LCA'S - Mustang Evolution
Old 08-22-2014, 05:56 PM   #1
medic204's Avatar
LCA'S
My 13 5.0 is going in on Monday to have the lower control arm bushings replaced. Had to have dealer drive it 3 times before they would replace.. it has 8500 miles on the clock should I have them check anything else while it's apart???
medic204 is offline   Reply With Quote
Old 08-22-2014, 06:47 PM   #2
BLKBETTY13's Avatar
Should cancel the appointment and just buy some aftermarket LCA's with poly's. Cheap investment and won't have to worry about it anymore.
BLKBETTY13 is offline   Reply With Quote
Old 08-22-2014, 09:41 PM   #3
jp1seattle's Avatar
I'm assuming you're talking about the front LCAs?
If that's the case, the latest dealership fix with the heat shield works. At least it did for me when I had it done last summer.
If your rear LCAs are making noise, I'd do what the other poster said and replace them with aftermarket.
jp1seattle is offline   Reply With Quote
Old 08-22-2014, 09:47 PM   #4
medic204's Avatar
It is the front. When I pull the car into the garage it sounds like an old granada when I drive over the hump lol
Old 08-23-2014, 05:41 PM   #5
grabber12's Avatar
How sure are you that its the LCA? Are you lowered? Lots of us have the popping sound going over bumps at slow speeds do to the strut tower mounts. Ford replaced mine and within 15 miles they make the same sound that i brought it in for.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 08-23-2014, 05:53 PM   #6
medic204's Avatar
No lowering. No popping. It squeaks and has a rubbing sound when going over a speed bump and the lip into my garage. But they had to drive it for a bit to warm it up to replicate the noise
LCA's are ordered!!!!!!!!!!!!!! Rygen Pre-2005 V6 Mustang 2 02-16-2006 03:19 PM
My next mod: LCA's (what to get?!?!?!) Rygen Pre-2005 V6 Mustang 3 02-12-2006 06:12 AM
going back to stock: 3.8 parts, shortblock, lca's, SPI p/p intakes, tb, etc. tire Mustang Parts for Sale and Wanted 2 07-09-2004 08:48 AM
tested my MM lca's today tire The Bar 7 03-20-2004 05:03 AM
looking for an LCA that will not bind and make noise bad? SpectorV Pre-2005 V6 Mustang 1 05-05-2003 06:38 PM
12:57 AM
