Oil change - Mustang Evolution
Old 07-06-2014, 05:32 PM   #1
Subtle stang14's Avatar
Oil change
Hey guys,
I did my oil change earlier last year, i also put in a new filter but now recently i have been looking at my oil and it says it's at 13%. So i decide to go to autozone and buy 5 quartz of mobil 1 (used it last oil change). When i got home i filled my car and then let it sit. I turned it on later to see what my oil % was at but it still sits at 13%... Anyone know the problem?
Subtle stang14 is offline   Reply With Quote
Old 07-06-2014, 05:34 PM   #2
It's a manual reset...
Old 07-06-2014, 08:21 PM   #3
DallasStang77's Avatar
Originally Posted by Subtle stang14 View Post
Hey guys,
You did drain your old oil before you put the new in right...
Old 07-06-2014, 08:22 PM   #4
I hope he did...
Old 07-06-2014, 08:26 PM   #5
I hope he did...
I don't think he did. The 5.0 takes 8.5 quartz... 13% might not mean it only has 3-4 quartz left. He might have topped it off too much.
OMG I hope he did just go hope and dump 5 quartz in without checking his oil level lol
Old 07-06-2014, 08:29 PM   #6
JoeyM91's Avatar
Yeah as they said, you have to manually reset it. The Info button If I remember till you see Oil Life, then the Reset button to the right. I never use the damn thing, I just keep track of the mileage and check it occasionally.
That indicator is Oil Life, not the amount left. You check that with your dipstick.
Old 07-07-2014, 06:34 AM   #7
GT need 8.5 or 8 qts of oil? I got my change done recently and they put only 8. I will have to check the level again..
libis22 is offline   Reply With Quote
Old 07-07-2014, 06:55 AM   #8
olds442111's Avatar
Send a message via AIM to olds442111
8 always fills mine up
White 2014 GT Premium / Blower / Auto Trans / Louisiana
Blue 2016 Sport FX4 Crewcab / Blower coming soon
olds442111 is offline   Reply With Quote
Old 07-07-2014, 07:00 AM   #9
KARgt13's Avatar
R.I.P. to your engine. 13% is the oil life, not how much oil is in the car.
KARgt13 is offline   Reply With Quote
Old 07-07-2014, 09:08 AM   #10
That's right!! it's oil life indicator not level..
But how come your GT took another 5 qts of oil? Didn't you check the oil level with the stick?
Best thing is to take it a service center and get your oil changed. I don't think new oil mixed with old is a good idea!
Old 07-07-2014, 01:02 PM   #11
scott_0's Avatar
omg! come on man!!! if you're unsure about these things ask before dumping oil on the pan, where is the oil level on the dip stick reading after you added the 5qts?
sent from HTC M8 using tapatalk
Old 07-07-2014, 01:44 PM   #12
I'm pretty sure he drained out the old oil.
He did say he put a new filter on so I'm pretty sure he did not just poor 5 quarts of oil into his crankcase.
He is just asking how to reset the Gage to zero.
He says he has a GT so he should have put in eight quarts and after reading this he probably went back and got three more quarts.
He is probably young and needs to learn to read the manual or ask someone that knows before jumping in to do some things he wants to do his self.
Old 07-07-2014, 02:44 PM   #13
Nope he said he changed his oil like earlier last year. That's when he changed his filter also.
Old 07-07-2014, 02:46 PM   #14
Uh ohhhh... He hasn't chimed in since his first post... I think... Bad news 😣
Old 07-07-2014, 02:54 PM   #15
Probably grenaded the engine.
Old 07-07-2014, 03:36 PM   #16
Paradone's Avatar
Oil Change
I hope it all worked out and hated to see this post, on the flip side it was a good laugh and at least now you know its oil life indicator the level will always be determined by your dipstick.
Paradone is offline   Reply With Quote
Old 07-07-2014, 09:37 PM   #17
Yes... My dipstick never failed to let me know when the engine is well lubed 😊
Old 07-07-2014, 09:58 PM   #18
lol wouldn't 2 much oil just cause pressure and pop seals?
he probably did the math and added what he thought was the difference in the 13%
TurboCobra is offline   Reply With Quote
Old 07-08-2014, 12:20 AM   #19
Yes... My dipstick never failed to let me know when the engine is... ummmm... well lubed 😊
Old 07-23-2014, 03:00 AM   #20
Noodles76's Avatar
Guess we'll never know the end result of this story....
2014 5.OHHHHHH
Noodles76 is offline   Reply With Quote
Old 07-23-2014, 04:00 AM   #21
Abominable Mustang
WhoDat's Avatar
Region: Alaska
2014 5.OHHHHHH
Yeah. Too bad. I was curious as to how things turned out.
2012 Kona Blue 3.7L V6:
Old 07-23-2014, 04:38 AM   #22
bucko's Avatar
For new car owners, I still think its a good idea to read through the owners manual. It explains how the oil life percentage reading works, as well as how much oil to add/use during an oil change.
Old 07-23-2014, 04:43 AM   #23
Noodles76's Avatar
Originally Posted by bucko View Post
Can you blame him for not reporting back? Came here for some help, and received a whole lot less!
You make a valid point but some tried to help
2014 5.OHHHHHH
Old 07-23-2014, 04:50 AM   #24
bucko's Avatar
2014 5.OHHHHHH
I've been guilty of this as well, but I make myself think back to my first time ownership of a car (old enough for it to be a model A; just joking, it was a 64 Beetle) and how nieve I was with all the maintenance.
Old 07-23-2014, 08:24 AM   #25
2014 5.OHHHHHH
I sorta tried to help but he never came back to clarify his actions. So it all became speculative.
I hope everything is fine but the 5.0 isn't an oil slurping rotary. Even at 13% life there's gonna be a helluva lot more than three quarts of oil left.
Old 07-23-2014, 12:10 PM   #26
Noodles76's Avatar
Ya hopefully his lack of return is because the vehicle is now in working order.
2014 5.OHHHHHH
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Oil change....... cagedthought Pre-2005 V6 Mustang 24 10-04-2003 12:35 PM
Oil Change problems 94sexystang Pre-2005 V6 Mustang 20 09-30-2003 10:14 PM
08:51 AM
