JLT Oil Separator - Mustang Evolution
Old 08-16-2014, 04:56 PM   #1
wgolden30's Avatar
JLT Oil Separator
Does anyone use this?
Is it worth buying for a stock 13 GT?
wgolden30 is offline   Reply With Quote
Old 08-16-2014, 05:05 PM   #2
Rapinator126's Avatar
Get breathers
Old 08-16-2014, 05:32 PM   #3
wgolden30's Avatar
dont see any on american muscle, can you send a link?
what are the benefits of having breathers on a stock engine, if any?
Old 08-16-2014, 05:38 PM   #4
http://www.jpcracing.com/2011-gt-boss-breather-package/
Bc the separators still let oil into the intake.
Old 08-16-2014, 05:39 PM   #5
wgolden30's Avatar
thank you,
does anyone else have experience using breathers on their new GT???
Old 08-16-2014, 07:26 PM   #6
Grabber Blue5.0's Avatar
I use breathers. The JLT oil separators can cause a lean condition due to air leaks.
Old 08-16-2014, 07:28 PM   #7
wgolden30's Avatar
very interesting, wish i could learn all of this stuff from a website or something other than forums lol.
can the breathers cause any issues?
i am completely stock, no tune.
Old 08-16-2014, 07:30 PM   #8
You don't need a website. Just pay attention to my posts and you'll learn plenty.
Old 08-16-2014, 07:35 PM   #9
Lmao. Do people not trust me hahah
Old 08-16-2014, 07:37 PM   #10
wgolden30's Avatar
i believe you.
but i would rather hear more than one person say something before i apply something to my 30k car. plus grabber blue elaborated a bit more to help me understand.
Old 08-16-2014, 07:41 PM   #11
Sometimes it's not about getting many opinions but rather the right ones from the guys that have done it.
Words of wisdom.
Old 08-16-2014, 07:59 PM   #12
SSTHIS's Avatar
Bobs auto sports has a cool design and according to them seems to work better than the JLT and the SVT version , there is a video on their website. If you decide not to go the breather route. I don't have one yet ,was going the metco breathers route or the Bob's just haven't done it yet
Sent from my XT1080 using Mustang Evolution mobile app
SSTHIS is offline   Reply With Quote
Old 08-16-2014, 08:02 PM   #13
Abominable Mustang
WhoDat's Avatar
Region: Alaska
How often do you have to replace/clean the breather filters?
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-16-2014, 08:09 PM   #14
2 Stangz's Avatar
Region: Nevada
+1
Old 08-16-2014, 08:18 PM   #15
I clean mine every oil change. So every 3,000 miles for me.
Just do them every oil change.
Old 08-16-2014, 08:24 PM   #16
2 Stangz's Avatar
Region: Nevada
I find it interesting that you change your oil every 3,000 miles. I use the Motorcraft synthetic blend and it lasts much longer than 3,000.
Old 08-16-2014, 08:28 PM   #17
E85
Old 08-16-2014, 08:29 PM   #18
2 Stangz's Avatar
Region: Nevada
Ah, gotcha.
Old 08-16-2014, 09:29 PM   #19
ddtmoto's Avatar
Region: Utah
Two problems with breathers. Oil mist in engine compartment which is not good for keeping your car clean under the hood and smelly oil vapor for cabin occupants #2, illegal for emissions requiring closed systems. Won't pass smog visual inspections in states with them....the JLT separators work as advertized.
ddtmoto is offline   Reply With Quote
Old 08-16-2014, 09:34 PM   #20
GrabberBlue1993's Avatar
Any options besides the JLT for the 2012 v6?
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 08-16-2014, 10:01 PM   #21
wgolden30's Avatar
disregard emission, but whats this about bad for engine??
Old 08-17-2014, 12:13 AM   #22
Here we go with this again. I'm not going to go through all this again, did it b4.
Breathers are perfectly fine,
Listen to people who have been down this road,
I'm not going to tell you to do anything I have not done myself.
Old 08-17-2014, 12:36 AM   #23
I don't get any oil mist in my engine compartment.
And as far as emissions goes it takes 2 minutes to switch everything back to stock.
JLT oil separators do not catch all of the oil and again cause vacuum leaks and lean conditions. Something only a data log will pick up.
Old 08-17-2014, 08:07 AM   #24
wgolden30's Avatar
Wow i might not get either after hearing this stuff
Old 08-17-2014, 10:18 AM   #25
Paradone's Avatar
haven't had the first problem using this separator when I change my oil I check the intake end with a Qtip no residue at all. I clean the unit each oil change which has been once so far and it also has two chambers.
Paradone is offline   Reply With Quote
Old 08-17-2014, 10:56 AM   #26
They are perfectly fine. Ran them on my stock motor and now on my Built motor.
Like I said listen to people who run them
Old 08-17-2014, 07:06 PM   #27
ddtmoto's Avatar
Region: Utah
I don't see how a catch can/separator added to a closed pvc line can cause a lean condition. I see it as exactly the same as OEM only with a separator to collect oil vapor and hold onto it. Explain? Opening the crankcase up to the atmosphere with a breather style is suspect in my book. Open vs closed, seems like a no brainer to me. A closed system like oem can only draw air from the crankcase if there is pressure/blow by available with a one way valve/pcv, not lean air from outside the motor. A breather just vents crankcase blow by/pressure into the engine bay and into our air we breath...? Kinda like removing cat convertors when we are trying to clean up our atmosphere, except in third world countries, not go backwards to the smog of the 60s and 70s. Sounds a tad selfish to me...but most here are too young to remember the hideous conditions of the air in so. California in those days. Oh well...
JLT Oil Separator GrabberBlue5.0 2011-2014 Mustang GT 55 12-23-2015 10:35 AM
Jlt vs Moroso oil separator OzzyLiriano 2011-2014 Mustang GT 39 10-29-2013 02:07 PM
JLT Oil Separator for Blown 5.0 poloka 2011-2014 Mustang GT 5 02-15-2013 02:47 PM
JLT Oil Separator 08Mustang 2005-2010 V6 Mustang 16 06-30-2012 07:56 AM
JLT oil separator Mustangpower5.0 2011-2014 Mustang GT 13 05-18-2012 10:32 PM
10:53 PM
