Widest rear tire - Mustang Evolution
Old 07-11-2014, 12:26 AM   #1
dapope's Avatar
Widest rear tire
Ok guys, I'm looking at getting a set of wheels for my 2014 base gt. I want to know how wide I can go with stock suspension. I'm ok with going down to a 15 inch wheel, if I did, would I be able to go 15x10 or wider? Also would I be able to go with a 315 on the back without any rubbing?
Sent from my SM-G900T using Mustang Evolution mobile app
dapope is offline   Reply With Quote
Old 07-11-2014, 03:50 AM   #2
Grabber Blue5.0's Avatar
A 15"x10" wheel requires sway bar relocation brackets should you go that route.
Old 07-11-2014, 06:28 AM   #3
NoSlo5oH's Avatar
I have 15X10 wheels with 28X12.5X15 tires on my 2013 GT and there is at least an inch of clearance between the inner sidewall and bump stop brackets. I was running a sway bar relocate kit, but still had a slight clearance problem, so I ended up buying a Strano adjustable rear sway bar. I had the Strano brackets modified and clearance is perfect now.
NoSlo5oH is offline   Reply With Quote
Old 07-12-2014, 04:29 AM   #4
tacoma96's Avatar
Region: Rhode Island
What about if you have the 19" Brembo wheels? Can I run 275/40/19's or wider? I know the wheels are only 9" but I can't see that Ford offers an optional Brembo wheel in a 10"
tacoma96 is offline   Reply With Quote
Old 07-12-2014, 08:12 PM   #5
Redonblackpony's Avatar
The Brembo wheels only come in 9" widths. Ford racing and many other manufacturers offer 10". A 275mm is the widest recommend tire for a 9" wheel.
Redonblackpony is offline   Reply With Quote
Old 07-12-2014, 09:20 PM   #6
tacoma96's Avatar
Thanks, if I did go to 10" wide rim in the rear is a 275 still the widest tire that will fit with no rub issues?
Old 07-12-2014, 09:56 PM   #7
That really depends on if you're lowered and how low. Stock ride height will accommodate a 315 easily.
Old 07-13-2014, 03:38 AM   #8
tacoma96's Avatar
Great, I'm not lowered. The car only car 1700 miles on it so far. I had an '03 that was lowered and a had 315's on it we no issues
Old 07-13-2014, 06:14 AM   #9
I put the relocation brackets on (not expensive). And I was able to put the 325/50/15" on my 2014 GT. Went with the MT drag radial. Big tire but it fits nicely.
bodon is offline   Reply With Quote
Old 07-13-2014, 06:18 AM   #10
tacoma96's Avatar
Cool
Old 07-16-2014, 09:02 PM   #11
Not true the Laguna Seca rear 19" wheels are 19x10"
chefron50 is offline   Reply With Quote
Old 08-22-2014, 06:20 PM   #12
Ftodaro's Avatar
I have a 2014 with the Brimbo brake package, I was going to go with an 18 inch rim because there are more road racing tire options, and I am told that the 18 inch rim will clear the brakes. I was planning on 18x10 all around with 274-40-18's
anyone see a problem. stock, not lowered.
Frank
2014 GT, Track Package, Deep Impact Blue. Roush Axle back, MGW short shifter.
Ftodaro is offline   Reply With Quote
Old 08-22-2014, 07:54 PM   #13
mustanggt2013's Avatar
I've got 285/40/18 out back and have lots of room. 18x10 wheel
mustanggt2013 is offline   Reply With Quote
Old 08-26-2014, 10:53 PM   #14
MarkCoyote's Avatar
What about on the base model cars with 18x8 wheel ?
MarkCoyote is offline   Reply With Quote
Old 08-26-2014, 11:18 PM   #15
Laquisha's Avatar
Im running 19x9.5 and have 255/40/19 front and 285/35/19 rear, nitto invos, goood traction'
Old 08-26-2014, 11:19 PM   #16
MarkCoyote's Avatar
18x8?
Old 08-26-2014, 11:20 PM   #17
Laquisha's Avatar
Name:	ImageUploadedByMustang Evolution1409116838.756121.jpg
Old 08-26-2014, 11:51 PM   #18
DallasStang77's Avatar
Pictures please. And what's your offsets on the rear wheels?
What's the widest tire I can go in the rear BUSHGUTS Mustang Wheels & Tires 6 11-23-2012 01:43 PM
widest tire all around? Laser Mustang Wheels & Tires 16 01-29-2007 06:58 AM
widest tire on stock rim? stangracer Mustang Wheels & Tires 3 08-22-2004 02:09 PM
Widest Tire 88stang Mustang Wheels & Tires 16 07-08-2004 09:01 AM
widest tire on a 8 inch rim. SVT_Rob Mustang Wheels & Tires 3 06-03-2004 08:17 PM
01:40 PM
