My car is bricked - Mustang Evolution
Old 08-10-2014, 04:51 AM   #1
mustanggt2013's Avatar
My car is bricked
Tried to load original backup and it diddent load it back to the car. Now I cant tune it with any tune. Says no ECM. Help please.
mustanggt2013 is offline   Reply With Quote
Old 08-10-2014, 06:31 AM   #2
scott_0's Avatar
what did you do right before this happened? did you update the hand held while there was a tune in the ecm? is the car's battery charged sufficiently? I try not to mess with flashing tunes on weekends or after hours when SCT isnt open, they can get you squared away first thing Monday morning
Old 08-10-2014, 09:15 AM   #3
DallasStang77's Avatar
Wait like 30-45min and reload stock tune.
I've had instances where the loading the race tune it would fail. And then I try to return to stock right after failing the race tune it also failed.
But for some reason if I waited like 30-45 mins it would allow me to return to stock again. Its dumb but true.
Old 08-10-2014, 09:18 AM   #4
But that was before I had the new updates to the tuner. After that I haven't failed in over 6 reflashes. But I also made sure I returned to stock before loading the new tune. Before that I forgot that step a few times because its not like I flash it every other day.
If you still have problems call the tuners. They can unlock the ECM for you.
Old 08-10-2014, 09:46 AM   #5
I had race tune on it and was going on a trip so I was going to put stock backup on it and it went through the whole process and said to disconnect so I did and then all the dash lights turned on and wouldn't start. So I tried to install stock tune again and it says no ECM
Old 08-10-2014, 09:49 AM   #6
When I hook up the tuner now it starts to read and then says no ECM
Old 08-10-2014, 09:58 AM   #7
scott_0's Avatar
try this ^^^ if that fails, try disconnecting the battery for a few minutes, reconnect it and try again. if that doesnt work, youll be stuck until normal business hours for SCT tomorrow. so you definitely didnt accept any updates on the hand held when connected to your PC while the race tune on the car?
Old 08-10-2014, 09:58 AM   #8
Ok thanks I'll try it
Old 08-10-2014, 10:00 AM   #9
Grabber Blue5.0's Avatar
Also when you disconnect the battery turn on the headlights. Do this for 20-30 minutes.
Old 08-10-2014, 10:10 AM   #10
Ok still days no ecm. Battery is disconnected and headlights on. Just waiting now.
Old 08-10-2014, 10:16 AM   #11
And no I diddent even plug it into the computer while I was changing tunes.
Sent from my HTC One_M8 using Mustang Evolution mobile app
Old 08-10-2014, 10:20 AM   #12
scott_0's Avatar
looking forward to hearing a success story man, but if this doesnt work, dont sweat it, SCT will get you squared away with a recovery stock tune. dont get stressed
Old 08-10-2014, 10:25 AM   #13
By the way I talked to bama ywsturday before they closed and they said that since its a in tune that I would have to talk with Diablo for them to get me fixed up. If this dosent work I'll be calling them first thing in the morning. I'm missing g work because of this
Old 08-10-2014, 10:29 AM   #14
Rynarok's Avatar
Had something similar a few years back when I went to install tunes on mine. Here's the original thread: Custom vs. Strategy Tune (BAMA SCT)
I think the problems start around post #11? For all the info you need (plus probably stuff you haven't yet considered).
TL;DR though - return car to stock before updating the tuner device. Make sure device is up to date before installing any new tune. Always, always return car to stock between swapping tunes (ie go 93R to stock to 93S).
As for right now, try the methods listed to drain off the battery... it might cause the ECU to reset everything to stock (hopefully!). If that fails, call SCT...you might have to pull the ECU and send it to them to be reflashed into a stock configuration under SCT's warranty. The numbers you need are in the thread I linked. Not sure but I think this is their number
1-866-637-1672
BAMA or whomever probably won't be able to help you much as its the actual device that is causing the problem, not the tunes. You need to work with SCT directly.
Good luck.
---edit---
I managed to 'brick' my car twice, so really check that whole thread - after Ford reflashed it the first time I managed to brick it again before I figured out what was going on.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 08-10-2014, 10:32 AM   #15
Well it's a no go. Same thing happened. Plugged in tuner and says no ecm check egnition key is on.
Old 08-10-2014, 10:43 AM   #16
That thread is about a body kit
Old 08-10-2014, 10:45 AM   #17
The time between the last two posts was 8 mins. That's 22mins at least shy of 30min that worked for me. Have some patience buddy. Lol
Old 08-10-2014, 10:48 AM   #18
Rynarok's Avatar
? It links to my old thread for me. Odd.
Also, were you using a diablosport tuner? In that case I don't know if you'll need SCT's numbers. I'll see if I can find a number for them for you.
AXLEBACKS THREADS =
Old 08-10-2014, 10:51 AM   #19
Rynarok's Avatar
1-888-801-9865 for diablosport's customer service line.
You might have an issue though. Reading through their warranty, it states "c. DiabloSport shall not be held responsible for direct or indirect failures due to our product."
I'd call them regardless and see what can be done.
---edit---
Still reading thru the warranty. They might bounce you back to AM or wherever you bought it from. "iii. It is the responsibility of the dealer distributor to handle their own technical issues with customers, and not to direct them to DiabloSport."
Sounds like their warranty is essentially a "go F@ck yourself" statement
AXLEBACKS THREADS =
Old 08-10-2014, 10:56 AM   #20
scott_0's Avatar
first time youve mentioned this is an Intune device, I was under the impression it was an SCT, at any rate, Ive never dealt with Diablo, but Im sure theyll get you squared away
Old 08-10-2014, 11:35 AM   #21
I've had it unplugged for about 45 min now. Trying again.
---------- Post added at 12:35 PM ---------- Previous post was at 12:34 PM ----------
Lol well someone better get my car fixed.
Old 08-10-2014, 11:42 AM   #22
Thanks
---------- Post added at 12:42 PM ---------- Previous post was at 12:41 PM ----------
Yes it was AM that I got it from
Old 08-10-2014, 11:46 AM   #23
Yeah I thought u had SCT also. Oh well. It sucks but you'll get squared away. Just sucks you have to wait.
Old 08-10-2014, 11:48 AM   #24
Well diddent work
---------- Post added at 12:48 PM ---------- Previous post was at 12:47 PM ----------
Thanks Dallas stang
Old 08-10-2014, 12:03 PM   #25
Rapinator126's Avatar
Update your handheld online on the sct website
Old 08-10-2014, 12:09 PM   #26
Dude!
Old 08-10-2014, 12:09 PM   #27
scott_0's Avatar
did you read all the thread? its an Intune Diablo device........
Old 08-10-2014, 12:14 PM   #28
Nope sure. Didn't. Have this problem once in awhile while swapping from nitrous to NA tune and it's just a update.
But cheers for going with **** ty Diablo.
Old 08-10-2014, 12:16 PM   #29
Just saw the title and responded with, what I do.
Not going to go and read through 3 pages. When it's a simple fix.
Old 08-10-2014, 01:21 PM   #30
Old 08-10-2014, 02:05 PM   #31
Wish it was simple. It lost my backup. So the tuner won't do anything.
Old 08-10-2014, 02:06 PM   #32
Aacts like it not plugged in to a car
Old 08-11-2014, 07:19 PM   #33
scott_0's Avatar
did you get it back on the road man?
sent from HTC M8 using tapatalk
Old 08-11-2014, 07:50 PM   #34
Nope had to send my in tune and ecu to Diablo for repair.
Old 08-12-2014, 07:39 AM   #35
scott_0's Avatar
oh ****!! that's odd, when I had this issue with my SCT they sent me a stock recovery file, maybe a good reason to avoid the intune. are they charging you for this "repair"
The guy turned in his Car Title and I want to buy his car. How do I get a new Title for the car? stanley General Car Discussion 2 04-10-2010 09:45 AM
Trolls car and car audio Troll The Bar 26 03-23-2004 01:18 AM
Pics of the car with fresh coat of water less car wash SpectorV Mustang Audio & Video 22 02-23-2004 08:12 PM
this car isnt a parts car Rellik The Bar 11 10-09-2003 09:04 PM
Car Audio ---> Car Video Ken Mustang Audio & Video 2 05-07-2003 10:47 PM
02:42 PM
