Eibach pro kit sprigs and stock bump stops need some help ! - Mustang Evolution
Old 08-13-2014, 04:56 PM   #1
crashkid500's Avatar
Hey guys i just got a new 2011 5.0 and a buddy of mine gave me eibach pro kit lowering springs. Only 1.5 in drop in rear and about an 1 inch front so i wanted to kno if i need to cut the rear and or front bumpstops in order to keep a comfty ride ? Any help would be greatly approciated ! Thnks
crashkid500 is offline   Reply With Quote
Old 08-13-2014, 04:59 PM   #2
JoeyM91's Avatar
The kit is supposed to come with new bump stops. Ask him if he can find them. The stock ones will be a bit rough.
Old 08-13-2014, 05:02 PM   #3
2 Stangz's Avatar
Region: Nevada
What... how does bump stops even come up in the conversation with 1.5" springs? My Steeda springs drop 1.5in in the rear and the stock bump stop still have a ton of room.
On another note, a friend of mine with (I think) the Cobra Jet rear springs or whatever springs with a really low drop trimmed his stock bump stops.
Old 08-13-2014, 05:39 PM   #4
JoeM1494's Avatar
Lowered my car last weekend on a set of Coilovers and I had to cut my bumpstop in half and I'm still sitting on it. I don't think you have much to worry about if it's just a 1.5inch drop haha. Maybe the smaller bump stops or a slight trim that's it.
Joe
'13 GT Track Pack
JoeM1494 is offline   Reply With Quote
Old 08-14-2014, 11:03 AM   #5
Thanks guys im gonna trim the just a little
Old 08-14-2014, 11:31 AM   #6
Wait do i need a panhard bar for 1.5 inch drop ?
Old 08-14-2014, 11:34 AM   #7
2 Stangz's Avatar
Region: Nevada
^I think so.
Old 08-14-2014, 11:35 AM   #8
I see ok thanks
Old 08-14-2014, 02:54 PM   #9
rockhillgt's Avatar
yes would get panhard bar. and really i'd get lower control arms with relocation brackets as well. That should be all with that drop.
rockhillgt is offline   Reply With Quote
Old 08-14-2014, 03:58 PM   #10
Ok will do thanks
Old 08-16-2014, 03:20 AM   #11
420hpkush's Avatar
I did mine with the panhard and SR control arms without relocation and the set up works great, I used the pro kit as well. Adjustable Panhard is a must. Car is off centre without it.
420hpkush is offline   Reply With Quote
Old 08-16-2014, 03:26 AM   #12
420hpkush's Avatar
Name:	ImageUploadedByMustang Evolution1408181110.625186.jpg
ID:	163567Click image for larger version
Name:	ImageUploadedByMustang Evolution1408181126.513515.jpg
Before and after, the one with my cat is after. Prefect drop hight I think
Old 08-16-2014, 08:29 AM   #13
Drop looks good with the pro kit, I need to get rid of the 4x4 look of mine too.
2014 Mustang GT, DIB, MT82, Tech and Track Package
mods are coming, slowly
kanine is offline   Reply With Quote
Old 08-16-2014, 08:38 AM   #14
420hpkush's Avatar
Doing all three things at the same time totally changed the feel and handling of the car . No more noes dive, and when you hit the gas the the rear end stays pretty much flat .. I'm very happy with it, for now
Old 08-18-2014, 05:04 PM   #15
Black302Alex's Avatar
I was actually wondering, what exactly do I NEED to lower my car on springs successfully? Many people are saying I'm going to need PH bar along with camber plates? Help! Thanks guys!
Black302Alex is offline   Reply With Quote
Old 08-18-2014, 06:12 PM   #16
20bmr14's Avatar
Black you can go without CC plates but you will be 1.3-1.6 neg camber in the front. The panhard bar is a given cause your rear end will not be centered after lowering it. I did CC plates and my friend did the same springs without plates or struts and his rides pretty good. I would spend money on struts before I would CC plates. The ride is so much better. Good luck.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 08-18-2014, 07:40 PM   #17
So I can basically just get the panhard and the springs and I'll be fine?
Old 08-19-2014, 03:34 AM   #18
420hpkush's Avatar
I didn't use CC plates but if I had the extra money at the time I would have put them in as well but Yes you can do it with just the PH and springs , the kit comes with alignment bolts but like he said it will be off just a bit. I have notice a little inner tire wear on the front right tire having had them done about 10000 kms ago . I will be bringing my car back to see if it can be aligned a bit better now that the springs have settled in. In the long run it would be wiser to have had the CC plates put in . Hope that helps
bump stops? BeachMonkey100 2005-2010 Mustang GT 2 04-26-2014 11:51 PM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 02:45 PM
Cut bump stops with eibach? maverick214 2005-2010 Mustang GT 6 01-08-2013 07:20 PM
Bump Stops for A arms runvsofthisbull 1996-2004 Mustang GT 0 08-09-2012 04:55 PM
removing or cutting bump stops wolfstang03 1996-2004 Mustang GT 1 04-10-2012 09:21 AM
09:48 AM
