trans. slip - Mustang Evolution
Old 07-22-2014, 06:06 PM   #1
trans. slip
My 2013 has a soft shift and a flare 5 to 6 3 h rpm at times after driving over a hour . anyone had this happen .
Lugnut is offline   Reply With Quote
Old 07-22-2014, 06:12 PM   #2
Please fix your post, "a flare 5 to 6 3 h rpm" does not make sense.
kn7671 is offline   Reply With Quote
Old 07-22-2014, 07:13 PM   #3
UrMaster's Avatar
Stock tune?
Sent from my SM-N900V using Mustang Evolution mobile app
---------- Post added at 08:13 PM ---------- Previous post was at 08:12 PM ----------
I think he means a 3 hundred rpm flare from 5th to 6th?
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 07-31-2014, 06:54 PM   #4
trans shifts soft all shifts and has a 3 hundred rpm flare from 5 to 6 shift . When trans is hot after driving over 1 hour ( normal driving ) Also cold ac water drips on passengers foot when turning left
Old 08-01-2014, 12:14 AM   #5
UrMaster's Avatar
Have you checked the transmission fluid level?
Old 08-01-2014, 02:06 PM   #6
ArtU's Avatar
I don't think he can, they are sealed I was told when I had a 2013 auto. Take it to the dealer, you have the water problem on passenger side they need to unseal and check your Tranny ASAP
Old 08-01-2014, 03:32 PM   #7
Grabber Blue5.0's Avatar
They are not sealed. You check the fluid level with the dipstick. It's there.
Old 08-04-2014, 02:03 PM   #8
UrMaster's Avatar
If I recall I read it's not under the hood but under the car isn't it
Old 08-04-2014, 03:28 PM   #9
Correct. It's on the side of the transmission.
Old 08-04-2014, 07:46 PM   #10
ArtU's Avatar
OK so then the owners manual lied to us?
Old 08-04-2014, 08:37 PM   #11
Apparently yes.
Old 08-05-2014, 12:53 PM   #12
ArtU's Avatar
Apparently yes.
Wow, I was duped, but I know have a MT-82. Here it is, implying that dealer needs to check it and so I never looked:
http://www.fordservicecontent.com/Fo.../13musom3e.pdf
Page: 240
Note:Transmission fluid should be checked and, if required, added by
an authorized dealer. The automatic transmission does not have a transmission fluid dipstick. However, the fluid level should be checked if the transmission is not working properly, (i.e., if the transmission slips or shifts slowly) or if you
notice some sign of fluid leakage.
They then show you how to check and add fluid to a manual transmission which is via a witness hole, but the auto does have a "Hidden" dipstick?
Old 08-05-2014, 01:32 PM   #13
2014SGM's Avatar
Region: Mexico
Mine does the same thing, stock tune. I took it in and they said it only did it once during their test drive, when they were going slow.I told them (before hand as well) that is when it did it except all of the time. They said they would email Ford about it but there are no TSB's on it so they will not look into it.
It DID NOT do this for the first 5,000 miles and only has 10,000 on it now. At least I have it documented.
I say take it in and have the dealership contact Ford. There may be in issue, even if it's a reprogramming of the slug shift automatic we have.
2014SGM is offline   Reply With Quote
Old 08-05-2014, 02:29 PM   #14
Page: 240
I'm sure Ford does it in such a way so as to not have the average person checking and adding fluid to the auto transmission. Which is also why most do come sealed from the factory now. The 6R80 is mighty expensive and they don't want to have to replace them unless it's absolutely necessary.
Old 08-05-2014, 04:55 PM   #15
ArtU's Avatar
Yes GB; that makes since and is why I was told by others the 6R80 was sealed when I had one. But I am concerned about truth; that the factory says it has no dipstick when it does (they could have just left that line out of the manual) when indeed it has a hidden one. Meanwhile they show how to do a difficult manual transmission fluid check or fill that has no dipstick at all, just a witness hole
[and I hear of folks changing the MT-82 oil to cure their notchy problems are being told changing it them selves to other oil voids the MT-82 warranty]
Why did Camaro and Trans Ams sales slip, compared to the Mustang? twrgadarn8 General Car Discussion 16 04-04-2010 01:18 PM
Have a Time Slip Ratt Fink Pre-2005 V6 Mustang 16 01-10-2006 02:34 PM
New time-slip stickers 97Stallion The Bar 11 09-08-2004 07:58 AM
detroit locker vs. limited slip oaktonarcher Pre-2005 V6 Mustang 15 07-10-2004 01:27 PM
If you have a time slip: Rellik Pre-2005 V6 Mustang 7 07-20-2003 06:45 PM
06:49 AM
