CAI power gain testing - Mustang Evolution
Old 08-13-2014, 02:10 AM   #1
Region: Arkansas
Ok this is kind of two different questions but both about CAI.
Everywhere I look I see almost all the major tuners saying that CAI do in fact add a little bit of power whether it be on forums or their websites. And then for the most part I see regular people saying it didn't help at the track at all and stuff like that. I would appreciate any insight into this.
I'm taking my car to Brenspeed Texas on Thursday to have full exhaust and MGW shifter installed with a 93 tune. I would like to know what true power gains I could see, if any, if I went ahead and had them put one on.
Wildstang86 is offline   Reply With Quote
Old 08-13-2014, 02:47 AM   #2
bucko's Avatar
Its not a matter of if they add power or not, its a matter if they add power over the stock Mustangs air filter box/tube. Ford did a really good job in the design of their stock air intake system. Flows as good (and sometimes better) than most aftermarket CAI systems. Some of the aftermarket systems have an open element; it's not inclosed in a sealed box. The open element ones simply grab warm underhood air, which actually is going a step backwards over your stock unit. Some have a shield that supposidly seals against the hood, but they still draw warm, engine heated air rather than cooler air that a stock setup does.
Most folks buy an aftermarket CAI to "dress up" the engine compartment, or to obtain the "roar" that an aftermarket CAI can provide. Other than that, they really do not give any seat of the pants performance gains on their own. Should you want to hear the roar of the drive by wire pedal when its stomped (formerly known as a gas pedal), you can mod the stock air box; remove the sound deadning box thats on its side. If you seach here, you'll find out how to do this.
Some of the more expensive CAI are sold with a tuner; these provide better numbers, but it's because the tuner/tune thats sold with them give the performance boost. These CAI's have a slightly larger tube diameter over stock, so they have the potential to flow more air, which means the PCM/ECU requires re-mapping of the fuel/air ratio, hense the requirement for the tuner/tune.
Old 08-13-2014, 03:47 AM   #3
Grabber Blue5.0's Avatar
Bucko said it all. Nothing else needs to be said.
cai
Most power gain from a CAI? Limes3578 2011-2014 V6 Mustang 12 08-11-2013 07:26 AM
CAI & Chip HP gain? 2000v6stang Pre-2005 V6 Mustang 11 02-04-2013 08:36 AM
Power gain? Matticus 1996-2004 Mustang GT 9 11-15-2012 08:28 PM
Biggest power gain 01StangGt 1996-2004 Mustang GT 7 04-13-2012 08:53 AM
VMP 4.0 Power Packages - up to 25RWHP gain justin00stang Pre-2005 V6 Mustang 0 09-17-2007 01:15 PM
04:48 AM
