Need help !!!!! - Mustang Evolution
Old 08-11-2014, 04:03 PM   #1
Justinsenese's Avatar
Need help !!!!!
Name:	ImageUploadedByMustang Evolution1407794594.346378.jpg
ID:	163262 how do you remove these on a 2013 mustang without any damage
Justinsenese is offline   Reply With Quote
Old 08-11-2014, 04:21 PM   #2
scott_0's Avatar
they're held on by spring push type connectors on the interior side, and double sided tape on the outer facing side. there is also an electrical connector for the lighting. carefully pull up starting at one end on the inner side, work you way to the other side carefully freeing the connectors, once free, disconnect the lighting connecter, then slowly lift the sill to break the double sided loose.
sent from HTC M8 using tapatalk
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 03:58 PM
Need to choose new tires..need help KyleUSAF Mustang Wheels & Tires 13 11-29-2005 11:13 AM
Need Help with Viruses on my COMPUTER! HELP ASAP!! Autobadges.com The Bar 41 02-05-2004 09:53 PM
02:08 PM
