Sway bar relocation bracket issue - Mustang Evolution
Old 08-14-2014, 11:57 AM   #1
grabber12's Avatar
Hey guys I'm trying to put on the relocation brackets from steeda and the sway bar hits my lower control arm mount waaaay before the holes will even line up so I can install the bracket. I jacked the car up on the rear end, could that be causing this?
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 08-14-2014, 12:20 PM   #2
Grabber Blue5.0's Avatar
Can you take a picture of what you're referring to? Are you talking about the lower control arms or control arm relocation brackets?
Old 08-14-2014, 12:36 PM   #3
grabber12's Avatar
I got it bolted up but as you can see the sway bar rubs on both sides.
Sent from my HTC6435LVW using Mustang Evolution mobile app
Old 08-14-2014, 12:39 PM   #4
grabber12's Avatar
I think before I cut the tab off I'm just going to bolt everything up like it is and see if I hear any noises. If I do then I'm going back to stock and just going with 17 inch rims
Old 08-14-2014, 02:40 PM   #5
grabber12's Avatar
Took it for a drive and I don't hear any clucking or noises and that seems odd because my sway bar is touching the LCA mounting area on driver side. On the passenger side it's a paper thickness from touching.
Old 08-14-2014, 02:49 PM   #6
If you're lowered you should be running the control arm relocation brackets anyways. I've never seen this before. Another option would be the rear sway bar from a 2010. It's a little smaller and will bolt right up.
Take a pic showing the whole rear for me so I can see both sides at the same time. That pic is a little tough to see. Also jacking the car up is going to give you a different look. The car needs to be on the ground with all the weight on the rear. If you raise the sway bar up after cutting the bottom portion of the shock mounts off that could also give you your clearance.
Old 08-14-2014, 03:06 PM   #7
Grabber, if I want to lower my car an inch, compared to 1.25 inches, what would I need for either?
Old 08-14-2014, 03:06 PM   #8
grabber12's Avatar
Thanks for the reply grabber5.0. I don't hear any clucking so I'm going to say I picked up some clearance when I put the wheels back on and put her on the floor. I'll be getting LCA's very soon then I think you're right it will come together much better. All this just to fit 15s hahaha. Should have just committed on running 17s on some MTs in the rear. O well.
Old 08-14-2014, 04:24 PM   #9
Control arm relocation's, possibly. The sway bar relocation brackets are only necessary when wanting to run a 15" wheel.
If you don't care about getting the car to hook on the street or the track you could skip the control arm relocation brackets as well.
There are many advantages to running a 15" tire. One is they're cheaper. Two is they will help much more with getting the car to hook. And three they will provide a better ride. Here's what mine looks like for point of reference.
Name:	BMR Steeda Relocates.JPG
Rear sway bar relocation bracket; hard to install? jrolivo1975 General Mustang Discussion 4 04-19-2014 05:12 PM
spohn lca relocation bracket 610swolf 2005-2010 Mustang GT 2 06-18-2013 05:55 AM
Sway bar relocation?? McQueen 2011-2014 Mustang GT 12 12-04-2012 06:43 AM
Front sway bar bracket RedBandit11 2011-2014 Mustang GT 10 11-09-2012 03:00 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
08:24 PM
