Cats - Mustang Evolution
Old 07-10-2014, 11:09 AM   #1
Barraza43's Avatar
Cats
Is it possible to remove the bolt on the cat for the passenger side by using a hand tool? Or would I have to get a power tool?
Barraza43 is offline   Reply With Quote
Old 07-10-2014, 11:24 AM   #2
REG
Cats
You can get a both bolts from the top.
You will need a 15 mm socket, deepwell, preferably a six point, a 1/2 universal joint, a 1/2 20 in extension, 1/2 inch ratchet with cheater or a 1/2 inch breaker bar.
Disconnect the battery and remove the battery and battery tray and that will give you a nice line of sight to both nuts. Soak the living $hi# out of them with penetrating oil and go for it.
They will be tight all the way out as the threads are cut to not allow them to back off.
Good luck, I broke one of the studs when I did it, so be careful!
I was and it still broke!
Good Luck!
REG is offline   Reply With Quote
xpipe... cats, no cats, *scratches head* A5295 1979-1995 Mustang GT 33 03-07-2017 01:41 AM
Cats vs no cats Dtibbz22 1979-1995 Mustang GT 8 08-10-2012 08:26 AM
Cats or no Cats tlarson3249 Pre-2005 V6 Mustang 16 03-23-2012 05:55 PM
From cats to no cats Jmeo 2005-2010 Mustang GT 29 05-17-2011 08:57 AM
Cats or no cats that is the question StreetRacer4371 1979-1995 Mustang GT 34 01-14-2011 09:07 AM
10:38 PM
