Eibach Sportlines with 20" wheels - Mustang Evolution
Old 07-17-2014, 11:33 PM   #1
hispeedlodrag's Avatar
Seen some pics and videos of 2014 GT's with this setup - any other suspension mods required for clearance?
hispeedlodrag is offline   Reply With Quote
Old 07-18-2014, 12:30 AM   #2
DallasStang77's Avatar
Yes. I'm running Sportline with 20" +45 offset wheels.
- Adjustable panhard bar or watts links.
- lower control arm (LCA)
- LCA relocation bracket
- some say adjustable upper control arm to adjust the pinion but I've run my set up with the stock UCA so far for over two years no problem. I will get the UCA but not until I get a one piece drive shaft.
- shocks and struts
- caster camber plates
You should be fine after this setup.
Old 07-18-2014, 10:13 AM   #3
What size tires are you running? I hear a 295/30 rear and 255/35 front work fine. Are all of your listed mods needed for this spring kit to work? I need to get this kit ordered right the first time!
Old 07-18-2014, 10:53 AM   #4
2 Stangz's Avatar
Region: Nevada
If you're Mustang isn't a drag-only car, you'll want to correct a lot of what lowering springs change in the geometry of your suspension especially if its a daily driver:
- Bumpsteer kit (corrects steering response, for me it greatly improved it from stock)
- Ball joints (corrects roll center)
- Adj. panhard bar (corrects rear-end alignment)
- Rear LCA relocation brackets (relocates LCA's, otherwise traction is significantly reduced)
BUT if you're looking for maximum effectiveness out of an aftermarket suspension I'd also recommend the following:
- Stronger strut mounts (factory pieces start to pop and fall apart, also more adjustable)
- Aftermarket shocks and struts (to get ride quality back on par with stiffer springs)
- Aftermarket rear LCA's (greatly reduces wheel hop and improves traction)
- Aftermarket UCA+UCA bracket (same as above)
Old 07-18-2014, 12:20 PM   #5
Sterlingbeast5.0's Avatar
I JUST got the Eibach Sportline springs, Eibach Pro Damper Shocks/struts and bought Camber bolts, Adjustable BMR pan hard, Adjustable BMR UCA and BMR LCA. Guy at the alinement shop that should cover anything I need to lower properly, get off the line better and handle very well.
BTW... install next week so I will let you know.
Old 07-18-2014, 01:08 PM   #6
2 Stangz's Avatar
Region: Nevada
^I definitely recommend BMR relo brackets with that setup. I rode around for a week with everything on my suspension list in my garage without the brackets and when my replacement set of brackets finally arrived traction was much much better. Definitely worth the $150 for them
Old 07-18-2014, 01:18 PM   #7
Thanks for the info, guys.
NaplesStang - I look forward to hearing how the install turns out.
Old 07-31-2014, 07:07 AM   #8
Thought I would update. I have had the set up for a couple days now... to reiterate:
BMR adjustable Panhard bar
BMR Polly bearing LCA
BMR Adjustable UCA polly bearrings
Eibach Sportline Springs
Eibach Pro-Damper Shocks and struts
I don't have any graphs or charts lol, but I can tell you that taking corners at speed is a world of difference!! NO body roll to speak of at all. Love the lowered look! She grabs the ground nicely on a launch too. TC off I tried a couple time to replicate the wheel hop I am so used to and nothing. Couldnt be happer! Only thing I will say for anyone in the future us to buy the bearings for the struts. Mechanic said they are built to fail with plastic parts. Soon as pressure was off they pop open and bearings shoot everywhere. I have read elsewhere that over 10,000 miles should expect this. Thrilled with the difference in handling, launch and look!
Name:	Drop Difference.jpg
Old 08-02-2014, 07:41 AM   #9
What wheels and tires are you running?
Old 08-02-2014, 07:46 AM   #10
they are 20" AMR and Sumitomo HZR III believe size is 255 35/20
Sent from my SPH-D710 using Mustang Evolution mobile app
Eibach sportlines or ford b springs? 98vertgt 1996-2004 Mustang GT 7 04-26-2013 04:27 PM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 02:45 PM
Pic Request: 10+ Eibach Sportlines.. CYCLON37 Pictures and Videos 15 04-19-2012 06:19 AM
03:22 AM
