Tire stretch? - Mustang Evolution
Old 06-29-2014, 06:36 PM   #1
Tire stretch?
Hi all, my tires are P245/45 ZR 19
They are currently on 19x8.5 premium aluminum wheels, I was looking into 19x10 wheels so they would stick outa little farther, to give more of an aggressive look. Would my wheels now be able to be stretched onto 19x10s without the tires looking oddly thin from being stretched out?
(If not, would offset give me this wider look im looking for? I dont want to use wheel spacers)
2011BlueGT is offline   Reply With Quote
Old 06-29-2014, 10:33 PM   #2
DallasStang77's Avatar
Don't try to put 245 on 10" wheels. Horrible
Old 06-29-2014, 10:41 PM   #3
Ok, how couldI go about making my wheels stick out wider without going the wheel spacer route? And hopefully not having to buy new tires
Old 06-29-2014, 10:51 PM   #4
HPFury's Avatar
Buy longer wheel studs and spacers. Cheapest and safest route.
Whiteline
Ford Racing
Steeda
Hurst
Boss
Mtx
Hotchkis
Roush
BAMA
Spohn
HPFury is offline   Reply With Quote
Old 06-29-2014, 11:27 PM   #5
Safest route is actually fatter wider tires on wider rims.
For 10" wide rims you need minimum 275/35/xx tires. Even 275 maybe a bite narrow and result in less than optimal lateral handling.
Tires handle their best when the side wall is perpendicular to the ground. When you stretch a tire it will lean inward thereby not offering the rigid support for handling.
You drive a mustang. It needs treads beefy enough to put the power down.
Just go wider tires on wider rims and be safe and be done with.
Old 06-30-2014, 08:38 AM   #6
HPFury's Avatar
+1 if you have the coin for new wheels & tires
Whiteline
Ford Racing
Steeda
Hurst
Boss
Mtx
Hotchkis
Roush
BAMA
Spohn
Biggest rear tire size on 18" tire ChrisMustangs Mustang Wheels & Tires 6 06-24-2013 02:46 PM
tire questions for the tire guru's strictly180 2011-2014 Mustang GT 13 06-13-2012 09:00 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Tire Sizes Laser02 Mustang Wheels & Tires 26 01-10-2004 12:22 AM
FLAT TIRE! maverik The Bar 10 07-27-2003 10:26 AM
04:41 AM
