Suspension question. - Mustang Evolution
Old 07-10-2014, 10:57 PM   #1
Region: Nevada
Ok, I have been following a number of suspension threads for a bit and I have a question. Why does it seem like everything is oriented toward progressive rate springs for performance applications?
Progressive rate springs make my head hurt when you try to match linear damping forces to them. To say nothing of roll and pitch calculations as the suspension dynamics change under load, weigh shift, and linear and lateral acceleration.
I am just not seeing how this is a performance advantage in any way as it introduces an unnecessary dynamic variable into a system that cannot account for it. Without being able to match damping forces in real time like some of the active suspension systems, it is clear that the system is going to be over or under damped except for the single point where the progressive spring rate and the damping compression and rebound are matched.
Can someone fill me in on why this is advantageous over a matched linear rate spring and damper setup?
-Static
Static_LV is offline   Reply With Quote
Suspension question... D00DIEBR0WN Pre-2005 V6 Mustang 10 10-13-2009 05:03 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Front Suspension Question 00vertstang Pre-2005 V6 Mustang 2 09-29-2006 10:55 AM
suspension question horess05 Pre-2005 V6 Mustang 11 05-21-2004 07:10 PM
Suspension question GoIn2Shock Pre-2005 V6 Mustang 3 01-13-2004 02:33 PM
12:25 PM
