Install Costs - Mustang Evolution
Old 08-02-2014, 06:15 PM   #1
Mike_waldroup's Avatar
Install Costs
I have a 2013 GT A6. What are you guys paying for installs on the following:
Torque Converter
Gear Swaps
Long Tube headers and x pipe
Complete suspenion kit
Custom Tunes
Mike_waldroup is offline   Reply With Quote
Old 08-02-2014, 06:46 PM   #2
Rynarok's Avatar
Most guys on here seem to be do-it-yourselfers....long tubes & xpipe are fairly simple things to accomplish yourself if you have a set of tools. Panhard, springs, LCA/UCA, sways are also relatively straight forward to do yourself also.
I would estimate a shop would do your exhaust work for around 2-300 if they don't have to fab anything for you - some shops will not install an exhaust without a catalytic converter so heads up. Suspension might be around 3-500ish. I don't know about doing the gear swap and torque converter - mine is a .373 MT82, so I never had much reason to look into it. Doing the gear swaps seems to be a common thing for guys on here to do, though...I bet a shop would knock it out for around 400 or so.
Tunes could be done yourself via a handheld tuner if you are working with a mail order tune provider, like Lund, AED, BAMA, etc. Having a full dyno tune done at a place would be a bit more than you'd pay with these guys, as you are also paying for dyno time as well as the tune. Safe bet would be 5-600 depending on how the shop does the tuning and how many runs it requires.
----edit----
You'll probably need access to a lift to do longtubes by yourself, I'm not 100% sure. Most of what you listed could be knocked out over the span of a few weekends with a decent socket set w/ extensions, jacks, jackstands, spring compressors, replacement gear oil, a yard stick, a torque wrench, some patience, a bit of luck, and a few cases of your beer of choice.
Saves you some cash if you manage to do it right by yourself and you earn yourself a few points on the mancard.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
custom exhaust pipe install costs? alrefire 2011-2014 V6 Mustang 11 08-07-2012 09:41 PM
Motor maching costs? Brett09 Pre-2005 V6 Mustang 5 07-05-2009 03:36 PM
Wear And Tear - parts and costs jones4stangs Pre-2005 V6 Mustang 6 10-17-2005 12:26 PM
dyno time costs? charkelly9 Pre-2005 V6 Mustang 8 02-22-2005 04:39 PM
Donate 2 dollars a month to help with server costs! Brent The Bar 35 10-22-2004 09:54 PM
07:58 PM
