Suspension questions - Mustang Evolution
Old 06-23-2014, 11:20 PM   #1
Ntbruncie's Avatar
Ok so when lowering a 2014 gt 1.5" is it necessary to change the upper rear control rod? And how big of a difference it it to change the lower rear rods? Thanks
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Ntbruncie is offline   Reply With Quote
Old 06-23-2014, 11:43 PM   #2
Big Q's Avatar
Region: Nebraska
Are you referring to upper and lower control arms?
Big Q is offline   Reply With Quote
Old 06-23-2014, 11:44 PM   #3
Ntbruncie's Avatar
Yes the rears
Old 06-24-2014, 03:47 AM   #4
Grabber Blue5.0's Avatar
There's only one upper control arm.
Old 06-24-2014, 04:00 AM   #5
Big Q's Avatar
Region: Nebraska
Adjustable rear upper control arm let's you reset your pinion angle, when you lower the car you change that geometry so if it was me I would get an adjustable upper. As for lowers many use relocation brackets, I've never used adjustable lowers so someone else would have to chime in on that one.
Old 06-24-2014, 06:00 AM   #6
Coyote5o's Avatar
Region: West Virgina
An adjustable upper control arm is recommended to fix the pinion angle - it also helps significantly with wheel hop. Most people, including myself, go with relocation brackets for the lowers (and non-adjustable Aftermarket lower control arms). Also, remember to get an adjustable panhard bar to re-center the rear axle and to get an alignment once everything is complete and settled. Ideally, shocks/struts would be replaced as well. This is dependent on how stiff the new springs are and how low you plan to go - 1.5" drop is sort of a grey area of whether shocks and struts are needed. It can go either way. Some people have no problems and some people do. I would recommend BMR for just about all of these parts (although i use Steeda springs). To do it right, lowering a car takes much more than just lowering springs.
2013 Mustang GT w/ Track Pack - Steeda Ultralite Springs, Koni Str.t Struts/Shocks, BMR LCA & Relocation Brackets, BMR Adjustable UCA and Bracket, BMR Adjustable Panhard, DSS Aluminum Driveshaft, Bassani x-pipe and catback, MGW shifter, JLT CAI, Steeda Tune
Coyote5o is offline   Reply With Quote
Old 06-24-2014, 09:52 AM   #7
tj@steeda's Avatar
It is not necessary & Coyote5o summed it up.
It all depends on your budget & what you are looking to do with the car ... do you plan on tracking? There is a certain sweet spot when it comes to lowering ... our springs won't go past a 1.5" drop because then you start getting into changes in the geometry of the suspension.
At the very least ... you will need the panhard bar when lowering the car. The rear tends to shift upon lowering these vehicles.
IF you would like ... send me an email to tim@steeda.com & we can look at your budget with install & put a package together to meet your goals & make your car a better handling car.
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 06-24-2014, 12:38 PM   #8
Paradone's Avatar
it does depend on your setup/options and parts you choose to use I dropped 1.5" and did not use or need an UCA, I did install all new FR springs and dampners/struts and strut mount. Adjustable LCA's and relocation brackets, panhardbar brace and panhard bar no wheel hop nota zero and pinion angle was set to spec.
Paradone is offline   Reply With Quote
Suspension Questions fadedsoldier 2011-2014 V6 Mustang 2 07-03-2012 06:27 AM
suspension questions taylor98gt 1996-2004 Mustang GT 15 04-16-2012 06:55 PM
front suspension questions white98gt 1996-2004 Mustang GT 3 12-13-2010 08:20 AM
Suspension questions?????? CC plates? Panhard bar? Camaro Eater Pre-2005 V6 Mustang 4 07-02-2010 09:47 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
12:51 AM
