Relocation Brackets question - Mustang Evolution
Old 06-22-2014, 03:45 AM   #1
I have BMR relocation bracket and BMR Non adj LCAand Adj Panhard bar,I'm also on lowering springs about 1.5 drop all around.Right now I have it set at the lowest hole on the brackets,but I'm wondering is this correct.Not rlly sure what I'd be looking for to know if I could benefit from moving them up to the middle or keeping them where they are.Which hole is mostly recommended.
2012 Kona Blue Metallic GT,6spd,3.73's,MGW Shifter,H&R lowering springs,BMR Panhard Bar,BMR Rear LCA,BMR relocaton brackets,Roush Axlebacks
BigBlue5.0 is offline   Reply With Quote
Old 06-22-2014, 06:19 AM   #2
Grabber Blue5.0's Avatar
On street tires I assume? Definitely not the lowest hole. It will hit the tires way to hard in that hole. Start with the top hole and if you're control arms are level that's where you should be. But remember what works for one person may not for someone else. Trial and error.
Old 06-22-2014, 06:21 AM   #3
I have a similar setup, (1.5" front/2" rear drop). Kelly @ BMR recommended the middle hole on the brackets for me.
Current Mustang: '14 GT/Track Pack/6spd-sold
Previous Mustangs: '68 Coupe, '73 Mach 1, '89 GT,
Hoss is offline   Reply With Quote
Old 06-22-2014, 06:23 AM   #4
With a 2" drop in the rear then yes the middle hole would be where you would want to start. But his car is only lowered 1.5" in the rear.
Old 06-22-2014, 06:46 AM   #5
vik912's Avatar
I've got a 1.5" drop all around as well , and the middle hole is what seems to work the best for me.
2013 Mustang GT
Premium, Brembo Brake Package, 6 MT, 3.73 gears
vik912 is offline   Reply With Quote
Old 06-22-2014, 11:01 AM   #6
gtstyles2's Avatar
Well I read all over that top hole is for stock height, middle is for moderate drop (1.5" is perfect for that), and bottom is for 2" or lower. As long as the LCA is in a horizontal position while on a load
Old 06-22-2014, 06:58 PM   #7
Getn off's Avatar
Yep, middle here is perfect on mine.
Troy
---------- Post added at 08:58 PM ---------- Previous post was at 08:57 PM ----------
Troy
Getn off is offline   Reply With Quote
Old 06-23-2014, 01:49 AM   #8
I went middle hole too
chefron50 is offline   Reply With Quote
Old 06-23-2014, 01:49 AM   #9
Damnit when I did mine we went with the lowest one lol,I'm gonna give it a shot in the middle.
Installed LCA relocation brackets BaSohol 2005-2010 Mustang GT 8 07-10-2013 07:25 PM
Why you need LCA relocation brackets when your lowered nosympathy 2011-2014 Mustang GT 8 05-07-2013 04:30 AM
Anyone have whiteline LCA Relocation brackets on Schram1 2011-2014 V6 Mustang 0 02-01-2013 12:21 PM
Relocation brackets BCS06GT 2005-2010 Mustang GT 12 05-21-2012 11:18 AM
LCA Relocation Brackets M3to5.0 2011-2014 Mustang GT 14 11-15-2011 03:01 PM
10:23 PM
