Whiteline tranny insert - Mustang Evolution
Old 06-20-2014, 09:13 PM   #1
Jgrummz's Avatar
So i just installed the whiteline tranny insert and took my car for a short spin and it seems like its a little bit harder to put it into gear now. Its not horrible but seems a little harder then before. I have a brand new 14 GT with 500 mi on it btw.
Is this normal? Or could i have managed to screw something up on this simple install lol. I deff hear a little more noise from the tranny now but that was expected. Thanks for any help!
Jgrummz is offline   Reply With Quote
Old 06-20-2014, 09:18 PM   #2
NoSlo5oH's Avatar
Did you install it from the front side of the tranny mount? I've heard of a few people installing them from the rear.
NoSlo5oH is offline   Reply With Quote
Old 06-20-2014, 09:30 PM   #3
Jgrummz's Avatar
Umm i installed it on the side that is closest to the rear of the car. Is this correct?
Old 06-20-2014, 09:38 PM   #4
Jgrummz's Avatar
Oh wow i just watched the cj pony parts video on it and im pretty sure i installed it on the wrong side lol now i feel like a dumbass! Looks like i will be doing this over again tomorrow!
Old 06-21-2014, 05:39 AM   #5
NoSlo5oH's Avatar
Lol! I was just about to send you a link to the CJ Pony Parts video, but I see you've already found it.
Old 06-21-2014, 06:50 AM   #6
I'm not sure what if any difference there would be about installing from the front or rear. When I installed mine the factory bushing was the same on either side and so was the cross member.
BadCon is offline   Reply With Quote
Old 06-21-2014, 09:09 AM   #7
Jgrummz's Avatar
So do you think it will make a difference? I think ill switch it anyway to see it the shifting gets a little smoother
Old 06-21-2014, 09:20 AM   #8
Rynarok's Avatar
It firmed up my gear engagement a small amount. Mostly it just made it damn near impossible to miss that 2nd-3rd shift at WOT.
What other shifter/transmission mods have you done?
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 06-21-2014, 09:23 AM   #9
Jgrummz's Avatar
Just this tranny insert so far. Ive only had the car for about a week. Next will be the barton bracket and a fluid swap tho
Old 06-21-2014, 09:26 AM   #10
Rynarok's Avatar
I'd withhold judgment on the trans bushing until you've done everything else. If you are still missing 2-3rd, then the bushing isn't doing it's job somehow.
Highly recommend the MGW over other shifter set ups. It's one of those things where you most certainly get what you pay for. I've heard ok things about the Barton, too....but the MGW is in a class of it's own.
AXLEBACKS THREADS =
Old 06-21-2014, 10:33 AM   #11
Rapinator126's Avatar
Barton = shortest throw available.
Old 06-21-2014, 07:18 PM   #12
Jgrummz's Avatar
So what would you guys recommend... Get the barton bracket or mgw?
Old 06-21-2014, 07:49 PM   #13
pss3286's Avatar
I recently installed a shifter bushing from aftermarketsuspensionparts.com. It was under 20 dollars and was worth every penny. Car shifts much better. Click image for larger version
Name:	ImageUploadedByMustang Evolution1403401766.300081.jpg
pss3286 is offline   Reply With Quote
Old 06-21-2014, 07:51 PM   #14
pss3286's Avatar
New bushing is on the left.
Old 06-21-2014, 07:53 PM   #15
NoSlo5oH's Avatar
The Barton two post bracket, Whiteline bushing and stock shifter with polyurethane motor mounts works really well for me. These mods really firmed up the driveline.
Old 06-21-2014, 11:36 PM   #16
JM7225's Avatar
Shortest throw doesn't mean best shifter.
2015 Mustang GT Premium | MRT Catback
JM7225 is offline   Reply With Quote
Old 06-21-2014, 11:38 PM   #17
DallasStang77's Avatar
It does if you know how to shift. I've never missed a stock shift my life. Control ur butterflies
Old 06-22-2014, 08:20 AM   #18
Never had one issue with it. No reason to buy a mgw. Also what is gear lockout??????? :////// hahah
Old 06-22-2014, 09:29 AM   #19
Big Q's Avatar
Region: Nebraska
MGW replaces the stock lower box as well for the same money as the Barton and the machining is the nicest quality you will find.
Big Q is offline   Reply With Quote
Old 06-22-2014, 09:42 AM   #20
Paradone's Avatar
Shifter
I have had MGW and Barton both, currently running a Barton shifter it is my personal preference between the two I do not knock either one but just my preference turned out to be the Barton, zero issues to date in past I had no issues with either.
Paradone is offline   Reply With Quote
Old 07-17-2014, 07:50 PM   #21
Region: New Hampshire
Just installed my MGW today. What an astonishing change in performance. This should have been my first mod. Crisp, quick and positive shifting. I can now rip through the gears quickly and accurately.
I also have a modified Whiteline Trans Mount. I removed the center section to make the NVH acceptable. In my car, with the center section in place, the sound and vibration coming up through the chassis was ridiculous for anything but a track car. Now it is fine and still improved performance.
The stock shifter is garbage.
todcp is offline   Reply With Quote
Old 07-18-2014, 08:36 AM   #22
Region: Wyoming
Have the Hurst shifter great shifter only complaint is reverse and 1 are way to close to each other but you get the hang of it..... it's I believe a 37% reduction
r_neck7 is offline   Reply With Quote
Old 07-18-2014, 05:36 PM   #23
SSTHIS's Avatar
What he said , I should have adjusted the set screw a little more than what they set it at , but I am not taking it back out to do it. Other than that I love the shifter
Sent from my XT1080 using Mustang Evolution mobile app
SSTHIS is offline   Reply With Quote
Old 07-31-2014, 06:33 PM   #24
SSTHIS's Avatar
Scratch that this thing is starting to get annoying, It won't shift into 2nd at high rpm its like it locks it out, 3rd 4th 5th 6th all fine. Installed the white line bushing today and that didn't help. Think I'm gonna yank it out and get a mgw.
Old 07-31-2014, 09:56 PM   #25
Replace the clutch with a McLeod and very light peddle and no gear lockout
chefron50 is offline   Reply With Quote
Old 08-01-2014, 12:00 PM   #26
Coyote5o's Avatar
Region: West Virgina
getting locked out of 2nd at high rpm isnt necessarily specific to the shifter - i have an MGW and still have lock-out issues. I think it has more to do with the clutch not fully disengaging.
2013 Mustang GT w/ Track Pack - Steeda Ultralite Springs, Koni Str.t Struts/Shocks, BMR LCA & Relocation Brackets, BMR Adjustable UCA and Bracket, BMR Adjustable Panhard, DSS Aluminum Driveshaft, Bassani x-pipe and catback, MGW shifter, JLT CAI, Steeda Tune
Coyote5o is offline   Reply With Quote
Old 08-03-2014, 01:56 AM   #27
Dhillbarn's Avatar
Any pics on the mod to the whiteline? I'm about to install one and would rather not have the vibration.
Dhillbarn is offline   Reply With Quote
Old 08-03-2014, 10:38 AM   #28
SSTHIS's Avatar
OK well if that's the case then everyone would be buying clutches for the 2nd to 3rd issue and not shifters or better bushings, I didn't have this issue before I put it in.
I'm starting to think its me and the ergonomics of the shifter. I have it like this pics in the instructions have it on where to mount the handle since they didn't tell me where too. And in this position it is off center which is why I think when I'm going to second under high rpm I'm pulling it towards me a little and not straight back. Anyway just my opinion.
Old 08-03-2014, 10:50 AM   #29
Said it b4.
Whiteline mount
Stainless clutch line
Assist spring removal
Shifter/ bracket
Fluid swap.
I ran the stock clutch past 600 at the tires. No issues shifting at 7900 at all
Old 08-03-2014, 02:54 PM   #30
Coyote5o's Avatar
I don't think there's an issue with the clutch itself.. Just the components that disengage it. Everyone replaces the stock shifter because it's a piece of ****. I agree with rapinator, it's a combo of upgrades that is going to fix it. I don't care if you continue to waste money on shifters, I'll still sleep at night. I have the whiteline mount, MGW shifter, and removed the clutch assist spring and it still will lock out. Just saying, it may not be the shifter causing the issues.
Whiteline Transmission Mount Bushing insert???? 2014GT 2011-2014 Mustang GT 16 05-30-2014 04:37 AM
Whiteline watts link group buy? HPFury 2011-2014 Mustang GT 7 10-31-2013 12:27 PM
Whiteline relo's Mikeyt03 2011-2014 Mustang GT 13 07-02-2013 07:41 AM
Anyone have whiteline LCA Relocation brackets on Schram1 2011-2014 V6 Mustang 0 02-01-2013 12:21 PM
Whiteline anti-dive kits mmike87 2011-2014 Mustang GT 0 11-28-2012 06:48 PM
08:52 PM
