Missing gears at high rpm - Mustang Evolution
Old 07-11-2014, 05:57 PM   #1
Redonblackpony's Avatar
I have been tracking my 2012 mustang GT a lot more lately than I have in the past. I'm pushing the limits of the car as it was intended. One thing that happens upon occasion is I miss fifth gear due to lock out or I miss downshifting from 5 to 4 and get locked out. This only happens at high rpm and when shifting quickly. I have a Barton short throw shifter with the bracket and this still happens. Has anybody had this problem and what could be done to solve it?
Redonblackpony is offline   Reply With Quote
Old 07-12-2014, 04:46 PM   #2
Nobody?? C'mon really
Old 07-12-2014, 05:03 PM   #3
Rapinator126's Avatar
#1 driver mod
#2 stainless clutch line
#3 white line mount
#4 spring assist removal.
Old 07-12-2014, 05:17 PM   #4
Okay I've researched the braided stainless steel clutch line and the white line transmission mount. What's up with guys drilling out the center of the transmission mount? Is that an attempt to limit NVH?
Old 07-12-2014, 05:23 PM   #5
Yes they drill it out for the NVH
Old 07-12-2014, 05:24 PM   #6
Got it. Thanks
Old 07-13-2014, 12:16 AM   #7
Noodles76's Avatar
What's NVH
Noodles76 is offline   Reply With Quote
Old 07-13-2014, 05:38 AM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Noise, vibration, harshness
Sent from your mom's house.
2012 Kona Blue 3.7L V6:
Old 07-13-2014, 09:57 AM   #9
Noodles76's Avatar
Got it
Old 07-19-2014, 05:54 AM   #10
Ftodaro's Avatar
Slow down you shift. It's not necessary to bang the gears. Run thinner fluid, like red line MTL
Frank
2014 GT, Track Package, Deep Impact Blue. Roush Axle back, MGW short shifter.
Ftodaro is offline   Reply With Quote
Old 07-19-2014, 09:09 AM   #11
nando09's Avatar
I had the same exact issue. It's caused by the shifter bracket. Look for the Barton Two Post Shifter Bracket. Solved my problem!!! Look at stock shifter bracket vs. Aftermarket. I can still shift as fast as I want and as hard as I want now that everything else held in place with the better bracket! Click image for larger version
Name:	ImageUploadedByMustang Evolution1405782565.824497.jpg
Fernando A
Black Coyote
nando09 is offline   Reply With Quote
GEAR HEADS HELP! Rapid exhaust popping @ WOT high rpm Brad.krieg SVT Mustang 1 02-22-2012 02:06 PM
RPM's are high?! Mustang_Madness 1996-2004 Mustang GT 30 02-08-2012 09:58 PM
High RPM's during emissions test Ben513b General Car Discussion 8 02-13-2011 03:54 PM
High RPM idle electricstang Pre-2005 V6 Mustang 4 09-25-2005 12:55 AM
09:44 AM
