Cat delete pipes - Mustang Evolution
Old 08-14-2014, 09:02 AM   #1
mustanggt2013's Avatar
Cat delete pipes
Will I get engine light with out a tune when I install them?
Sent from my HTC One_M8 using Mustang Evolution mobile app
mustanggt2013 is offline   Reply With Quote
Old 08-14-2014, 09:25 AM   #2
Coyote5o's Avatar
Region: West Virgina
yes - only way to see any benefits is with a tune. It will probably run terrible without one.
2013 Mustang GT w/ Track Pack - Steeda Ultralite Springs, Koni Str.t Struts/Shocks, BMR LCA & Relocation Brackets, BMR Adjustable UCA and Bracket, BMR Adjustable Panhard, DSS Aluminum Driveshaft, Bassani x-pipe and catback, MGW shifter, JLT CAI, Steeda Tune
Coyote5o is offline   Reply With Quote
Old 08-14-2014, 10:43 AM   #3
I have the tune for it but was just wondering if I should tune before or after u install em
Old 08-14-2014, 10:48 AM   #4
Runs real good with the tune. But took it off untill I get the pipes installed.
Old 08-14-2014, 10:55 AM   #5
WhiteCali5oh's Avatar
How long does the cats take to remove
And put the delete
Pipes in place?
WhiteCali5oh is offline   Reply With Quote
Old 08-14-2014, 10:56 AM   #6
Coyote5o's Avatar
You need separate tunes for a car with/without cats. If the tune is for a cat-less car, then i would wait to use it until after the cats are removed.
Old 08-14-2014, 11:04 AM   #7
Ya that's what I figured.
30 mins maybe.
Old 08-14-2014, 05:58 PM   #8
Region: Wyoming
It's probably about 1 1/2 hour job by yourself the passenger side cat is a pain to remove hope you got about 2ft of extension an a swivel and some penetrating oil your gonna need it lol all in all mine wasn't bad take your time and use a jack on the mid pipe when installing back together to help get it even so you don't have any leaks
r_neck7 is offline   Reply With Quote
Old 08-14-2014, 06:03 PM   #9
I don't have the clamps under there anymore. Will be welding them on.
Old 08-15-2014, 07:37 AM   #10
Region: Wyoming
Probably make install a little easier as long as you can get it lined up correctly to tack it together
Old 08-15-2014, 08:50 AM   #11
I hear ya
Old 08-15-2014, 09:18 AM   #12
scott_0's Avatar
yes, you will get a CEL for the rear O2 sensors, the main reason for a tune when removing the cats is to turn off the COTS feature (cat over temp protection) which dumps fuel to keep the cats cool, the CEL will actually not effect performance at all, but the COTS being left on will
Old 08-15-2014, 09:45 AM   #13
Nice. Thank you for breaking it down for me.
Off Road Cat Delete Pipes tigerfan2771 2011-2014 Mustang GT 11 05-19-2014 01:56 AM
Cat delete pipes Yankee5.0 2011-2014 Mustang GT 16 04-30-2014 10:53 PM
Header to cat/cat delete pipe gasket. nosympathy 2011-2014 Mustang GT 9 12-14-2012 09:36 PM
X-Pipes and H-Pipes? Soccerluvr4 2005-2010 V6 Mustang 4 02-26-2012 06:10 PM
off-roaad h-pipes and x-pipes Black00GT 1996-2004 Mustang GT 2 02-19-2004 06:12 PM
05:55 AM
