Mystery wire? - Mustang Evolution
Old 08-18-2014, 09:32 AM   #1
WJBertrand's Avatar
Mystery wire?
I was installing some upgraded speakers in the rear package shelf of my '13 GT premium this weekend. When I removed the large right side, inner quarter panel trim, I found this wire just rearward of the door opening. Out of curiosity, I removed the electrical tape and found a single small (16ga?) wire in there, black with a white stripe. The end was prepared for stripping with the insulation cut about 1" down and separated slightly there. The harness loom and sticky tie-wrap anchors look aftermarket to me, but I bought my car brand new.
One photo shows where the wire terminates and is taped over, the other photo shows where it routes down under the seat and disappears beneath the carpet.
Any idea what it's for?
ID:	163748   Click image for larger version
Name:	mystery wire 2.jpg
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 08-20-2014, 05:39 AM   #2
Noodles76's Avatar
I'm curious as well now...
2014 5.OHHHHHH
Noodles76 is offline   Reply With Quote
Old 08-20-2014, 07:18 AM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
More than likely something for the Shaker 1000 option
2012 Kona Blue 3.7L V6:
Old 08-20-2014, 08:20 AM   #4
Noodles76's Avatar
He has the premiums which would mean he already has the shaker system.
2014 5.OHHHHHH
Old 08-20-2014, 08:43 AM   #5
Voltwings's Avatar
EJECTO SEAT CUZ!
Old 08-20-2014, 10:25 AM   #6
mystang50's Avatar
Originally Posted by Voltwings View Post
EJECTO SEAT CUZ!
Old 08-20-2014, 10:45 AM   #7
EJECTO SEAT CUZ!
hahaha beauty
2012 GT Ignot Silver
Evolution5.0 is offline   Reply With Quote
Old 08-20-2014, 11:10 AM   #8
WJBertrand's Avatar
One suggestion I got was that it might be an antenna for a LoJack system. As far as I know, there's never been a LoJack installed on this car. I called LoJack and they of coarse will confirm nothing but did tell me that dealers sometimes install them to protect their inventory and deactivate them after sale.
So far this seems the most likely explanation. If it was part of the Shaker system, i.e. a subwoofer amplifier turn on signal wire or something, someone would have identified it by now I expect. The mystery remains...
-Jeff-
Ventura, CA
Old 08-20-2014, 12:00 PM   #9
Strange Mud's Avatar
does your rear defrost work?
Old 08-20-2014, 05:58 PM   #10
WJBertrand's Avatar
I haven't used it recently, being that it's summer, but yes it has worked fine before.
-Jeff-
Ventura, CA
Old 08-20-2014, 06:20 PM   #11
Abominable Mustang
WhoDat's Avatar
Region: Alaska
2014 5.OHHHHHH
The premiums come with the Shaker 500 which includes the door subs. The Shaker 1000 is part of the audio package, which adds two trunk subs on the right side, exactly where he found this wire.
Old 08-20-2014, 06:31 PM   #12
Noodles76's Avatar
Learn something new everyday. My B
2014 5.OHHHHHH
Old 08-23-2014, 02:50 PM   #13
WJBertrand's Avatar
So curiosity got the better of me (and I had to pull the right rear inside panel again to wire my new sub anyway) so decided to trace this wire. I didn't lead very far, just to under the right rear seat down by the floor behind were someone's heel would be sitting there. I found this (see photo). It is self contained with batteries and a circuit board inside. I tried scanning the bar code but it only came back saying this is the kind of code used to track shipments. Guessing it's a LoJack?
Name:	Lojack maybe.JPG
-Jeff-
Ventura, CA
Old 08-24-2014, 11:28 PM   #14
13coyotevahan's Avatar
Where would lo jack be then???
If at first you don't succeed. keep flushing!!!
13coyotevahan is offline   Reply With Quote
Old 08-25-2014, 11:59 AM   #15
WJBertrand's Avatar
Huh?
-Jeff-
Ventura, CA
Old 08-25-2014, 01:17 PM   #16
Where does ford put their gps?
Old 08-25-2014, 01:45 PM   #17
WJBertrand's Avatar
I don't think Ford puts a GPS in the car unless you have the navigation package, which I do not. In the case of the nav package, I would assume the GPS is integrated into the head unit.
-Jeff-
Ventura, CA
Old 08-25-2014, 01:46 PM   #18
Haha damn it I meant do our cars have tracking devices? and if so where would they be?
Old 08-26-2014, 06:08 AM   #19
What is this?
Lojack
charliep is offline   Reply With Quote
Old 08-26-2014, 06:52 AM   #20
My Ford Touch
If you have the "MY FORD TOUCH" feature you do have a GPS in your Mustang. If you crash the car and the airbags go off, That is used to locate you. I have this on my 2012 MCA premium.
My Ford Touch will also give me directions to where I want to go. I find my Garmin 55LMT works much easier and better though, so I really don't use it.
WJBertrand probably has the My Ford Touch on his car and this is how they would find his location if the airbags deployed.
Old 08-26-2014, 07:30 AM   #21
WJBertrand's Avatar
I actually do not have my ford touch in my car, but sync uses my phone's GPS to locate me and call 911 in the event of an air bag deployment. Sync also gives turn by turn directions. Again, none of this works without my phone.
-Jeff-
STOC 025
-Jeff-
Ventura, CA
Old 08-26-2014, 07:54 AM   #22
I have a 2012 and mine works fine without a smart phone.
I have a blue tooth capable flip phone and it only works for telephone calls, No texting, or anything else and my Ford touch works fine.
I'm reasonably sure that box on your car is a tracking device and I probably have the same thing on my Mustang.
Old 08-26-2014, 08:11 AM   #23
have you done something to make your wife suspicious?
Old 08-26-2014, 10:26 AM   #24
WJBertrand's Avatar
That's a limitation of your phone, not sync. Again if you don't have my ford touch or nav, sync depends on a smart phone for directions and location.
Whatever that thing is, It's not in my car now! It's certainly not OEM, as it was completely independent of the car's electrical system, not connected to anything. 99% sure it's a LoJack.
-Jeff-
STOC 025
-Jeff-
Ventura, CA
Old 08-26-2014, 11:07 AM   #25
It is a jo-jack
I googed the #5500-1103-01 and it agrees with you as being a lojack. I'll bet the dealer probably forgot to remove it when they sold you the car.
Old 08-26-2014, 01:10 PM   #26
WJBertrand's Avatar
The dealer would have had to deactivate it, which I'm told by LoJack is permanent. They probably just don't bother collecting the deactivated units since they evidently cannot be used again. I took it apart and removed the battery - just to be sure, but I'm not paranoid or anything
-Jeff-
Ventura, CA
Need to connect red wire to gray wire. clflorida Pre-2005 V6 Mustang 4 08-06-2013 06:46 PM
I alway thought that this was a pretty interesting unsolved mystery JROC The Bar 1 01-03-2008 02:13 PM
Cold Air Intake Mystery chris7869 Pre-2005 V6 Mustang 7 02-10-2007 05:37 PM
Guess the Mystery Celeb 00vertstang The Bar 16 11-02-2004 02:33 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
12:09 AM
