High Performance vs All Season tires - Mustang Evolution
Old 07-22-2014, 06:17 PM   #1
Marty5.0's Avatar
It's time for me to get a new set of tires and have been looking around but can't decide on all season or performance.
My main question is... If I go high performance, does it cut down on my tire life?
Right now I have the stock 19" P - zeros on.
Also, how wide of a tire can I safely go on my stock 19x9 (I think it's 9... maybe 8.5 can't remember.)
2013 GTCS Sterling Gray, 3.73 gears, limited slip dif, MT82, Roush Axel-backs, 3 qtr window louvers
Marty5.0 is offline   Reply With Quote
Old 07-23-2014, 03:16 AM   #2
For your concerns you need to look at the treadwear rating of the tires, which will be on the sidewall, basically its going to tell you how long the tire will last, the higher the number the harder of a compound the tire and the longer it will last, lower numbers wont last as long but will perform better. I just replaced my continental contiprocontact's with a treadwear of 400 with a sumitomo htr z 3 with a treadwear of 300, performancewise, night and day difference the sumitomo's are so much better and stickier, but I don't expect them to last as long. Of course the more performance oriented tires aren't any good in the cold or snow, so that may be a factor depending on where you live. Check out tirerack.com
rwheels is offline   Reply With Quote
Old 07-23-2014, 08:42 AM   #3
Awww but wait, UTQG Treadwear Rating is not a universal, controlled and calibrated, standard that can be truly used to cross shop between tire manufacturers. There's a little Tom Foolery going on for UTQG, Traction, and Temperature grades, so beware.
Here's a link on the TireRack.com explaining this.
http://www.tirerack.com/tires/tirete....jsp?techid=48
In other words, the numbers in tire specs do not tell the whole story, and some companies are not very honest in those numbers. There is lots of technology put into tires, but there is only one thing that's usually true when it comes to tires, you get what you pay for.
kn7671 is offline   Reply With Quote
Old 07-23-2014, 08:59 AM   #4
AJcruz1's Avatar
A good all season tire like Michelin Pilot Sports A/S 3 (kind of pricey) or Continental DWS will be way be better than the stock Pirelli. I have the Michelins and love them, 275/40/19 and the Handling, traction and ride in wet/dry conditions is great. I have also had the DWS' and I would say they are a close second but they have kind of a soft sidewall.
AJcruz1 is offline   Reply With Quote
Old 07-23-2014, 09:06 AM   #5
Just to be clear, there are High Performance All Season tires as well, so when shopping All Season tires, you don't need to give up on performance.
Summer tires usually use a softer or faster wearing rubber compound, and will not last as long as all-season tires, but depending on where you live, and how you drive, will depend on what tires you should be looking at.
As for how wide, the stock wheels (assume that's your car in the pic) are 19 x 8.5", while the Brembo/Track Pack wheels are 19 x 9.0". The stock 8.5" wide wheels can accept a 255/40/19 or 255/45/19 tire safely. Some people on here might recommend using a 275/40/19's on the stock 8.5" wheels, but most tire manufacturers recommend at least a 9.0" wide wheel at a minimum for a 275 tire.
I use Michelin Pilot Sport A/S 3's, 255/45/19 on my Brembo wheels.
2015 Mustang GT PP 401A Black | Roush Supercharger
Old 07-23-2014, 12:08 PM   #6
Marty5.0's Avatar
Wow great info. Tks everyone
Old 07-23-2014, 01:18 PM   #7
I have the as3 too, stock bbp 255 size. Way better wet grip, way better ride, equivalent dry grip to the P Zeros. No complaints. I needed these bc I DD the car, all year round.
Old 07-23-2014, 05:13 PM   #8
If you go with the summer tire, expect less grip on cold days. If you like all season, I loved my Michelin Pilot sport A/S 3, but on a different car.
jd864 is offline   Reply With Quote
Old 07-23-2014, 08:44 PM   #9
One thing to keep in mind about summer tires is the winter climate where you live. If you regularly encounter temperatures around or below freezing during the winter months, you risk damaging the summer tires by developing cracks in the rubber. I think temps below 40F is where many tire manufacturers recommend summer tires not be used.
Best all season tires? sLbxO143 Mustang Wheels & Tires 30 12-18-2013 07:13 AM
All season tires Mayhem48 2011-2014 V6 Mustang 9 01-28-2013 09:17 AM
all season tires 2013 19" Flashjmg 2011-2014 V6 Mustang 10 10-04-2012 07:26 PM
Summer or All Season Tires? 99ford Mustang Wheels & Tires 5 05-18-2012 08:45 PM
All season tires 04machazblue Mustang Wheels & Tires 33 02-03-2011 07:26 AM
01:16 PM
