Whining from rear end - Mustang Evolution
Old 08-04-2014, 08:54 AM   #1
Randeezy23's Avatar
Just recently lowered my car, I used steeda ultra lites, LCA, adjustable UCA, LCA relocation brackets, UCA mount, adjustable panhard bar, koni adjustable shocks. Today on the freeway I heard a whining noise and noticed when I speed up it gets faster and louder. I have stock gears 3:55. Any help is appreciated.
Randeezy23 is offline   Reply With Quote
Old 08-04-2014, 09:01 AM   #2
Grabber Blue5.0's Avatar
What upper control arm and what did you set the pinion angle to?
Old 08-04-2014, 09:07 AM   #3
Randeezy23's Avatar
Used bmr UCA 2.3 degrees
Old 08-04-2014, 10:36 AM   #4
Paradone's Avatar
I lowered mine 1.5" but as suggested by the performance shop I used Adj LCA's and relo brackets along with Adj panhard bar did not use a aftermarket UCA or even touch it and have not had any issues set at 2.7 wheel hop is also completely gone after everything was done.
Paradone is offline   Reply With Quote
Old 08-04-2014, 12:36 PM   #5
Anything over -2 is pushing it for a street 3 link car. That's a lot of strain on an already known problem area on 8.8s: the pinion seal.
The transmission of noise to the cabin is a part of stiffening up the rear suspension bushes and having a control arm attached to the actual pumpkin itself. It's part of the reason I went with the rubber Roush piece, especially since I'm not lowering. Putting poly LCAs did induce some extra noise but, it's very mild and only in a narrow speed range.
Old 08-04-2014, 01:03 PM   #6
Deerslayer's Avatar
When you replace all of that soft forgiving rubber with some MUCH stiffer performance type components, you are going to hear a lot more of your driveline than you did before. The "racier" you get the louder you get It will give you more "feel" which is rougher and louder. Your UCA is probably where you are picking up more sound in your cabin than all the other parts for sure. You will get used to it. It is new to you now, so you notice it.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 08-04-2014, 01:10 PM   #7
Randeezy23's Avatar
It doesn't bother me but just wanted to make sure that it wasn't something that needed adjusting I appreciate all the help
Rear End Whining Again Slow4V 1996-2004 Mustang GT 3 04-17-2014 04:07 PM
Whining noise from rear end... ClockworkOrange General Mustang Discussion 7 05-28-2013 01:27 PM
8.8 rear end whining 67mustang97 1996-2004 Mustang GT 2 04-18-2010 09:34 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
10:14 PM
