Running stock engine with boss 302 - Mustang Evolution
Old 07-16-2014, 05:20 PM   #1
I have a 2014 Mustang 5.0 and as the title implements I was just wondering if running the boss 302 on my stock engine be a bad call. If so what else could I upgrade to make up for the deficit? I already purchased a boss cold air intake as well and the steeda tuner for it. That's pretty much the only bolt on mod I will be running. Any help in this area would be much appreciated.
jcalvinrice is offline   Reply With Quote
Old 07-16-2014, 07:27 PM   #2
3\73 gears
chefron50 is offline   Reply With Quote
Old 07-16-2014, 07:29 PM   #3
I had my eyes on those next my only concern is if you think my stock internals for my engine could handle the bolt-on mods?
Old 07-16-2014, 08:25 PM   #4
UrMaster's Avatar
Your stock internals will be just fine with bolt ons. I have the BOSS manifold bigger TB jlt cai and full header back off road exhaust. Its tuned and shift points are at 7500 no problems. Others take it even further
UrMaster is offline   Reply With Quote
Old 07-16-2014, 08:43 PM   #5
Thanks for the advice I was just worried that my stock setup wouldn't be good enough. Thanks for the advice.
Old 07-16-2014, 10:39 PM   #6
UrMaster's Avatar
Nah these motors are stout. There's ppl running forced induction and nawzzz on stock internals.
Sent from my SM-N900V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
Old 07-17-2014, 02:50 AM   #7
Your good till about 600 hp
Old 07-17-2014, 10:45 AM   #8
Thanks for the info. The only thing that concerns me now is do I really want to void my warranty?
Old 07-17-2014, 10:46 AM   #9
UrMaster's Avatar
It's a Ford part. I was told by dealer if they install it it won't void warranty but who knows
Old 07-17-2014, 10:50 AM   #10
I guess it just depends on the dealership.
Old 07-17-2014, 10:52 AM   #11
Rapinator126's Avatar
Only worth it if you go beyond 7500 rpms.
Thread
Old 07-17-2014, 10:53 AM   #12
Also what about installing the tune file that might raise a couple eyebrows.
Old 07-17-2014, 10:54 AM   #13
UrMaster's Avatar
It helps beyond 7000 that's where the stocker craps out. A bigger tb will also more then make up for the minor loss in tq under the curb too
Old 07-17-2014, 10:57 AM   #14
I had also ordered a ford racing 90mm throttle body which I was planning on returning. So your saying I should keep that to help improve the torque loss?
Old 07-17-2014, 11:00 AM   #15
Return the throttle body.
Boss if used past 7500 and return throttle body.
End thread B4 this thread gets full of a bunch of bad advice.
Old 07-17-2014, 11:01 AM   #16
Alright I'll return the tb thanks rasp.
Old 07-17-2014, 11:48 AM   #17
Grabber Blue5.0's Avatar
No it's not. It's a Ford Racing part. Totaly different. Plus it requires a tune.
Agreed.
That's the risk.
Send it back.
Old 07-17-2014, 12:33 PM   #18
UrMaster's Avatar
90 mm is overkill for a stock internal engine
Old 07-17-2014, 12:50 PM   #19
UrMaster's Avatar
I run an 85mm. You won't see much as far peak gains but you'll pick up around 15 under the curve. Common misconception is its all about your peak hp. Not if u want a good running car. The dyno doesn't lie... Boss with a bigger tb and a nice cai and a tune will definitely wake the car up. Just have to use the rpm.
Old 07-17-2014, 01:01 PM   #20
Lol throttle body is a paper weight.
Old 07-17-2014, 03:31 PM   #21
UrMaster's Avatar
Dyno graphs show otherwise when paired with the boss intake. Stock vehicle yes I'd agree.
Old 07-17-2014, 03:32 PM   #22
Lmao. Ok we have another dyno warrior over here.
Old 07-17-2014, 03:53 PM   #23
Dyno numbers mean jack squat. A throttle body is not needed for the majority of people out there. Even F/I guys up to a certain point. My recent 11.3 N/A pass is proof the stock throttle body works just fine.
Old 07-17-2014, 05:36 PM   #24
UrMaster's Avatar
Dyno is a good way so see what power the car is making and what it's capable of. If you want to know if it helps that's how u find out. A stock one does work fine nobody said It doesn't.
Old 07-17-2014, 05:41 PM   #25
9 secound cars still using stock throttle body for a reason.
650-700 with mine. No need
Old 07-17-2014, 07:41 PM   #26
I went with Justin@VMP,He did the install, 130mm TB 82 mm pulley 625rwhp in a 2013 boss
Boss 302 video running from some death machine Lalayla General Mustang Discussion 2 09-05-2013 09:38 AM
2013 Mustang Boss 302 :: 2013 Ford Boss 302 bvillarreal60 Member Garages 0 05-01-2013 09:09 PM
Boss 302 or Boss 429? AllanUSAFEvans 2011-2014 Mustang GT 6 03-05-2012 08:06 AM
BOSS 302 Mustang :: 2012 Ford B0SS 302 GoldenPonyBoy Member Garages 0 09-18-2011 11:12 AM
10:26 PM
