Magnaflow Competition catback hitting rear axle - Mustang Evolution
Old 08-05-2014, 02:47 PM   #1
515roushtvs5.0's Avatar
Anybody resolve the issue of the magnaflow competition series catback hitting the rear axle over bumps on lowered 2011 mustang gt!?! I cant handle it anymore!! About to have a shop just custom make me side exhaust!!! HELP!!!
515roushtvs5.0 is offline   Reply With Quote
Old 08-05-2014, 02:53 PM   #2
Rapinator126's Avatar
Part of it man.
3" exhaust and lowered it's Goin to happen over big bumps. You will get use to it
Old 08-05-2014, 03:03 PM   #3
Originally Posted by Rapinator126 View Post
Part of it man.
That's what I figured. And I haven't got used to it haha Iv been dealing with it for almost a year now. I'll probably just go with a custom exhaust out the side in front of the rear tires.
Old 08-05-2014, 03:35 PM   #4
Rynarok's Avatar
If it's real bad, try wrapping the piping with some heat tape/wrap to take the 'CLANG' out of it.
---edit---
Something like this.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 08-05-2014, 03:55 PM   #5
Deerslayer's Avatar
The drivers side will hit the vent cap on the rear axle. Here is an easy fix we did: Jacked her up, took a torch and heated the pipe right where the cap hits. Took a 3lb hammer and a long 1/2" extension and beat it in just a bit. It just dented it in just enough to where it did not hit even on big bumps. After switching to the Eibach R2 system, with bump stops, we are just as low, but never hit anymore even when we bottom out hard.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 08-05-2014, 04:00 PM   #6
I just deal with mine. If you don't like NVH and etc You wouldn't want to ride in my car. Solid motor mounts and all
Old 08-05-2014, 04:15 PM   #7
Ya I definitely wouldn't like that at all!! And I also have the r2's! What ride height are running and how many clicks compression and rebound are you at?
Old 08-05-2014, 04:25 PM   #8
Old 08-05-2014, 04:28 PM   #9
Deerslayer's Avatar
We are set soft for daily driving. We are all the way minus on Compression and two clicks off full + on rebound. Been loving this setup. With the R2's you will just have to dent the 3" over axle pipe on the drivers side just a bit and it will clear. I also noticed that if you were to trim just a 1/2" of the front of the over axle pipe for the whole thing to slide forward 1/2" it would clear better as well. We kept our Magnaflow over axle pipes to the GT500 quads so we had the same pipe clank for a while.
Old 08-05-2014, 04:36 PM   #10
That's about what I'm at only with a lil more rebound. And I think I'll try denting it in and if I don't like it or it doesn't work I'll probably just get a custom side exhaust
13-14 gt, flowmaster outlaw vs magnaflow competition catback Kurt_5ohh General Mustang Discussion 12 10-07-2013 09:08 PM
Magnaflow competition catback somedopebeats 2011-2014 V6 Mustang 17 10-04-2013 12:19 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
2011+ Magnaflow V6 competition muffler deletes pwrby4d Mustang Parts for Sale and Wanted 8 09-10-2012 03:14 PM
Roush axle back or magnaflow competition axleback?? Chaseh504 2011-2014 V6 Mustang 33 07-19-2012 09:47 PM
02:23 AM
