3.55 vs 3.73 - Mustang Evolution
Old 06-28-2014, 08:35 AM   #1
Big Q's Avatar
Region: Nebraska
3.55 vs 3.73
I know I know, another gearing thread. Have a 2014 6 speed with the stock 3.31's and really cant decide which ratio I want to go with. Car accelerates well but not as well as my last 3.73 car and I rarely use 6th gear. I've heard most really like the 3.55's for a DD, my car is a nice weather driver but doesn't get driven in the winter. Current mods are AED tune,JLT CAI and waiting on my Kooks 1 3/4 long tubes to arrive. Originally I was going to keep the 3.31's in anticipation of going turbo but with building a house the reality of that is the Helion TT is probably a few years off so considering building a NA instead. Only downfall is when I had a 3.73 car 1st gear was pretty short and hard to get to hook up but the car wanted to bog a little leaving in 2nd during spirited driving.
Big Q is offline   Reply With Quote
Old 06-28-2014, 08:41 AM   #2
gdcracing's Avatar
go 4.10 and never look back.
and honestly, you have a 3.31. why would you even consider wasting money on a 3.55. Not even that big of a difference. just saying.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Mark Donohue
"You might think that's not cricket, and it's not, it's motor racing"
"Finishing second means you are the first person to lose"
gdcracing is offline   Reply With Quote
Old 06-28-2014, 08:53 AM   #3
Big Q's Avatar
Region: Nebraska
3.55 vs 3.73
Considered 4.10's, occasionally travel a couple hundred miles to some car shows so wasn't sure if they would be to much on the interstate running 75.
Old 06-28-2014, 10:15 AM   #4
gdcracing's Avatar
itll be a little over 2300 rpms. not that big of a deal. promise. and cruising speeds youll get pretty much the same mpg. just a lot more fun around town though. lol. if not at least the 3.73. the 3.55 is a waste. promise.
Old 06-28-2014, 10:17 AM   #5
Rapinator126's Avatar
4.10's here 650 ish at the tires
@80 I'm about 2700 -2800 rpms in 6th
Old 06-28-2014, 10:18 AM   #6
305/35/19 tire.
Old 06-28-2014, 10:21 AM   #7
No issues either. 8000 Redline so I can still use first.
Old 06-28-2014, 10:57 AM   #8
Region: West Virgina
I wondered myself what the rpm would be with 4.10's. That's 1000 more than I run at that speed with the 3.31's. What is you highway mpg? I get 29 on the highway here in wv with the mountains. If I were in flatlands like texas I would get more.
2013 Gotta Have It Green Gt, stock with American thunder axle backs, 6-speed
Green5.0 is offline   Reply With Quote
Old 06-28-2014, 11:02 AM   #9
14-16 mpg on highway. My car runs on e85 and is far from stock motor/ fuel system. Mpg is not what I intended my car for
Old 06-28-2014, 11:14 AM   #10
Subbed, I've been thinking about doing gears as well but don't want to sacrifice much in the mpg department as I'll be doing a lot of highway driving
2011 Mustang GT Premium
So. Many. Mods....
Colin1337 is offline   Reply With Quote
Old 06-28-2014, 11:46 AM   #11
gdcracing's Avatar
I get 25-26 on 4.10's 275/40-19 intake and tune. I DD my car so I care about mileage but I have plenty of room to play with so I'm not worried about it for now. My 05 mini i had running 21 psi supercharged. little quick ****er but no top end due to small displacement. 21 mpg. lol. get something much faster and 3 times the engine and im getting better with mods. still laughing about it.
Old 06-28-2014, 12:12 PM   #12
Big Q's Avatar
Region: Nebraska
I'll be running E85 as well once my tester kit arrives here in the next week. Sounds like 4.10's might work pretty well. Do you have a boss or upgraded to spin to 8000 reliably?
Old 06-28-2014, 12:13 PM   #13
No boss, i have Fully forged motor.
Old 06-28-2014, 12:20 PM   #14
Big Q's Avatar
Region: Nebraska
Which block did you go with?
Old 06-28-2014, 12:22 PM   #15
Stock block is good for 900 ish.
Stock crank is good for 1000
I did Manley H beams
Diamond pistons
All ARP hardware
Ported heads.
11.5 compression vs 11.1 stock
Old 06-28-2014, 12:23 PM   #16
My stock motor took a **** at 611 at the tires. Pistons 4 and 6
Old 06-28-2014, 12:26 PM   #17
Big Q's Avatar
Region: Nebraska
Diamond pistons
All ARP hardware
Ported heads.
Interesting, thought the stock block was only good for around 700 or so. NA build maybe sooner than later then
Old 06-28-2014, 12:29 PM   #18
Plenty of people pushing upwards off 900 on stock block.
Old 06-28-2014, 12:31 PM   #19
I will be at 850+ here by the end of this year
Old 06-28-2014, 01:06 PM   #20
Big Q's Avatar
Region: Nebraska
Did you use a local performance shop for your build or online shop?
Old 06-28-2014, 01:19 PM   #21
Local shop. Lethal performance in new braunfels/ San atonio TX.
Old 06-28-2014, 05:31 PM   #22
Cdgardner1's Avatar
Might be a stupid question but does anyone know how to decipher the manufacturer sticker on my 2013 mustang GT to know what rear end I'm running with. I'm 99.9 percent sure a 3.35 because I only have a deluxe but not a premium but I've heard of ppl getting 3.55 gears in a deluxe package. Thanks.
Cdgardner1 is offline   Reply With Quote
Old 06-28-2014, 05:32 PM   #23
There is a sticker on the pumpkin. Crawl under the car and you will see it bud
Old 06-28-2014, 05:33 PM   #24
Cdgardner1's Avatar
Thanks bud
Old 06-28-2014, 05:35 PM   #25
Thanks bud
No problem. It will be easy to spot
Old 06-28-2014, 05:35 PM   #26
Big Q's Avatar
Region: Nebraska
Also says it on the door sticker, I believe DD is 3.31 have to google if it's another code.
Old 06-28-2014, 05:36 PM   #27
Big Q's Avatar
Region: Nebraska
Ahhhhh, no local shops here that I'd trust.
Old 06-28-2014, 05:37 PM   #28
Cdgardner1's Avatar
The only sticker on my rear end says 3.31. So I guess that's it thanks bud.
Old 06-28-2014, 05:44 PM   #29
They have done my car from the ground up and have some of the fastest cars around. Including a 1900 rwhp z06 out here. Twin 76mm turbos and e85
---------- Post added at 06:44 PM ---------- Previous post was at 06:44 PM ----------
That would be the one. I had 3.31's for awhile
Old 06-29-2014, 04:09 PM   #30
Compstall's Avatar
Maybe around Texas, but we all know the fastest cars in the country come from Oklahoma.
Sent from my iPad using Tapatalk HD
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-29-2014, 04:35 PM   #31
Lmao yes I 4 got about that hahahahah
they have some of the behind the scenes footage from when they went out there.
Old 06-29-2014, 05:03 PM   #32
DallasStang77's Avatar
Yes that's because the measure the speed of acceleration off a cliff... No car from texas or anywhere else for that matter can beat that lol
Old 06-29-2014, 06:34 PM   #33
Voltwings's Avatar
I think there was some misunderstanding here, Stock internals =/= stock block. Rap means the physical block, I believe you were asking about the engine internals being rated to ~700 or so, which is true.
Old 06-29-2014, 11:46 PM   #34
Getn off's Avatar
Fyi...I drive 25k per year all freeway. Limit is 70. Driving 80, I get 21-22 mpg at 2450 rpm. At 70 i get 24-25 mpg and can't recall rpms as I rarely go that slow!
This is from my '14 Track pack with 3.73s.
Troy
Getn off is offline   Reply With Quote
Old 06-30-2014, 05:52 PM   #35
elkk's Avatar
I have a 2014 GT 6 speed with 3.73 and and they are perfect for a DD. Often times start from a stop in second gear, but then I am not a racer..my 2 cents.
2014 GT / Ruby Red / MT82 / 3.73 / RR Sensing & Security
Mods: GT500 Axlebacks, Modest Pin Stripe, Side Scoops, Wheel Spinners, Lower Fog Lights, Strut Tower Brace, Chrome Shift Knob
elkk is offline   Reply With Quote
05:29 PM
