you do. You make power well past the 6500rpm power drop off with a stock manifold.
Them: You gotta spin to 7500/7600 to really see any useful power gains.
Me: That's bull cuz I see power gains after 6500!
They failed to bring the following point up and I will do you a solid: The Boss manifold effectively shifts your power bandwidth up about 1000 RPMs so that unless you shift at 7500 you will find yourself about 500-1000 below your power sweet spot thus effectively make you slower or about just as fast as with a stock manifold unless you shift 7500.
The car was more fun to drive with the stock manifold because I spend most of my time around 3-4000rpm which is 500-1000 below the new powerband spot.
It could be the tune but my car does feel slower at 3000rpm than it did before.
Old 06-21-2014, 10:42 AM   #8
My Redline is 8k sees it everyday. Also don't listen to bama about there 60 hp gain with boss and a tune not going to happen.
Boss can either make or brake your build.
Old 06-21-2014, 11:01 AM   #9
Paradone's Avatar
cams
All the ready to buy camshafts are junk other people might think different but truth is they are crap not a damn one of them for 11-14 if you want cams get a custom grind done by people who know what they are doing.
Paradone is offline   Reply With Quote
Old 06-21-2014, 11:26 AM   #10
Yeah OP honestly the Boss intake manifold was the worst upgrade I've done so far
Old 06-21-2014, 12:02 PM   #11
Custom grinds are always the way to go, and most places charge the same for that as regular off the shelf cams.
Old 06-21-2014, 12:30 PM   #12
Joaquin_ii's Avatar
This is all great input thank you so much!
---------- Post added at 01:30 PM ---------- Previous post was at 01:29 PM ----------
As for custom cams do I have to choose the duration? Lift and all or do they do it according to my needs?
Old 06-21-2014, 12:32 PM   #13
It was perfect for Me bc it's the way my motor is set up.
I do not recommend 8k in a stock motor
Old 06-21-2014, 02:41 PM   #14
Camshafts?
Yes. Rap's got forged up internals so he's safe to spin up to the heights of heaven. I don't so even tho my rev limits is set at 7500 I shift by 7-7100 and that still leaves me a good 400-500 below power spot to accelerating at the most optimal.
I would go somewhat the route of Rap if you got the money. He's using a real safe route in terms of building his car except for the fact that he's trying to intentionally shatter his manual trans right now to a million pieces so that he can buy an auto lol.
Edit: I just remembered an important piece of info that probably affected my build. I'm running 3.31 gears. If you have 3.73 or 4.10 then you will be better off than me I would think.
Old 06-21-2014, 03:52 PM   #15
I have 4.10's. But the rest of your build has to be setup for them. I ran with 3.31's b4 I swapped to 4.10's.
Lol yes a auto soon or maybe the magnum XL.
Old 06-21-2014, 04:03 PM   #16
Magnum XL
Old 06-21-2014, 04:08 PM   #17
Magnum XL
http://www.jpcracing.com/tremec-magn...wheel-options/
---------- Post added at 05:08 PM ---------- Previous post was at 05:07 PM ----------
Yes sir
Old 06-21-2014, 07:45 PM   #18
Compstall's Avatar
Turbo tree fitty
- Brent
2005-2009 Comp Mutha Thumpr camshafts. Graham1992 Mustang Parts for Sale and Wanted 12 12-02-2012 10:50 AM
anyone install FR Camshafts? redfire 2005-2010 Mustang GT 15 10-12-2012 11:55 AM
2011 V6 Camshafts?? ChrisMustangs 2011-2014 V6 Mustang 14 09-30-2012 11:49 AM
Camshafts?! tea84 2011-2014 Mustang GT 9 02-06-2012 06:49 PM
O4 3.9 v6 mustang camshafts? Zebs5408 Pre-2005 V6 Mustang 2 10-04-2009 01:54 PM
06:05 PM
