Help with caster camber plates! - Mustang Evolution
Old 06-28-2014, 05:46 AM   #1
Mustang32Bill's Avatar
I just got maximum motor sports caster camber plates, does anyone have them? How are they? How's the install?
Mustang32Bill is offline   Reply With Quote
Old 06-28-2014, 07:17 AM   #2
Paradone's Avatar
Kinda Vague
What year is your car and what are you doing with them? Lowering your car? Installing them just because? What are your intentions?
Paradone is offline   Reply With Quote
Old 06-28-2014, 08:23 AM   #3
Deerslayer's Avatar
Yes, we have them. Install is pretty straight forward. Just make sure you seat everything properly and in the right order that the diagrams show.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 06-28-2014, 08:35 AM   #4
How long did it take to install? Did you get it aligned after?
Old 06-28-2014, 08:49 PM   #5
2014 I put smaller tires on and now my tires are getting chopped so I'm installing them so I can get it aligned.
Old 06-29-2014, 04:04 AM   #6
they are great plates, the hardest part of the install for me, was not breaking the rubber bands that hold it all together while installing, other than that its easy. Definitely take it in for an alignment, preferably at a performance shop that know what caster/camber/toe adjustments should be. I have found that most alignment shops only know how to keep things at factory settings.
rwheels is offline   Reply With Quote
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Caster/Camber Plates...will they be a problem with this? Joel5.0 1979-1995 Mustang GT 4 10-22-2005 04:36 PM
Steeda Springs - Do I need caster camber plates? audioqueso Pre-2005 V6 Mustang 8 12-05-2003 05:34 PM
01:11 PM
