OK guys maybe y'all can help me out.....recently I got some door light projectors and wired them to the mycolor lights on the side of my door they would work for about 30 seconds then trip out to the default green well I thought the Mycolor system didn't have enough power to run the ambient lights with the projectors so I disconnected the projectors and the ambient door lights won't revert back to blue they stayed the default green......anytime I change the color with any type of blue such as ice blue or regular blue they revert to default green now that's my first problem second problem is I decided to try and wire the projector lights to the map lights figuring they should have a lot more power in the circuit to run the projectors and I hooked them up to the light circuit and one of the projectors is very bright the other one was dim which didn't make any sense because the factory power wire to the lights splices to each bulb so I decided to disconnect them entirely. Now the second problem when I open my doors my map lights on the driver and passenger will not come on automatically any more but the driver side will come on if the button is pressed and now the passenger side will only come on if I press and hold the button in? Any ideas ?
