Instant center? - Mustang Evolution
Old 07-03-2014, 07:47 AM   #1
2014oxstang's Avatar
Instant center?
Hey guys, I'm getting ready to lower my car. I'm tryin to get a definitive answer on where I should be placing my BMR UCA bracket, and my BMR LCA relocation brackets once lowered. Anybody have some insight on this? I've done a bit of research and everything leads to top hole of UCA bracket, and middle hole of LCA bracket for daily driving, which is what the intended purpose will be with the occasional drag strip action. Thanks in advance bros.
Eric,
2014oxstang is offline   Reply With Quote
Old 07-03-2014, 11:57 AM   #2
LuisBlackGT's Avatar
If your asking if you should replace the UCA because ur lowering the car, yes. Do you have to? No. How low are you lowering the car?
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 07-03-2014, 12:06 PM   #3
I already have the UCA and bracket. What I'm asking is if I should lower the UCA to the lower hole BECAUSE it's lowered. It's getting lowered on konis's, with springs, and strut mounts.
Old 07-07-2014, 08:08 AM   #4
Voltwings's Avatar
I have no input on the UCA, but i believe you are correct on the LCA. It has been a while since i spoke with Kelly, so you may want to double check this on your own, but from what i understood, you basically wanted to lower the LCA "double" what you lowered the car.
For example, the first hole is 2" lower than stock, second is 3", last is 4" (i believe, again, may want to check on your own).
So if i lowered my car 1", i would use the first hole which is "double," or 2" down. If i lowered 2" id want the last hole or, or "souble," which is 4" down.
At the end of the day though, you either want them parallel, or at a slight downward angle towards the axle. The higher the angle towards the axle, the more stress you put on the tires, so the stickier tire you will need. Kelly can explain it MUCH better than i just did, so id recommend giving them a call.
Old 07-07-2014, 08:18 AM   #5
I have the LCA's in the middle hole, that is what's recommended for my drop. The angle is ever so slightly pointing up towards the axle.
Old 07-07-2014, 03:52 PM   #6
Paradone's Avatar
dropped mine 1 1/2" all way around used LCA relocation brackets middle hole and adjustable LCA's no wheel hop at all pinion angle was set no issues to date. I did install panhardbar brace and adj panhard bar. Did not touch the UCA at all.
Paradone is offline   Reply With Quote
Old 07-07-2014, 07:10 PM   #7
The Blue Dragon
GrabberBlue5.0's Avatar
Yes, top hole for uca and top or middle hole for relocation brackets. The bottom holes on both of these are for hardcore use and 96% of people should not use them.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-07-2014, 07:27 PM   #8
Lol 96% percent. So specific lol. I got a slight camber issue up front. Going to let the springs settle a bit and get an alignment.
Got my new center caps today!! 01mineralgrey6 Mustang Wheels & Tires 10 03-11-2004 06:45 PM
has anyone tried to cut and redo their center console? tire Mustang Audio & Video 10 02-22-2004 09:12 PM
Brent and I's Instant message convo: Rellik The Bar 24 10-17-2003 12:30 PM
» Members Mustangs
Bella
dmunoz
Shelby
Bgover
Add your Mustang
08:13 AM
