stuck on passenger header - Mustang Evolution
Old 07-18-2014, 05:56 PM   #1
Joaquin_ii's Avatar
i can get the top 2 corner nuts off anyone who has installed headers before got any ideas?
2011 gt putting bbk headers on
Joaquin_ii is offline   Reply With Quote
Old 07-18-2014, 09:03 PM   #2
Jsmorley81's Avatar
Takes time. Be patient. You can take tire off and get to them thru there. Passenger side is a pita.
Jsmorley81 is offline   Reply With Quote
Old 07-18-2014, 09:06 PM   #3
REG
headers
Which two corners?
The passenger Side is a *****, I've done the BBK shorties so tell me what your problem is and I'll walk you through it as best I can.
The top front, I bought a 15 mm wrench and bent it in a vice to work.
Didn't have to bend it much but you can only get maybe a 6th of a turn on it.
Bottom front I used a 3/8 matco flex ratchet with a 15 mm deep well.
I got horror stories you can't dream of on the pass side!
REG is offline   Reply With Quote
Old 07-18-2014, 09:31 PM   #4
Joaquin_ii's Avatar
I'm going to try to remove tire tomorrow it's already on the jack. Thank you for the input man I hope I can get this
Old 07-19-2014, 10:11 AM   #5
Jsmorley81's Avatar
I used several swivel sockets and dome small wrenches on that side. Can not get much of a turn on them but eventually they will come out.
Old 07-19-2014, 11:09 AM   #6
REG
Much the same for me.
The one behind the heater hose was tough, that nut I bought a 15 mm wrench and bent it enough to be able to get around interference with the valve cover.
« Tire Size | Exhaust »
Header coating. Ceramic vs. Chrome/painted with header wrap wc3john The Bar 10 06-27-2011 09:20 AM
86 svo mustang header panel wanted header panel? wit 2.3 Mustang 1 08-21-2009 07:39 PM
My ugly exhaust tips are stuck Crispy Pre-2005 V6 Mustang 7 12-19-2003 10:12 PM
Pulled out my first stuck vehicle n8r The Bar 7 10-21-2003 09:52 AM
something stuck in her throat Ken The Bar 17 10-16-2003 04:49 PM
05:33 AM
