loose steering wheel + "pop" - Mustang Evolution
Old 08-20-2014, 10:02 AM   #1
Voltwings's Avatar
So, as the title states, i am trying to diagnose a pop in the steering wheel when gassing through turns, and will try to provide as much detail as possible below.
1. the K-member has been dropped by a shop to install headers... i think the problem started when i got the car back, but i really cant remember since it took a while to notice it, the problem does not happen every single time.
2. There is a slight (but noticeable) amount of slack in the steering wheel; basically i can jiggle the steering wheel with no movement of the actual wheels. I have compared with other mustangs and mine is noticeably more loose. Car has 20k miles and no wrecks.
3. When the popping occurs it is not only audible, but i can feel it in the firewall / through the gas pedal
4. The car is lowered on OEM boss shocks / struts / FRPP K springs
- I know some people mention the top hats / perches need to be replaced when lowered, but i have a feeling this is a different issue
5. i have gotten under and tightened / double checked every single nut / bolt i can find and they are all tight
6. If someone is in the car jiggling the wheel, you can slightly hear it where the steering shaft exits the firewall in the engine bay.
7. The pop is consistent throughout the turn, not just a one time thing, and stops once the steering wheel is moved back towards the neutral position.
Possible thoughts:
1. The steering shaft is hitting the Kooks shorty headers when turning and the motor is torqued? I think i really only notice it on left hand turns (including a high speed corner at my recent track weekend, as well as around town, it is not speed dependant), but i have no idea how hard / far the motor torques when turning or on the gas. The kooks headers also look like they have plenty of room under the car.
2. K-member / steering rack no realigned properly? It really looks like theres only one way for it to go, and even if it was off, it doesnt explain the slack in the steering wheel.
3. basically the only thing i can think of is a damaged steering rack? What else would cause slack and whatever the hell is popping like this?
I'm tired of trying to figure this out and would really appreciate some help. Thanks.
Loose steering. 66 coupe. richpickins01 Classic Mustangs 14 11-09-2013 08:33 PM
Steering wheel feels a little loose 1999mustang Pre-2005 V6 Mustang 4 08-08-2013 07:04 AM
Steering pop twotone01 Pre-2005 V6 Mustang 11 05-16-2012 05:55 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
01:37 PM
