Installing Panhard Bar - Mustang Evolution
Old 06-26-2014, 07:12 PM   #1
Looks like my driver side wheel is slightly shifted outward after lowering my car. Im looking into an adjustable panhard bar, probably bmr.
My question is, does the car need to be jacked up to remove and install the new panhard bar? Or can this be done with the car on the floor? The way my carport is, I have a steep slope on one end...I was able to install the Roush chin no problem without jacking it up. Can I do the same for the panhard?
tigerfan2771 is offline   Reply With Quote
Old 06-26-2014, 07:19 PM   #2
Yea you can put in the Panhard bar on the ground. That's how I did mine.
Old 06-26-2014, 07:30 PM   #3
Ok, Ive seen some say that the suspension cant be under load when installing, but figured this wasnt the case in this situation.
Old 06-26-2014, 08:21 PM   #4
As long as the axle is centered when you put it on you will be good
Old 06-26-2014, 08:24 PM   #5
Well it's currently sitting about 3/16'' to the driver side, but I was told adjustments are made after its installed and set on the ground.
Old 06-26-2014, 08:28 PM   #6
Compstall's Avatar
I ordered a Scott Drake bar from Summit Racing on the 15th but haven't gotten any shipping notification yet, just says, "processing". I ordered LCA brackets same day from LMR and they were at the door in 4 days.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-26-2014, 08:39 PM   #7
Cool story bro
Old 06-26-2014, 10:38 PM   #8
Compstall's Avatar
I know
- Brent
Old 06-27-2014, 12:59 AM   #9
Xedes's Avatar
My ph was adjusted when I did the alignment (which I highly recommend). I was about the same as you, 3/4" towards the driver side.
Sent from my pay phone using Mustang Evolution
Xedes is offline   Reply With Quote
Old 06-30-2014, 12:35 PM   #10
Compstall's Avatar
Just found out that Scott Drake doesn't make a pan hard rod for 11-14 Stangs. Just cancelled with Summit.
- Brent
Old 06-30-2014, 03:23 PM   #11
08Mustang's Avatar
Anybody know the proper way to adjust the J&M steel rod? I'm confused lol
08Mustang is offline   Reply With Quote
Old 06-30-2014, 03:26 PM   #12
13BKV6's Avatar
can you update us once you do the install? i'll be installing a panhard bar soon on my V6, and curious as to if i need to get it on a lift or if it can be done on ground, or with jack stands...
Current: 2015 GT Premium Performance Package-stock for now
Past: 13 V6, 11 MCA V6, 89 GT, 88 GT, 04 V6
13BKV6 is offline   Reply With Quote
Old 06-30-2014, 03:31 PM   #13
08Mustang's Avatar
All mine will be done with jack stands in the garge. It'll be a couple weeks til install. I gotta get rear shocks and LCAs still
Old 06-30-2014, 03:54 PM   #14
Grabber Blue5.0's Avatar
It can be done on the ground because it's the body that's being adjusted, not the suspension.
Old 07-03-2014, 02:24 PM   #15
would you guys say a PH bar is a necessity when lowering the car? Or can install a lowering kit and buy an aftermarket PH bar when ready?
mattk08 is offline   Reply With Quote
Old 07-03-2014, 02:40 PM   #16
nhcowboy's Avatar
Depends...
On how much drop there is and if. It bothers you.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 07-03-2014, 02:40 PM   #17
If you want your rear axle to be kicked out to one side some while driving, skip the PH bar. As for ke, whenever I have the money, I will get a PH bar with springs.
Old 07-03-2014, 02:45 PM   #18
Originally Posted by nhcowboy View Post
Depends...
I just bought the eibach pro system plus. so changing the springs/shocks/struts all at the same time. Should lower the car about 1.5".
Old 07-03-2014, 02:53 PM   #19
PHB needs to be done same time, otherwise your axle will be further to one side than the other.
Old 07-03-2014, 02:55 PM   #20
ok, thanks guys
Old 07-03-2014, 03:36 PM   #21
DallasStang77's Avatar
PHB is like the third cheapest mod you can do at $120. Other than maybe camber bolts and a shift knob. Maybe a shift bracket too. Well also emblems.
Ok maybe the fifth cheapest lol
Old 07-03-2014, 06:01 PM   #22
Stangholio's Avatar
6th. You forgot plasti dip
Stangholio is offline   Reply With Quote
Old 07-04-2014, 07:01 AM   #23
Would like to see some pictures to of the install will be doing this in a month or to when I lower the car
droptopstang201 is offline   Reply With Quote
Good Aftermarket Panhard Bar? Skinsfan6 2005-2010 Mustang GT 7 03-05-2010 10:07 AM
rear sway, or panhard bar? A5295 1979-1995 Mustang GT 12 07-16-2007 08:05 AM
panhard bar eagle05 1979-1995 Mustang GT 12 07-09-2007 08:03 AM
Will a MM Rear Swaybar work in junction with the MM Panhard bar? MustangMatt Pre-2005 V6 Mustang 8 02-02-2005 04:28 PM
Panhard Bar Question njstang97 Pre-2005 V6 Mustang 6 11-07-2004 11:31 PM
05:33 AM
