Jacking up the car - Mustang Evolution
Old 08-04-2014, 12:40 AM   #1
Black302Alex's Avatar
Jacking up the car
Do I need to use a low profile jack to get the car up on jack stands? Tried using a normal jack and it wouldn't go high enough for the jack stand to sit under. Maybe I'm just doing this wrong?
Black302Alex is offline   Reply With Quote
Old 08-04-2014, 01:09 AM   #2
Tyoung68's Avatar
Low profile jacks are for lowered cars and some jacks go higher than others. Although you should be able to get your car on jack stands with pretty much all jacks. It depends where you jack and put the stands.
Old 08-04-2014, 06:34 AM   #3
2014oxstang's Avatar
I'm going I have to go out and get a lower profile jack because being lowered 1.5" and having the Roush splitters makes it impossible to get a jack under there. I have to drive up onto boards currently lol.
2014oxstang is offline   Reply With Quote
Old 08-05-2014, 01:11 PM   #4
Tyoung68's Avatar
Its just ideal to jack up the car closes to where you want to put the jack
Old 08-05-2014, 03:33 PM   #5
Rynarok's Avatar
A good low profile floor jack should set you back 100-150 bucks - once you have a good floor jack you'll wonder why you waited so long to get one.
That, with a decent set of jackstands, should handle damn near most of what most guys would do in their own garage.
Ramps are relatively cheap and easy, also.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 08-05-2014, 03:43 PM   #6
Name:	ImageUploadedByMustang Evolution1407274990.632420.jpg
ID:	162933 with these jacks I don't know where to place them to get my car high enough for the jack stands to clear
Old 08-05-2014, 04:02 PM   #7
Loc: Austin,TX
Originally Posted by Black302Alex View Post
Attachment 162933 with these jacks I don't know where to place them to get my car high enough for the jack stands to clear
Sorry. Meant to quote your post,not edit it. That jack stand will be good to toss in the trunk of your DD. Go to Harbor Freight and get a low pro jack.
Old 08-05-2014, 04:12 PM   #8
Idk if I'm setting it up wrong, but as I try jacking towards the center of the car with these jacks, I have no room to jack anymore. Will low pro jacks help me with this problem?
Old 08-05-2014, 04:31 PM   #9
Abominable Mustang
WhoDat's Avatar
Region: Alaska
What exactly do you mean by towards the center of the car? You do know where the jack points on the car are correct?
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-05-2014, 04:34 PM   #10
I usually jack like the side of the car of you know what I'm talking about like from the door to the rear wheel that area, but once I try going towards the center as in passed the side jack points I don't get clearance. Lol sorry i don't know crap much about this and I appreciate the help!!
Old 08-05-2014, 04:37 PM   #11
Tyoung68's Avatar
Low profile jacks are only need if you cannot fit your jack under your car.
Old 08-05-2014, 04:42 PM   #12
Thank you!!!
Old 08-05-2014, 05:04 PM   #13
Abominable Mustang
WhoDat's Avatar
Region: Alaska
If you're talking about the inner jack points seen in the attached link, you're gonna need a low profile jack to reach that far in.
http://forums.themustangsource.com/a...jackpoints.jpg
Old 08-05-2014, 06:02 PM   #14
Does anyone know if the duralast low pro are any good? Or does it not matter
Old 08-05-2014, 06:03 PM   #15
Tyoung68's Avatar
I work at autozone and i have sold one in almost a year, but iv sold other jacks and haven't seen any come back
Old 08-05-2014, 06:15 PM   #16
So you wouldn't recommend duralast? So what would you recommend?
Old 08-05-2014, 06:27 PM   #17
If you have a Harbor Freight tools nearby, I recommend taking a look at their jacks.
They have a wide assortment and are reasonably priced.
Old 08-05-2014, 08:24 PM   #18
Tyoung68's Avatar
These
Old 08-05-2014, 08:31 PM   #19
Tyoung68's Avatar
These
Old 08-05-2014, 08:34 PM   #20
Coyote5o's Avatar
Region: West Virgina
Arcan makes some good jacks as well. Amazon has decent deals usually. Got mine for $200. If I drive my car up on two 2x6's I can reach the center jack point under the k member and then lift by the diff to get everything quickly.
---------- Post added at 10:34 PM ---------- Previous post was at 10:33 PM ----------
I'm also lowered on steeda ultralites (1.25" front and 1.5" back)
2013 Mustang GT w/ Track Pack - Steeda Ultralite Springs, Koni Str.t Struts/Shocks, BMR LCA & Relocation Brackets, BMR Adjustable UCA and Bracket, BMR Adjustable Panhard, DSS Aluminum Driveshaft, Bassani x-pipe and catback, MGW shifter, JLT CAI, Steeda Tune
Coyote5o is offline   Reply With Quote
Old 08-05-2014, 09:16 PM   #21
Loc: Austin,TX
:FP:
Old 08-07-2014, 06:20 AM   #22
kingstrider's Avatar
Its hard to tell from the photo but the arm on that jack doesn't look long enough to clear those stands. If that is the case then you need a bigger jack.
kingstrider is offline   Reply With Quote
Old 08-07-2014, 07:03 AM   #23
Region: New Mexico
Just a fyi. If you have a jack and a spare, make sure your jack fits under the side skirt especially if you have lowered your Mustang. I had a flat rear tire and the scissor jack didn't fit. I had to buy a lower profile one.
califsp is offline   Reply With Quote
Old 08-09-2014, 07:06 AM   #24
I too made some 2 step (2X6) ramps in order to get my 2014 GT up high enough to get a jack under, and I have a low profile jack.
bodon is offline   Reply With Quote
Old 08-09-2014, 07:09 PM   #25
How low are you guys? I'm just curious since I plan to do a 1.5" drop, do you guys have problems getting it on a lift at a shop too?
2014 Mustang GT, DIB, MT82, Tech and Track Package
mods are coming, slowly
kanine is offline   Reply With Quote
Mach 1 jacking Redsvtcobra Pictures and Videos 12 01-14-2014 01:11 PM
Jacking up car Moto111 2011-2014 Mustang GT 38 02-03-2013 01:48 PM
The guy turned in his Car Title and I want to buy his car. How do I get a new Title for the car? stanley General Car Discussion 2 04-10-2010 09:45 AM
Jacking the back up. GhostStang 2005-2010 Mustang GT 5 08-05-2009 03:46 PM
Differ Ways of Jacking bluemustang Pictures and Videos 25 03-02-2007 08:26 AM
03:56 PM
