After market Steeda short shifter - Mustang Evolution
Old 08-05-2014, 01:43 PM   #1
Zed
Zed's Avatar
Every time I shift into 2nd gear while making a turn, it makes a strange noise when it goes in and it also has an odd feel to it...
Anybody know how to fix this problem? Does anybody's car have the same problem?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Zed is offline   Reply With Quote
Old 08-05-2014, 05:24 PM   #2
Jgrummz's Avatar
Mine does the same thing when turning and shifting to 2nd. My car is brand new as well. I dont really worry about it though cuz i figure its just another "thing" with the mt82.
I would like to hear what others have to say as well though.
Jgrummz is offline   Reply With Quote
Old 08-05-2014, 06:00 PM   #3
20bmr14's Avatar
Do you guys have the shifter bracket as well or just the shifter?
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 08-05-2014, 07:09 PM   #4
tj@steeda's Avatar
Let me look into this with our manufacturing team. I have yet to come across this issue so I can't speak to the issues that you are experiencing.
As soon as I hear more ... I will let you know.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 08-05-2014, 07:21 PM   #5
Jgrummz's Avatar
I dont have the steeda shifter.. Im still stock except for trans bushing but its still a somewhat rough shift into 2nd while turning.
Old 08-05-2014, 09:34 PM   #6
I have the steeda shifter and when you change the clutch out all issues went away,I went mcleod,very light pedal,no more 1-2 lock outs and after it warms up no more notchy shifting,as smooth as butter.
chefron50 is offline   Reply With Quote
Old 08-06-2014, 07:00 AM   #7
tj@steeda's Avatar
Hello,
Are you using the supplied spacer for the shifter?
I spoke to manufacturing & they are unclear to what may be taking place. If you can provide some more insight ... we will continue to look into it once we get more information.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 08-07-2014, 06:06 AM   #8
kingstrider's Avatar
I have the Steeda shifter and bracket. I can't say I've noticed this but will check the next time I drive it.
kingstrider is offline   Reply With Quote
Old 08-07-2014, 12:33 PM   #9
I've noticed this as well. I notice it in 2nd and third. It sounds like it's coming into contact with something it shouldn't be. I think I'm just going to get an mgw and call it a day.
Mikeyt03 is offline   Reply With Quote
Old 08-07-2014, 12:35 PM   #10
tj@steeda's Avatar
You have noticed this with the Steeda Tri Ax?
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 08-07-2014, 12:41 PM   #11
Yeah. I have the bracket too. I had to have the spacer thing put in because I was getting locked out of second. Apparently some 14's have different specs and steeda had to create a spacer to fix it because going into second caused you to hit the reverse lock out plate. The spacer fixed the lock out issue, but it still makes odd noises from time to time going into 2nd and 3rd.
Old 08-07-2014, 03:03 PM   #12
tj@steeda's Avatar
There seems to be something going on here with the transmission vs. having an issue with the Tri Ax shifter. It is happening on both sets of cars ... ones with & ones without.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 08-07-2014, 04:45 PM   #13
BLKBETTY13's Avatar
For the record I run a Barton and never had any issues...
BLKBETTY13 is offline   Reply With Quote
Old 08-07-2014, 04:55 PM   #14
This problem started immediately after my shifter install. I know it's not my transmission.
Sent from my SM-G900T using Mustang Evolution mobile app
Old 08-08-2014, 07:28 AM   #15
tj@steeda's Avatar
A short throw shifter provides a more positive/direct connection with the transmission.
We eliminate a lot of the rubber with stiff materials for a better feel.
The downside to that is it will transmit more noise from the transmission and as the industry has noted ... these transmissions have a lot of opportunity for improvement.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 08-08-2014, 04:57 PM   #16
Oh ok. Thanks TJ. No worries, mgw cured all symptoms. Got tired of messing with the tri ax.
Old 08-09-2014, 07:53 AM   #17
tj@steeda's Avatar
Glad it worked out for you. You can reach me at tim@steeda.com if you are looking at any future Steeda parts & I can provide you with a forum code for you the issues that you experienced.
That is interesting, however ... I will provide more feedback to our engineers.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 08-09-2014, 10:01 AM   #18
I liked the tri ax. I just think the addition of the spacer was a weird fix and I believe it contributes to some of the issues, especially going into 2nd. The entire piece needs to be correctly manufactured to the adjusted ford specs for the 14's. But im not an engineer so i could be wrong. I'll pm you if I need any steeda stuff. Thanks!
Old 08-09-2014, 09:04 PM   #19
Worse case Steeda has lifetime warranty, but clutch replacement is the real cure
Opinions on the steeda short shifter. Ntbruncie 2011-2014 V6 Mustang 3 01-15-2013 11:03 PM
MGW or Steeda short throw shifter? Gobabygo67 1996-2004 Mustang GT 4 12-02-2011 02:14 PM
Steeda Tri ax short shifter install..... rinfield2004 SVT Mustang 10 09-02-2011 12:40 AM
Resovling My Steeda Shifter Short comings Herbstang Pictures and Videos 3 10-05-2008 05:40 AM
Steeda Tri-Ax Short Throw Shifter for T-3550 USMCSS Mustang Parts for Sale and Wanted 4 04-23-2007 08:09 AM
08:24 PM
